    Dome with smooth edges
    29 Posts 9 Posters 5.7k Views 9 Watching
    • GaieusG
      How about this one, Al?
      Mapped with Whaat's UV Tools (it screws up the very top generally but don't look at it from above).
      Note that I doubled the segments of both the base circle and the arc.
      Dome.skp
      • charly2008C
        charly2008
        Hi Gaieus,
        I have tried the UV-tool for the first time.It works perfectly except for the polar cap. How can I correct this?
        Karlheinz
        • GaieusG
          I am afraid you cannot. All the other facets are quads but these are triangles and that probably messes up the map (in SU, there are four texture positioning handle for each face and you cannot merge 2 into a singularity).
          See if Whaat's UV Tools version 2 works for you (it exports then reimports the model into 3rd party apps)
            Jim
            Could you make them quads, then have only a very small, flat circle on top. Instead of a single vertex where the lines converge?
            The image reminds me of Moe's hair from the Three Stooges, btw. 😆
            • GaieusG
              If you download my dome, that's exactly what I did. Maybe it could be even smaller.
              However it stretches the texture this way, too.
                Jim
                I see now - scaling the texture is not quite what you want. My eye was tricked, but the tiles should not actually be scaled as they are.
                • GaieusG
                  Yes, in the meanwhile I edited my previous post, too.
                  Solution - put a cap on the top. 😛
                  Dome.skp
                    Is there a plugin to create a Geodesic Dome.
                    Seems you have someone in the Components menu Shapes or in 3Dware house 😉
                    • GaieusG
                      If you want to know something about geodesic domes, our fellow member Taff Gogh is to search for. This is his 3D Warehouse contribution:
                      http://sketchup.google.com/3dwarehouse/cldetails?mid=1f33552966b6f22224e5217d8a2e013a
                      and his Google Groups for Geodesic Domes:
                      http://groups.google.com/group/geodesichelp
                      But unfortunately, Al, I would doubt that a different shape on the top would help (albeit who knows?) It's where the image itself should also shrink to infinity. So speaking of skies, maybe one with a pure, blue colour on the very top could produce some not noticeable turbulence?
                      • charly2008C
                        charly2008
                        Thanks for all your help. I will try out UVMapper.
                        • Al HartA
                          Al Hart
                          Can you show us a view from the top of the dome with a cap on top.
                          (Or was that a joke?)
                          Thanks,
                          Al
                          Al Hart
                          IRender nXt from Render Plus
                          • Al HartA
                            Al Hart
                            Thanks for your help on this Gai.
                            We need to get Whaat to recognize the triangles at the top, and assign the UV coordinates differently.
                            Alternatively, you could start with a Geodesic Dome which uses the same size for all triangles. Would Whaat's plug-on work for Geodesic Domes?
                            We tried to solve this when we were trying to improve the O3D dome for viewing panoramic images (which has the same problem at the top and bottom), but we weren't able to do it properly.
                            Al Hart
                              driven
                              2004 by Gavin Kistner- Geodesic_SketchUp.rb
                              don't remember where or when I got this, have you tried it?
                                Taffgoch serial domes is amazing 😲 😲 😲
                                His PDF is a true gem! 😎
                                • GaieusG
                                  Al, see the image I attached to that post. There is a yellow "cap" - just hiding the fact that we cannot properly UV Map that part.
                                  Maybe half joke but at the same time, if you can find out something to put there, can be a workaround.
                                    This is as it would be in the 'real-world' - you'd have a special cap-stone or finial, simply because you can't use smaller and smaller tiles or stone to finish it - The builder WILL use a single 'thing'... 💭
                                    • GaieusG
                                      Certainly. Even the rest of the tiles mapped spherically is impossible.
                                      • Al HartA
                                        Al Hart
                                        I see my problem better now.
                                        I don't want a texture mapping which gets smaller and smaller at the top. I want a texture mapping which is uniform over the entire dome - As if you placed an actual carpet on the dome.
                                        To do this properly, I would probably need to make the dome out of hexagons, and have a "hexagon tileable" pattern to place on it.
                                        I'm sure people must to this sometimes, but it is probably more difficult than I think.
                                        http://plus.maths.org/issue8/features/art/orb.jpg
                                        Al Hart
                                          driven
                                          I do this a lot , if that's what you mean
                                            d12dozr
                                            And just HOW do you do that? 😄 I believe that is what he means...
                                            http://goo.gl/f7ooYh
