    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.3k Views 30 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Not sure what the distinction is that you are trying to make. In Kerkythea, the texture can be applied to the radiance (edit material > self illumination > and select bitmap and use the screen texture) function and the texture becomes "self illuminating", it is not a backlit texture.
      Here is a completely dark scene with only the screen applied to one surface, self illuminated:
      Or am I missing completely what you are trying to get at? Are you trying to achieve a similar effect, without applying self illumination of this type?
      • Al HartA Offline
        Al Hart
        i dunno, when my iphone is off, it's just a black screen.
        Oops - I guess U need to buy one.
        But - does it have a lit and non-lit mode?
        Al Hart
        IRender nXt from Render Plus
        • Al HartA Offline
          Al Hart
          I think what you showed in your rendering is just what I am talking about. The ability to make something look illuminated, without using or adding any actual light sources to the scene.
          New light options including projector lights and manual inputs of light intensities for self luminating sources.
          I presume that in the image you showed, we see a reflection of the lit iPhone, but it is not actually a light source??
          Al Hart
          • jeff hammondJ Offline
            no, it's just like a standard computer monitor.. on or off and that's it
            http://obsdesign.freznell.com/wp-content/uploads/2008/11/iphone-off.jpg
            • olisheaO Offline
              olishea
              al: nobody said you cant make it an emitter.....there are many ways of doing this but its the most realistic way of achieving the result. you cant really make something look illuminated without showing its effect on neighbouring surfaces/particles (air/dust etc). correct me if i'm wrong. you are basically trying to make a texture look brighter which isn't convincing.
              why are you trying to avoid putting lights behind it? this is largely how screens are illuminated in real life. like a large emitter......again correct me if im wrong...but saturating and brightening a texture wont make it look illuminated.
              oli
                EscapeArtist
                The texture itself is the source of light, there are no other lights whatsoever in the scene. The reflection on the surface below the screen is actually reflected light off of the ground plane. Kerkthea will create light based on the color of the image used - black, no light; green, green light, etc... Kerkythea does not do "light linking" (yet), where light can be shone on one object of the scene to make it brighter but not affect any other objects. Other render engines can do this though.
                One could put lights behind a texture, but I couldn't imagine the difficulty of getting nice, even light out of a large surface by arranging light sources behind it. It would be more involved setup in the render engine as well, you'd have to do something like a multi-layered texture with transparency mapping and translucency set up for the colors.
                Another example, this time the blacks are not completely black so they do emit some light. A quick "plasma TV".
                • U Offline
                  Ultimatez 32
                  twilight easy 09, 24 minutes
                  planning to buy the real version soon
                  Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                  • W Offline
                    weizxwilliam
                    Mine first try ;D
                      richcat
                      Just got a few minutes - eventually - to give this challenge a go.
                      • 2 Offline
                        21D
                        My quick try,
                        exported to MODO 401 for rendering
                        Modo Rendered
                        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                        Le Corbusier
                        • boofredlayB Offline
                          boofredlay
                          Ha Ha. Great render Rob. 👍
                            dspace
                            Just join, so just post....a quickie for the shine..but not the emitter..oops! 😉
                              robmoors
                              Iphone sucks Android rules!!
                              SUCK IT!!!!
                              http://img.photobucket.com/albums/v244/Blaze_X/HTC Hero/HTCHero-1.jpg
                              Vray for Sketchup
                              Model by me
                              HTC Hero
                              Rob Moors
                              Architecture Student
                              • Large_BlackL Offline
                                Large_Black
                                Hi to everyone, i would like to share my attempt.
                                Rendered with Vray for SU, SU lines overlay, some level, color correction and DOF in PP.
                                No light, only the emissive material of the phone.
                                Sincerly Enrico
                                http://img163.imageshack.us/img163/605/91784613.th.jpg
                                • W Offline
                                  wahoowetzel
                                  quick question with the LCD screens. I'm working on a LCD TV and I wanted to know if there is a way to in/decrease the amount light the image (screen material) emits without affecting the actual image's appearance. What I'm getting right now is a decent light level being emitted but the image is getting washed out. Any ideas?
                                    d12dozr
                                    What render app are you using?
                                    http://goo.gl/f7ooYh
                                    • Al HartA Offline
                                      Al Hart
                                      One trick you could try is to place an invisible, second face in front of the visible face. Make the second face the light - diffuse so the light only goes up - and then adjust the intensity of the invisible face get the lighting effect you want, without having it effect the illumination of the visible face.
                                      If you are using IRender nXt, you would illuminate the visible face with "self glow", - a setting which make it seem illuminated without emitting illumination, and make the invisible face a diffuse light. By placing the two faces in separate lighting channels, then you can use the post-processing image editor to quickly adjust the lighting intensities and effects of the two faces without having to re-render ay of the scene.
                                      Al Hart
                                      • N Offline
                                        nomeradona
                                        Keyshots.. real time about 2 minutes
                                        http://i334.photobucket.com/albums/m421/nomeradona_1234/Iphone_keyshots.jpg
                                        • N Offline
                                          nomeradona
                                          some parodies
                                          Iphone captains speaking...
                                          http://i334.photobucket.com/albums/m421/nomeradona_1234/iphone30.jpg
                                          "all man will have"... the main goal of mr.mac
                                          http://i334.photobucket.com/albums/m421/nomeradona_1234/iphone27.jpg
                                          • pyrolunaP Offline
                                            pyroluna
                                            Hey everyone
                                            I'm still sort of new here but hey this is fun. I notice people seem to have the same ideas... just a little while back I modeled an i-phone so I could test light-emitting materials in v-ray for SU. So I'll just post the renders...
                                            This one is lighted with an interior hdri... maybe the result's a little too darkThis one is lighted with a sun system... so the screen brightness is way too low... just as it would be in real life on a very sunny day...
                                            And this is the sketchup file. Enjoy! I took the measurements from my own i-phone, and scaled everything by a factor 10. Though I didn't put in all the details...
                                            • 3 / 3
