    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
    • CarrozzaC
      Carrozza
      Go Fredo Go!!!
      • N
        NawaGK
        Thank +++
          Jebimasta
          Thanks, Fredo, for your brilliant plugin!
          unfortunatly the model I needed to use it on includes instances where concave meets convex.
          Obviously this is a problem πŸ˜› Any headway on solving this issue?
          Thanks again πŸ˜„
          • fredo6F
            Jebimasta,
            Then you should look at a more recent plugin, RoundCorner 2.0
            Download, doc and video is at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
            • N
              novice
              Cool Fredo!
              Thank you!
              • B
                burgerlord
                thanks friend. cool plugin. XD
                nature sings in the ears of the world.. be GREEN!
                  darkme
                  hello
                  dose it work on os x?
                  • fredo6F
                    @darkme said:
                    does it work on os x?
                    Probably, but you should consider the more rcenet version RoundCorner that handles 'real' round edges.
                    See http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin#p171721
                      Fredo: do we need these old versions around? I see several times people refering to these older versions without being aware of the newer ones. Can't we just shut them down and direct to the latest?
                      • fredo6F
                        Tom,
                        We could remove previous versions in the general case. However, for RoundEdges by Bezier, the situation is a little bit differenet. It is not the same script as RoundCorner, and it does perform better the sharp junction with numerous edges (more than 5). Anyway, I already put a redirection to RoundCorner in the top message.
                        • mike60M
                          mike60
                          were i can find the download???
                          Michael
                            driven
                            this one, top of page one, at the end of Fredo's 1st entry, most people leave the latest versions in that spot on the plugin page.
                            • B
                              balloon
                              Thanks Fredo Thanks!!!
                              • 0
                                09qt
                                Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself.
                                πŸ˜•
                                • fredo6F
                                  @09qt said:
                                  Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself. πŸ˜•
                                  Are you referring to RoundEdge or to RoundCorner?
                                  Do you have a model on which you get this systematic crash?
                                  • 0
                                    09qt
                                    Dear Fredo, the issue with Round Edges by Bezier. Attached is a SU7 file where the crash occurs. I'm unable to load this file because extension skb not allowed. I'm happy to email it to you.
                                      Rename it .skp and it'll upload OR 'zip' it... πŸ’­
                                        Or why not upload the .skp instead?
                                        • 0
                                          09qt
                                          Okay. Ta.100 inch cube sample Or watch thisQuicktime Movie ➑
                                            Jim
                                            Should this plugin be marked as 'obsolete', or maybe 'deprecated' in favor if this one:
                                            404 Not Found
                                            (forums.sketchucation.com)
                                            • 8 / 9
