    [Plugin] Selection Toys
    594 Posts 121 Posters 565.6k Views 121 Watching
      yes/no/yes/no/yes?
      • bagateloB
        bagatelo
        @thomthom said:
        yes/no/yes/no/yes?
        Please see the imagem called "selection"...
        This is plugins tools to make selections in 3dsMax, and more...:
        http://www.polyboost.com/features_selection.htm
        http://www.orionflame.com/
        • JClementsJ
          JClements
          Hi Thom:
          Selection Tools must be a labor of love! πŸ˜„
          Selecting Instances on same layer (both all and active) not working? See attached.
          Select Instance of Same Layer Not Working.skp
            I will look into that.
            (you edited you post? you mentioned about selecting from active vs all - well, I have been planning a complete new set of selection tools, where you interactively build your selection)
              @jclements said:
              Another Bug; Select Edge Loops?
              If after an edge loop is selected, then using the Layers Toolbar dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
              hm.. will have to look at that. I never use that toolbar. PC or OSX?
              @jclements said:
              Select Default Front and Default Back not working?
              Might be a bug there. Thought I'd fixed it earlier, but maybe it slipped through... πŸ˜•
              • JClementsJ
                JClements
                Yeh, I edited my post because part of it didn't make sense. 😲
                If after an edge loop is selected, then using the Layers Toolbar (PC) dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                [Edit]
                  @jclements said:
                  Hi Thom:
                  Confirmed and fixed internally.
                  Thanks for reporting.
                    Can't reproduce.
                      @thomthom said:
                      Can't reproduce.
                      Saying that, as it works now, the edges also needs to have the same material for the Select Connected by Material to select the neighbouring face... Might have to revise this function. ...and I wonder why I haven't added one that doesn't select connected....
                        [attachment=0:137w7llf]<!-- ia0 -->Layers Toolbar, PC.png<!-- ia0 -->[/attachment:137w7llf]
                        This is very odd. But it seems to be a Sketchup bug. I can't see anything in my code that'd do this. And as you say, the Entitiy Info works. I'll try to forward this to Google.
                          rv1974
                          Hi!
                          What I really missinng is option to select all edges bitween "90 degrees faces" (the exact degree number should be ajustable)
                            Ah - took me a little while to understand this one, but being able to select edges where the angle between connected faces are larger than a given angle?
                            This would be something that filters an existing selection? Or make a new selection in the active space?
                              rv1974
                              ...being able to select edges where the angle between connected faces are larger than a given angle?..
                              -yes
                              ...filters an existing selection?
                              -yes
                              • juan974J
                                juan974
                                good idea rv1974, kind of : "select string edges", useful for complicated shape
                                juan974 (RΓ©union island)
                                website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                • N3TON
                                  N3TO
                                  Where can I download Seletcion Toys (2.1.0)???
                                  thanks
                                    thanks
                                    Bottom of the first post on the first page of this thread.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Selection Modifier
                                      Selection Submenu - Currently there's two kinds of modifiers.
                                      The explanations are a bit confusing for me... I have alot of experience in Electronic Radio Frequency / Broadcast Engineering, where Filters are a very important device. So when I think of Filters I think of them in that respect. See if you think I'm correct here:
                                      One filters out the type of entity you want.
                                      This would be a 'Pass' filter?
                                      http://en.wikipedia.org/wiki/Band-pass_filter
                                      The other deselects the entity you specify.
                                      This is a 'Reject' Filter? (also sometimes called a 'Trap' or 'Notch' Filter from the way the signal looks on a Spectrum Analyser.)
                                      http://en.wikipedia.org/wiki/Notch_filter
                                      I'm not here much anymore.
                                        I think so ... from what I understood of that definition of filters... unfamiliar territory to me.
                                          DIEGO-RODRIGUEZ
                                          hi tom.
                                          a question
                                          as I select only:
                                          1 - Lines with a free end (no connection with another line or entity)
                                          2 - lines with the two free ends (no connection with another line or entity, in its extreme ningudo)
                                          http://img534.imageshack.us/img534/1747/sinttulo1zd.jpg
                                            arjunmax09
                                            please help me.... i'm not getting all the buttons in the toolbar... only able to get faces, edges, groups and component options
                                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 29
                                            • 30
                                            • 12 / 30
