    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.3k Views 30 Watching
    • Al HartA Offline
      Al Hart
      @escapeartist said:
      Or am I missing completely what you are trying to get at? Are you trying to achieve a similar effect, without applying self illumination of this type?
      I think what you showed in your rendering is just what I am talking about. The ability to make something look illuminated, without using or adding any actual light sources to the scene.
      New light options including projector lights and manual inputs of light intensities for self luminating sources.
      I presume that in the image you showed, we see a reflection of the lit iPhone, but it is not actually a light source??
      Al Hart
      IRender nXt from Render Plus
      • jeff hammondJ Offline
        @al hart said:
        i dunno, when my iphone is off, it's just a black screen.
        Oops - I guess U need to buy one.
        But - does it have a lit and non-lit mode?
        no, it's just like a standard computer monitor.. on or off and that's it
        http://obsdesign.freznell.com/wp-content/uploads/2008/11/iphone-off.jpg
        • olisheaO Offline
          olishea
          al: nobody said you cant make it an emitter.....there are many ways of doing this but its the most realistic way of achieving the result. you cant really make something look illuminated without showing its effect on neighbouring surfaces/particles (air/dust etc). correct me if i'm wrong. you are basically trying to make a texture look brighter which isn't convincing.
          why are you trying to avoid putting lights behind it? this is largely how screens are illuminated in real life. like a large emitter......again correct me if im wrong...but saturating and brightening a texture wont make it look illuminated.
          oli
          • EscapeArtistE Offline
            EscapeArtist
            The texture itself is the source of light, there are no other lights whatsoever in the scene. The reflection on the surface below the screen is actually reflected light off of the ground plane. Kerkthea will create light based on the color of the image used - black, no light; green, green light, etc... Kerkythea does not do "light linking" (yet), where light can be shone on one object of the scene to make it brighter but not affect any other objects. Other render engines can do this though.
            One could put lights behind a texture, but I couldn't imagine the difficulty of getting nice, even light out of a large surface by arranging light sources behind it. It would be more involved setup in the render engine as well, you'd have to do something like a multi-layered texture with transparency mapping and translucency set up for the colors.
            Another example, this time the blacks are not completely black so they do emit some light. A quick "plasma TV".
            • U Offline
              Ultimatez 32
              twilight easy 09, 24 minutes
              planning to buy the real version soon
              Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
              • W Offline
                weizxwilliam
                Mine first try ;D
                  richcat
                  Just got a few minutes - eventually - to give this challenge a go.
                  • 2 Offline
                    21D
                    My quick try,
                    exported to MODO 401 for rendering
                    Modo Rendered
                    "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                    Le Corbusier
                    • boofredlayB Offline
                      boofredlay
                      Ha Ha. Great render Rob. 👍
                        dspace
                        Just join, so just post....a quickie for the shine..but not the emitter..oops! 😉
                          robmoors
                          Iphone sucks Android rules!!
                          SUCK IT!!!!
                          http://img.photobucket.com/albums/v244/Blaze_X/HTC Hero/HTCHero-1.jpg
                          Vray for Sketchup
                          Model by me
                          HTC Hero
                          Rob Moors
                          Architecture Student
                          • Large_BlackL Offline
                            Large_Black
                            Hi to everyone, i would like to share my attempt.
                            Rendered with Vray for SU, SU lines overlay, some level, color correction and DOF in PP.
                            No light, only the emissive material of the phone.
                            Sincerly Enrico
                            http://img163.imageshack.us/img163/605/91784613.th.jpg
                            • W Offline
                              wahoowetzel
                              quick question with the LCD screens. I'm working on a LCD TV and I wanted to know if there is a way to in/decrease the amount light the image (screen material) emits without affecting the actual image's appearance. What I'm getting right now is a decent light level being emitted but the image is getting washed out. Any ideas?
                                d12dozr
                                What render app are you using?
                                http://goo.gl/f7ooYh
                                • Al HartA Offline
                                  Al Hart
                                  One trick you could try is to place an invisible, second face in front of the visible face. Make the second face the light - diffuse so the light only goes up - and then adjust the intensity of the invisible face get the lighting effect you want, without having it effect the illumination of the visible face.
                                  If you are using IRender nXt, you would illuminate the visible face with "self glow", - a setting which make it seem illuminated without emitting illumination, and make the invisible face a diffuse light. By placing the two faces in separate lighting channels, then you can use the post-processing image editor to quickly adjust the lighting intensities and effects of the two faces without having to re-render ay of the scene.
                                  Al Hart
                                  • N Offline
                                    nomeradona
                                    Keyshots.. real time about 2 minutes
                                    http://i334.photobucket.com/albums/m421/nomeradona_1234/Iphone_keyshots.jpg
                                    • N Offline
                                      nomeradona
                                      some parodies
                                      Iphone captains speaking...
                                      http://i334.photobucket.com/albums/m421/nomeradona_1234/iphone30.jpg
                                      "all man will have"... the main goal of mr.mac
                                      http://i334.photobucket.com/albums/m421/nomeradona_1234/iphone27.jpg
                                      • pyrolunaP Offline
                                        pyroluna
                                        Hey everyone
                                        I'm still sort of new here but hey this is fun. I notice people seem to have the same ideas... just a little while back I modeled an i-phone so I could test light-emitting materials in v-ray for SU. So I'll just post the renders...
                                        This one is lighted with an interior hdri... maybe the result's a little too darkThis one is lighted with a sun system... so the screen brightness is way too low... just as it would be in real life on a very sunny day...
                                        And this is the sketchup file. Enjoy! I took the measurements from my own i-phone, and scaled everything by a factor 10. Though I didn't put in all the details...
                                        • W Offline
                                          wahoowetzel
                                          Thanks Al,
                                          I'm using the new Vray for Sketchup but I think I might be able to adapt some of your method to accomplish what I'm after.
                                          • marked001M Offline
                                            marked001
                                            here's an old,noisy Maxwell rendering..
                                            *edit... reading is fundamental.. LCD screen...whoops, sorry.
                                            http://img166.imageshack.us/img166/3710/tv1by9.jpg
                                            http://www.revision21vis.com
                                            instagram: revi21on
                                            • 3 / 3
