    Dome with smooth edges
    29 Posts 9 Posters 6.0k Views 9 Watching
      Jim
      Could you make them quads, then have only a very small, flat circle on top. Instead of a single vertex where the lines converge?
      The image reminds me of Moe's hair from the Three Stooges, btw. 😆
      • GaieusG
        If you download my dome, that's exactly what I did. Maybe it could be even smaller.
        However it stretches the texture this way, too.
          Jim
          I see now - scaling the texture is not quite what you want. My eye was tricked, but the tiles should not actually be scaled as they are.
          • GaieusG
            Yes, in the meanwhile I edited my previous post, too.
            Solution - put a cap on the top. 😛
            Dome.skp
              Is there a plugin to create a Geodesic Dome.
              Seems you have someone in the Components menu Shapes or in 3Dware house 😉
              • GaieusG
                If you want to know something about geodesic domes, our fellow member Taff Gogh is to search for. This is his 3D Warehouse contribution:
                http://sketchup.google.com/3dwarehouse/cldetails?mid=1f33552966b6f22224e5217d8a2e013a
                and his Google Groups for Geodesic Domes:
                http://groups.google.com/group/geodesichelp
                But unfortunately, Al, I would doubt that a different shape on the top would help (albeit who knows?) It's where the image itself should also shrink to infinity. So speaking of skies, maybe one with a pure, blue colour on the very top could produce some not noticeable turbulence?
                • charly2008C
                  charly2008
                  Thanks for all your help. I will try out UVMapper.
                  • Al HartA
                    Al Hart
                    Can you show us a view from the top of the dome with a cap on top.
                    (Or was that a joke?)
                    Thanks,
                    Al
                    Al Hart
                    IRender nXt from Render Plus
                    • Al HartA
                      Al Hart
                      Thanks for your help on this Gai.
                      We need to get Whaat to recognize the triangles at the top, and assign the UV coordinates differently.
                      Alternatively, you could start with a Geodesic Dome which uses the same size for all triangles. Would Whaat's plug-on work for Geodesic Domes?
                      We tried to solve this when we were trying to improve the O3D dome for viewing panoramic images (which has the same problem at the top and bottom), but we weren't able to do it properly.
                      Al Hart
                        driven
                        2004 by Gavin Kistner- Geodesic_SketchUp.rb
                        don't remember where or when I got this, have you tried it?
                          Taffgoch serial domes is amazing 😲 😲 😲
                          His PDF is a true gem! 😎
                          • GaieusG
                            Al, see the image I attached to that post. There is a yellow "cap" - just hiding the fact that we cannot properly UV Map that part.
                            Maybe half joke but at the same time, if you can find out something to put there, can be a workaround.
                              This is as it would be in the 'real-world' - you'd have a special cap-stone or finial, simply because you can't use smaller and smaller tiles or stone to finish it - The builder WILL use a single 'thing'... 💭
                              • GaieusG
                                Certainly. Even the rest of the tiles mapped spherically is impossible.
                                • Al HartA
                                  Al Hart
                                  I see my problem better now.
                                  I don't want a texture mapping which gets smaller and smaller at the top. I want a texture mapping which is uniform over the entire dome - As if you placed an actual carpet on the dome.
                                  To do this properly, I would probably need to make the dome out of hexagons, and have a "hexagon tileable" pattern to place on it.
                                  I'm sure people must to this sometimes, but it is probably more difficult than I think.
                                  http://plus.maths.org/issue8/features/art/orb.jpg
                                  Al Hart
                                    driven
                                    I do this a lot , if that's what you mean
                                      d12dozr
                                      And just HOW do you do that? 😄 I believe that is what he means...
                                      http://goo.gl/f7ooYh
                                        driven
                                        probably the hard way,
                                        I strip out the annular rings from one sphere, make a group, rotate copies until I like the pattern, explode the lot, slice off the top (3 or 4 rings), drape with sandbox, slice off the top of a plain old 'follow me' sphere (just 1 or 2 rings), offer up the sandbox hat (Gai was right, just a hat), decide how far to use the pattern, trim, explode, add projected material off a number of different angled surfaces I paint ( and make unique before projecting), decide what I like, purge all the test materials, and that's it...
                                        I make these cages for pipe along path objects, and just thought I try draping and rendering one night,
                                        foolishly I always bin the makings and have to start from scratch each time, but I'll keep this drawing and use it as a component, nearly everything is grouped so have a play.
                                        like this
                                        You only need to change the top 1 or 2 rings to completely change how the texture gets projected, but I have no idea why.
                                        On this one I also copy pasted the cylinder off the standard one because the texture worked better on that one, again no idea why.
                                        this is why I normally use this technique (it's for a 3D printing test in stainless steel)
                                        I haven't cleaned this up, but should be OK
                                          d12dozr
                                          Thank you for the detailed explanation.
                                            driven
                                            no problem, don't know if it helps Al (I know next to nothing about UV mapping, but I just saw this sitting on the desktop and may as well add it
                                            I think explains the basic construction technique more clearly
