    Is anything impossible?
    63 Posts 20 Posters 13.5k Views 20 Watching
    • Chris FullmerC Offline
      What I discovered about Jeff a while ago, and needs to be kept in mind when trying to answer ihs questions:
      He designs professional skateboard ramps in Sketchup and they actually get built using his 3d models as a base for dimensions. 😲
      So solutions that appear to work in Sketchup, often do not really work. Like in Solo's example, it fills the gap nicely, but imagine trying to skate on it. Everything needs to be smooth, no angled transitions, no flat planes alowed.
      Seriously Jeff, I'm amazed at what you are able to do in SU. That it even fits into your skateboard park modeling workflow amazes me.
      I do think that a patch solution might be possible if it could take into account the adjoining surfaces Thom. I guess it has handles that you would pull out and align to the neighbors?
      Good luck to you on this 😄
        Here's my mockup from EEbyRails and Weld, Group, Copy+PasteInPlace etc... I agree that the top of the infilled part is not tangential - it could have been faked up IF the other two Arc shapes were equivalent [as they are BUT as they could be beziers etc which wouldn't work - so it seemed churlish to show that it was possible...].
        We need EEbyRails2 where you choose 4 curves and fill in the mesh...
        TT's bezier patch that's tangential would be very helpful...
          Yea, the idea was that you build surfaces out of quad or tri-patches. For either side of a patch you can add another tri/quad-patch and you keep going like that. Some align tools that would make one patch align to another patch is something I hope to be able to do.
          In 3DSMax, when you have connected patches they start out so the control handles are linked to each other. Rotate one of the handle of one control points affects the other handles for that point - effectively ensuring tangent surfaces. If you use Ctrl when you move the control handles you make that handle act independently from the rest.
          That's the rough outline I'm working after now. Just began on putting some code together. Not sure how long this project will take. There is a possibility that I might make this my first commercial plugin. Will see how after the first prototype - then I should have a better idea of how much work it'd be.
          • brodieB Offline
            brodie
            It seems to me that there's a difference between "impossible" and "really difficult."
            Organic stuff can be really difficult but technically as long as you can make it from triangles any shape should be possible, with the limitation of an object with an huge amount of polygons.
            I've had some discussions with a friend who uses Rhino. He's come up with some cool shapes and stuff and challenged me, 'I'll bet you can't do THAT in Sketchup.' Typically with a plugin or 2 I'm able to recreate his shape without too much problem. The big secret, though, is that SU tends to fall apart not with the complicated stuff but with the rather mundane. Once I create that shape how easy is it for me to manipulate compared to Rhino? What if he were to ask me something simple like, UV map this sphere (I'm aware of Whaat's plugin here but I don't count it since it stretches the ends and has a lot of limitations, no fault of Whaat's)? Or perhaps, create a simple box...that's .000001m in all directions?
            -Brodie
              driven
              Hi Jeff,
              is this what you mean? being a pool skater from long ago I couldn't resist trying this out.
              Welded Top + Bottom rails then Extrude edges by rail and then follow me for the forward projection.
              Ramp.skp
              • jeff hammondJ Offline
                Nah, not like that. I've used that shape a few times on the past though. (one of which can be seen on the bowl at the following link)
                http://forums.sketchucation.com/viewtopic.php?p=135777
                the main problem with that is the lip ends up being the same angle in the shallow and deep end whereas the drawing I posted earlier in this thread has vert in the deepend and no vert in the shallow. (and I do have a way to use this same technique to counteract that problem but there are other things happening in the 'SU impossible' drawing). I don't have an Internet connection right now (this post is via iPhone) but when I get a connection, I'll upload a skp to better describe the problems.
                (EDIT -- John, a couple of more examples using a similar formula can be seen in the posts starting here:
                http://forums.sketchucation.com/viewtopic.php?p=191711#p191711
                  KXI System
                  How about an exact replica of your 3-D self!
                  Thats impossible
                  Getting the perfect sig is hard...
                  Google it!
                  • juan974J Offline
                    juan974
                    hello,
                    just like that ?
                    acrobat reader 8.0 required
                    skate.skp
                    juan974 (Réunion island)
                    website : http://sketchucation.com/click.php?url=http://www.tarn.us
                      Exactly how is this achieved ?
