[Plugin] Round Edge - v1.0 (by Bezier)
Daniel,
If you don't mind, I will make them the primary icons, because mine were really ugly.Of course you can, and thanks again for working in this plugin.
@craigslist.men said:
is there any way i can round the edge only bit like a 1/16 or even less?
A workaround is to scale the model. For example with my units you canΒ΄t round less than 0,5 cm. So if you need to round 0,4 cm you can scale up the model 10 times and round 4 cm. Then you scale down (0,1) and you have the rounded edges in 0,4 cm.
If you need less you can scale 100 times larger or even more, and scale down when done.Daniel S
oooh, I am so looking forward to this new version! I guess there is a whole community eagerly awaiting your next breakthrough.
so no pressure there, fredo -
We also want to Chime in and agree that a professional grade tool for bullnosing and filletting is much needed.
Team SDA
Many thanks Fredo for your elegant plugin.
As a new user to all this, it has worked like a dream! Very useful and easy to incorporate into sketchup...thanks too to the icon-maker! Looks good!
Go Fredo Go!!!
Thank +++
Thanks, Fredo, for your brilliant plugin!
unfortunatly the model I needed to use it on includes instances where concave meets convex.
Obviously this is a problem Any headway on solving this issue?
Thanks again -
Jebimasta,
Then you should look at a more recent plugin, RoundCorner 2.0
Download, doc and video is at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721Fredo
Cool Fredo!
Thank you!
thanks friend. cool plugin. XD
hello
dose it work on os x? -
@darkme said:
does it work on os x?
Probably, but you should consider the more rcenet version RoundCorner that handles 'real' round edges.
See http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin#p171721Fredo
Fredo: do we need these old versions around? I see several times people refering to these older versions without being aware of the newer ones. Can't we just shut them down and direct to the latest?
Tom,
We could remove previous versions in the general case. However, for RoundEdges by Bezier, the situation is a little bit differenet. It is not the same script as RoundCorner, and it does perform better the sharp junction with numerous edges (more than 5). Anyway, I already put a redirection to RoundCorner in the top message.
were i can find the download???
this one, top of page one, at the end of Fredo's 1st entry, most people leave the latest versions in that spot on the plugin page.
Thanks Fredo Thanks!!!
Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself.
Are you referring to RoundEdge or to RoundCorner?
Do you have a model on which you get this systematic crash?Thanks
Dear Fredo, the issue with Round Edges by Bezier. Attached is a SU7 file where the crash occurs. I'm unable to load this file because extension skb not allowed. I'm happy to email it to you.
