    Is anything impossible?
    63 Posts 20 Posters 13.8k Views 20 Watching
    • brodieB
      brodie
      It seems to me that there's a difference between "impossible" and "really difficult."
      Organic stuff can be really difficult but technically as long as you can make it from triangles any shape should be possible, with the limitation of an object with an huge amount of polygons.
      I've had some discussions with a friend who uses Rhino. He's come up with some cool shapes and stuff and challenged me, 'I'll bet you can't do THAT in Sketchup.' Typically with a plugin or 2 I'm able to recreate his shape without too much problem. The big secret, though, is that SU tends to fall apart not with the complicated stuff but with the rather mundane. Once I create that shape how easy is it for me to manipulate compared to Rhino? What if he were to ask me something simple like, UV map this sphere (I'm aware of Whaat's plugin here but I don't count it since it stretches the ends and has a lot of limitations, no fault of Whaat's)? Or perhaps, create a simple box...that's .000001m in all directions?
      -Brodie
        driven
        Hi Jeff,
        is this what you mean? being a pool skater from long ago I couldn't resist trying this out.
        Welded Top + Bottom rails then Extrude edges by rail and then follow me for the forward projection.
        Ramp.skp
        • jeff hammondJ
          Nah, not like that. I've used that shape a few times on the past though. (one of which can be seen on the bowl at the following link)
          http://forums.sketchucation.com/viewtopic.php?p=135777
          the main problem with that is the lip ends up being the same angle in the shallow and deep end whereas the drawing I posted earlier in this thread has vert in the deepend and no vert in the shallow. (and I do have a way to use this same technique to counteract that problem but there are other things happening in the 'SU impossible' drawing). I don't have an Internet connection right now (this post is via iPhone) but when I get a connection, I'll upload a skp to better describe the problems.
          (EDIT -- John, a couple of more examples using a similar formula can be seen in the posts starting here:
          http://forums.sketchucation.com/viewtopic.php?p=191711#p191711
          • K
            KXI System
            How about an exact replica of your 3-D self!
            Thats impossible
            Getting the perfect sig is hard...
            Google it!
            • juan974J
              juan974
              hello,
              just like that ?
              acrobat reader 8.0 required
              skate.skp
              juan974 (Réunion island)
              website : http://sketchucation.com/click.php?url=http://www.tarn.us
                Exactly how is this achieved ?
                Exactement comment y parvenir?
                • jeff hammondJ
                  here's a skp to try... good luck
                  datdere.skp
                  • ely862meE
                    ely862me
                    U got served!
                    datdere fixed.skp
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      B U T... how did you do it ??? 😕
                      ExtrudeEdgesByRails2 where you have two pairs of rails [or profiles] which would do this, but it is not [yet] published ?
                      • CarrozzaC
                        Carrozza
                        Ehy, wait! Are you turning SketchUp into a NURBS application? Bad boys! 😉
                        • jeff hammondJ
                          @ely862me said:
                          U got served!
                          I'll say!
                          so yeah, how'd you do it.
                          • ely862meE
                            ely862me
                            First of all make sure u have same numbers of segments on the opposite curves .
                            Second use follow me tool ,let say use it with down curve for shape and right curve for rail.
                            Now begins the pain..select all vertical segments for each row and weld them in a curve,after this move the end point of that curve to the affiliate point of the upper curve.After doing this step explode all curves ..and begin the same operation as previous but this time for the horizontal rows of segments and move the end point to the affiliate points of curve from the left...after lot of patience ..the result is (visually) the best.. not the easiest but the best (i guess)
                            Hope u get it!
                            Elisei
                            • juan974J
                              juan974
                              ely862me says : "First of all make sure u have same numbers of segments on the opposite curves ."
                              or the result of division gives an integer (bigger number of points / smaller number of points) => using extrudeedgebyrails
                              edit : Actualy extrudeegdebyrails doesn t support it ....
                              • ely862meE
                                ely862me
                                Apparently with this kind of shape Chris s loft tool seems to deal the best...can this be developed to work with 3 or 4 set of lines or curves???
                                datdere fixedd.skp
                                • juan974J
                                  juan974
                                  nice job ely862me,
                                  there are several ways to draw this
                                  did you modify the orginal curves ?
                                  i try whitout modify them.
                                  @ Jeff Hammond, you should create you contour by copy, move, rotate and scale, by this way this possible to do it just whit sandbox.datdere.skp
                                  edit : add the curved plane groupeddatdere_curvedplane_grouped.skp
                                    ExtrudeEdgesByRails works on a Profile and one OR two Rails [one Rail option effected by selected same Rail twice].
                                    I am currently looking a version that takes two 'opposite side' Profiles and Rail pairs and uses those - rather like EEbyRails BUT with an second Profile that the first Profile is 'melded' to as it is repeated down the pair of Rails...
                                    EEbyRails does even up the number of edges in the two Rails BUT this is based on a 'common-factor' - so with Rail1 of 6 edges and Rail2 of 12 edges you will get Rail1 re-divided into 12 edges to match Rail2, BUT with 6 and 13 edges there is no common-factor so Rail1 gets 613=78 edges and Rail2 136=78 edges so the Rails' edge-count is equalized - so in that case prior manual adjustments to Rail2 down from 13 to 12 edges would give a much less faceted mesh !
                                    • juan974J
                                      juan974
                                      I think EEbR works like this :
                                      • select a profil then 2 rails
                                      • the 2 rails are divided whit a common number, the number of point of each rail multiply together (a segment is 2 points, 2 consecutive segments are 3 points etc).
                                      • the plugin calculate now the lenght and the orientation of the segment formed by the first points of each rail, then the second points, etc...
                                      • the lenght of this segment give the scale (homogen) of the profil and the orientation give the ... orientation
                                        I will try to mesh more nicely at my own aprecia, i will start from the two bigger curve, then extrude edge by edge (or follow me tool) and scale, rotate each profil and sometimes merge some points :i try to explain in 2d and straight linesthe file
                                        My feeling is that EEbR should be modified to make this work (i think it s basical mathematics) before publishing ExtrudeEdgesbyRails2, because the size of the mesh will exponential and crashing SU.
                                      • charly2008C
                                        charly2008
                                        this is a quick test with Follow Me and Keep.
                                        Organic.skp
                                          EEb makes a little crack (number of segments sides must also be refined before run)
                                          so I take the existant curve and make "convert to segmentor" 19 for up side
                                          profil = left side"
                                          Soap Skin and Bubble works fine but you must adjust the pressure 😄
                                          click for zoom
                                          EEB on the left SSB on the right
                                          EEB face view for mask the crack 😉
                                          • jeff hammondJ
                                            soapskin can't handle it.. it makes horrible kinks/humps/dips and a dirty mesh...
                                            so far, ely's method looks the most promising but i haven't had time to check it for accuracy yet.. visually/on screen however, it looks ok.
                                            • 3 / 4