                      Exactement comment y parvenir?
                        here's a skp to try... good luck
                        datdere.skp
                        • ely862meE Offline
                          ely862me
                          U got served!
                          datdere fixed.skp
                          Elisei (sketchupper)
                          Come and See EliseiDesign
                            B U T... how did you do it ??? 😕
                            ExtrudeEdgesByRails2 where you have two pairs of rails [or profiles] which would do this, but it is not [yet] published ?
                            • CarrozzaC Offline
                              Carrozza
                              Ehy, wait! Are you turning SketchUp into a NURBS application? Bad boys! 😉
                                @ely862me said:
                                U got served!
                                I'll say!
                                so yeah, how'd you do it.
                                • ely862meE Offline
                                  ely862me
                                  First of all make sure u have same numbers of segments on the opposite curves .
                                  Second use follow me tool ,let say use it with down curve for shape and right curve for rail.
                                  Now begins the pain..select all vertical segments for each row and weld them in a curve,after this move the end point of that curve to the affiliate point of the upper curve.After doing this step explode all curves ..and begin the same operation as previous but this time for the horizontal rows of segments and move the end point to the affiliate points of curve from the left...after lot of patience ..the result is (visually) the best.. not the easiest but the best (i guess)
                                  Hope u get it!
                                  Elisei
                                  • juan974J Offline
                                    juan974
                                    ely862me says : "First of all make sure u have same numbers of segments on the opposite curves ."
                                    or the result of division gives an integer (bigger number of points / smaller number of points) => using extrudeedgebyrails
                                    edit : Actualy extrudeegdebyrails doesn t support it ....
                                    • ely862meE Offline
                                      ely862me
                                      Apparently with this kind of shape Chris s loft tool seems to deal the best...can this be developed to work with 3 or 4 set of lines or curves???
                                      datdere fixedd.skp
                                      • juan974J Offline
                                        juan974
                                        nice job ely862me,
                                        there are several ways to draw this
                                        did you modify the orginal curves ?
                                        i try whitout modify them.
                                        @ Jeff Hammond, you should create you contour by copy, move, rotate and scale, by this way this possible to do it just whit sandbox.datdere.skp
                                        edit : add the curved plane groupeddatdere_curvedplane_grouped.skp
                                          ExtrudeEdgesByRails works on a Profile and one OR two Rails [one Rail option effected by selected same Rail twice].
                                          I am currently looking a version that takes two 'opposite side' Profiles and Rail pairs and uses those - rather like EEbyRails BUT with an second Profile that the first Profile is 'melded' to as it is repeated down the pair of Rails...
                                          EEbyRails does even up the number of edges in the two Rails BUT this is based on a 'common-factor' - so with Rail1 of 6 edges and Rail2 of 12 edges you will get Rail1 re-divided into 12 edges to match Rail2, BUT with 6 and 13 edges there is no common-factor so Rail1 gets 613=78 edges and Rail2 136=78 edges so the Rails' edge-count is equalized - so in that case prior manual adjustments to Rail2 down from 13 to 12 edges would give a much less faceted mesh !
                                          • juan974J Offline
                                            juan974
                                            I think EEbR works like this :
                                            • select a profil then 2 rails
                                            • the 2 rails are divided whit a common number, the number of point of each rail multiply together (a segment is 2 points, 2 consecutive segments are 3 points etc).
                                            • the plugin calculate now the lenght and the orientation of the segment formed by the first points of each rail, then the second points, etc...
                                            • the lenght of this segment give the scale (homogen) of the profil and the orientation give the ... orientation
                                              I will try to mesh more nicely at my own aprecia, i will start from the two bigger curve, then extrude edge by edge (or follow me tool) and scale, rotate each profil and sometimes merge some points :i try to explain in 2d and straight linesthe file
                                              My feeling is that EEbR should be modified to make this work (i think it s basical mathematics) before publishing ExtrudeEdgesbyRails2, because the size of the mesh will exponential and crashing SU.
                                            • 2 / 4
