    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 348.6k Views 71 Watching
    • CarrozzaC Offline
      Carrozza
      Hi TIG and all, today I spent some quality time trying to achieve the result of this procedure with Extrude Edges by Rails plugin: http://www.youtube.com/watch?v=SUYN_Uqzvec.
      http://img18.imageshack.us/img18/9016/capturew.gif
      Any idea if and how is possible to produce this kind of result?
      Thanks in advance for the plugin and any help.
      • plot-parisP Offline
        plot-paris
        @tig said:
        I'm currently looking at updating several of my extrusion tools and putting them onto a toolbar and giving them web-dialogs were appropriate... so be patient ๐Ÿ‘ฟ ๐Ÿค“ ๐Ÿ˜‰
        wow, sounds exciting. I will be as patient as I can manage ๐ŸŽ‰
        ๐Ÿ˜„
        (@Gaieus**: see, with a Wave I would have been able to place this comment inline, where it belongs, instead of having to quote to make clear which post I am referring to...)**
          As you found vanillas FollowMe isn't going to make a Fillet that touches the Leg and Arm properly...
          Here is away of doing it with careful pre-planning, Groups, Copy/Paste-in-Place, Intersect and EEbyRails etc - however the Fillet that's made is very poly-intensive... BUT it is accurate to suit the facets of the cylinders... depends what you want - for detailed work OK but for massing just leave out the fillets as you'll barely see them! EEbtRailsFilletWeldForm.pngEEbtRailsFilletWeldForm.skp
          • CarrozzaC Offline
            Carrozza
            Hi TIG, thanks for your help. There's a problem with the fillet created this way, though: it doesn't revolve correctly around the "arm". See picture, taken from your kind example: on one side the arc points inward, on the other side points outward.
            http://img704.imageshack.us/img704/942/capturem.gif
              blajnov
              With the plug "Round Corner" by Fredo, you can do the welding seam.
                You are right !
                If you make it in 90 degree bits it's better...
                BUT it should be like that - I'll look at the cause...
                Perhaps the Fredo Rounded Option is the best ... see below ...
                Blajnov - exactly did you do that I can't reproduce it ??? ๐Ÿ˜•
                  d12dozr
                  Top segment of horizontal pipe has to line up with a segment on the vertical pipe...look closely at his hidden geometry ๐Ÿค“
                  http://goo.gl/f7ooYh
                  • CarrozzaC Offline
                    Carrozza
                    Mamma mia, this is a great learning experience!
                    Thank you very much Blajinov and TIG for your help, is much appreciated! โ˜€
                      blajnov
                      I enclose a file with scenes of action
                        I see now... โ˜€
                        So to recap: DON'T use EEbyRails for making Fillets between Rounded Legs and Arms etc - instead USE Fredo's 'Round Corners' - it's quicker and produces better results !
                        Blajnov - it might be best if you edit / retitled your SKP without reference to EEbyR, to avoid confusion ๐Ÿ˜„
                          Here's a way to make a Multi-Railed Mesh with EEbyRails by making sub-meshes and combining them...EEbyRailsMultiRailSteps.pngEEbyRailsMultiRailSteps.skp
                            Rip Tanion
                            Awesome plugin! Thanks!
                            Three attached curvesround_corner.pnground_corner.skp
                              I don't understand you diagram.
                              You can already do this ?
                              Are you wanting some sort of 2-face FollowMe ? Just use the faces edges [welded into a curve] as your Rails ?
                              With EEbyRv2 [that is about to be launched] you will be able to choose the Profile, Rail1 and Rail2 and then a 'Melding-Profile' that fixes the end form too - is that what you want ? It will allow a definite start and end profile location form to be predefined...
                              โ“
                              • H Offline
                                hsjzyangbin
                                Hi,TIG,I have a idea that <extrude edges by rails> adds a path like this,thanks
                                next:I wish it could be add rotate and scale function
                                • H Offline
                                  hsjzyangbin
                                  โ“
                                  Yes,it could be "2-face +2-path+FollowMe" ๐Ÿ˜
                                  I also do not have this plug-in, I use the LATHE. RB command generates images shown, as you said, the first path to the same, choose the second Rails as a control Rails
                                  "lathe" you can see it http://www.sketchupbbs.com/thread-40382-1-1.html
                                  • charly2008C Offline
                                    charly2008
                                      โ“
                                      I too have a lathe.rb that is somewhat similar...
                                      • H Offline
                                        hsjzyangbin
                                        ๅธŒๆœ›ๆˆ‘็š„ๆ่ฎฎๅฏนไฝ ็š„ๆ’ไปถๆœ‰็”จ๏ผŒ่ฐข่ฐข๏ผ
                                          Your proposal for my plug-in very useful, thank you!
                                          • david_hD Offline
                                            david_h
                                            very fun indeed. Is there a toolbar? I get the command in my Plugins Tab, but Is there an onscreen toolbar as well?
                                            • 19
                                            • 20
                                            • 3 / 20
