    [Plugin] Selection Toys
    594 Posts 121 Posters 499.1k Views 121 Watching
      Panga
      Thanks for this update, and this great plugin !!
        Maybe an image of the arborescence folder/files needing result will be an help for new plugin users? 😉
          Yea - I've been thinking I should include that for plugins that consists of multiple files packaged in .zip.
            Outer Edges added to selection filters and Quad-Face Loop now accepts multiple start-edges in my internal build. Got a couple of other things to finish before I release it though.
            • bagateloB Offline
              bagatelo
              MODO from Luxology have good tools that make interesting selections. I remenber one very good. Is something like select polygon by yes/no/yes/no/yes/no, or by samples. Think about this, please.
                yes/no/yes/no/yes?
                • bagateloB Offline
                  bagatelo
                  @thomthom said:
                  yes/no/yes/no/yes?
                  Please see the imagem called "selection"...
                  This is plugins tools to make selections in 3dsMax, and more...:
                  http://www.polyboost.com/features_selection.htm
                  http://www.orionflame.com/
                  • JClementsJ Offline
                    JClements
                    Hi Thom:
                    Selection Tools must be a labor of love! 😄
                    Selecting Instances on same layer (both all and active) not working? See attached.
                    Select Instance of Same Layer Not Working.skp
                      I will look into that.
                      (you edited you post? you mentioned about selecting from active vs all - well, I have been planning a complete new set of selection tools, where you interactively build your selection)
                        @jclements said:
                        Another Bug; Select Edge Loops?
                        If after an edge loop is selected, then using the Layers Toolbar dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                        hm.. will have to look at that. I never use that toolbar. PC or OSX?
                        @jclements said:
                        Select Default Front and Default Back not working?
                        Might be a bug there. Thought I'd fixed it earlier, but maybe it slipped through... 😕
                          JClements
                          Yeh, I edited my post because part of it didn't make sense. 😲
                          If after an edge loop is selected, then using the Layers Toolbar (PC) dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                          [Edit]
                            @jclements said:
                            Hi Thom:
                            Confirmed and fixed internally.
                            Thanks for reporting.
                              Can't reproduce.
                                @thomthom said:
                                Can't reproduce.
                                Saying that, as it works now, the edges also needs to have the same material for the Select Connected by Material to select the neighbouring face... Might have to revise this function. ...and I wonder why I haven't added one that doesn't select connected....
                                  [attachment=0:137w7llf]<!-- ia0 -->Layers Toolbar, PC.png<!-- ia0 -->[/attachment:137w7llf]
                                  This is very odd. But it seems to be a Sketchup bug. I can't see anything in my code that'd do this. And as you say, the Entitiy Info works. I'll try to forward this to Google.
                                    rv1974
                                    Hi!
                                    What I really missinng is option to select all edges bitween "90 degrees faces" (the exact degree number should be ajustable)
                                      Ah - took me a little while to understand this one, but being able to select edges where the angle between connected faces are larger than a given angle?
                                      This would be something that filters an existing selection? Or make a new selection in the active space?
                                        rv1974
                                        ...being able to select edges where the angle between connected faces are larger than a given angle?..
                                        -yes
                                        ...filters an existing selection?
                                        -yes
                                        • juan974J Offline
                                          juan974
                                          good idea rv1974, kind of : "select string edges", useful for complicated shape
                                          juan974 (Réunion island)
                                          website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                          • N3TON Offline
                                            N3TO
                                            Where can I download Seletcion Toys (2.1.0)???
                                            thanks
                                            • 11
                                            • 12
                                            • 13
                                            • 29
                                            • 30
                                            • 11 / 30
