    Is anything impossible?
    63 Posts 20 Posters 13.8k Views 20 Watching
      A Bezier Patch is a set of 4x4 control points. From that a series of Bezier curves is generated in the horizontal and vertical direction. Getting adjacent patches to be smooth should be accomplished by making the opposite control-points tangent to each other. (At least in theory if I understand it correctly.) I should be starting on making a prototype soon.
      What I'm also playing around with is Modifier stacks to these patches. So you can add a modifier to extrude (add thickness) to the patches.
        Another plus with the bezier patches is that UV mapping them should be relatively easy, at it's all in regular quad/triangle grids.
        • soloS
          Maybe I'm issing something here but according to the images above, SU's most primative tools can be used, namely 'from contours' in the sandbox toolset.
          I did a quick mock up.
          • jeff hammondJ
            yes, i think so..
            that's what i'm saying about making something look sort of right in sketchup but it being totally wrong in real world dimensions..
            for one pete, your blended surface has two giant flat triangles where as the desired surface has no flat areas at all.
            • GaieusG
              AND it would never be editable.
              • pbacotP
                sorry is that OT? Been enjoying watching you guys outdo yourself.
                • Chris FullmerC
                  What I discovered about Jeff a while ago, and needs to be kept in mind when trying to answer ihs questions:
                  He designs professional skateboard ramps in Sketchup and they actually get built using his 3d models as a base for dimensions. 😲
                  So solutions that appear to work in Sketchup, often do not really work. Like in Solo's example, it fills the gap nicely, but imagine trying to skate on it. Everything needs to be smooth, no angled transitions, no flat planes alowed.
                  Seriously Jeff, I'm amazed at what you are able to do in SU. That it even fits into your skateboard park modeling workflow amazes me.
                  I do think that a patch solution might be possible if it could take into account the adjoining surfaces Thom. I guess it has handles that you would pull out and align to the neighbors?
                  Good luck to you on this πŸ˜„
                    Here's my mockup from EEbyRails and Weld, Group, Copy+PasteInPlace etc... I agree that the top of the infilled part is not tangential - it could have been faked up IF the other two Arc shapes were equivalent [as they are BUT as they could be beziers etc which wouldn't work - so it seemed churlish to show that it was possible...].
                    We need EEbyRails2 where you choose 4 curves and fill in the mesh...
                    TT's bezier patch that's tangential would be very helpful...
                      Yea, the idea was that you build surfaces out of quad or tri-patches. For either side of a patch you can add another tri/quad-patch and you keep going like that. Some align tools that would make one patch align to another patch is something I hope to be able to do.
                      In 3DSMax, when you have connected patches they start out so the control handles are linked to each other. Rotate one of the handle of one control points affects the other handles for that point - effectively ensuring tangent surfaces. If you use Ctrl when you move the control handles you make that handle act independently from the rest.
                      That's the rough outline I'm working after now. Just began on putting some code together. Not sure how long this project will take. There is a possibility that I might make this my first commercial plugin. Will see how after the first prototype - then I should have a better idea of how much work it'd be.
                      • brodieB
                        brodie
                        It seems to me that there's a difference between "impossible" and "really difficult."
                        Organic stuff can be really difficult but technically as long as you can make it from triangles any shape should be possible, with the limitation of an object with an huge amount of polygons.
                        I've had some discussions with a friend who uses Rhino. He's come up with some cool shapes and stuff and challenged me, 'I'll bet you can't do THAT in Sketchup.' Typically with a plugin or 2 I'm able to recreate his shape without too much problem. The big secret, though, is that SU tends to fall apart not with the complicated stuff but with the rather mundane. Once I create that shape how easy is it for me to manipulate compared to Rhino? What if he were to ask me something simple like, UV map this sphere (I'm aware of Whaat's plugin here but I don't count it since it stretches the ends and has a lot of limitations, no fault of Whaat's)? Or perhaps, create a simple box...that's .000001m in all directions?
                        -Brodie
                          driven
                          Hi Jeff,
                          is this what you mean? being a pool skater from long ago I couldn't resist trying this out.
                          Welded Top + Bottom rails then Extrude edges by rail and then follow me for the forward projection.
                          Ramp.skp
                          • jeff hammondJ
                            Nah, not like that. I've used that shape a few times on the past though. (one of which can be seen on the bowl at the following link)
                            http://forums.sketchucation.com/viewtopic.php?p=135777
                            the main problem with that is the lip ends up being the same angle in the shallow and deep end whereas the drawing I posted earlier in this thread has vert in the deepend and no vert in the shallow. (and I do have a way to use this same technique to counteract that problem but there are other things happening in the 'SU impossible' drawing). I don't have an Internet connection right now (this post is via iPhone) but when I get a connection, I'll upload a skp to better describe the problems.
                            (EDIT -- John, a couple of more examples using a similar formula can be seen in the posts starting here:
                            http://forums.sketchucation.com/viewtopic.php?p=191711#p191711
                            • K
                              KXI System
                              How about an exact replica of your 3-D self!
                              Thats impossible
                              Getting the perfect sig is hard...
                              Google it!
                              • juan974J
                                juan974
                                hello,
                                just like that ?
                                acrobat reader 8.0 required
                                skate.skp
                                juan974 (RΓ©union island)
                                website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                  Exactly how is this achieved ?
                                  Exactement comment y parvenir?
                                  • jeff hammondJ
                                    here's a skp to try... good luck
                                    datdere.skp
                                    • ely862meE
                                      ely862me
                                      U got served!
                                      datdere fixed.skp
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                        B U T... how did you do it ??? πŸ˜•
                                        ExtrudeEdgesByRails2 where you have two pairs of rails [or profiles] which would do this, but it is not [yet] published ?
                                        • CarrozzaC
                                          Carrozza
                                          Ehy, wait! Are you turning SketchUp into a NURBS application? Bad boys! πŸ˜‰
                                          • jeff hammondJ
                                            @ely862me said:
                                            U got served!
                                            I'll say!
                                            so yeah, how'd you do it.
                                            • 2 / 4
