    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 172.9k Views 83 Watching
    • plot-parisP Offline
      plot-paris
      oooh, I am so looking forward to this new version! I guess there is a whole community eagerly awaiting your next breakthrough.
      so no pressure there, fredo πŸ˜„
        TeamSDA
        We also want to Chime in and agree that a professional grade tool for bullnosing and filletting is much needed.
        Team SDA
          magpie
          Many thanks Fredo for your elegant plugin.
          As a new user to all this, it has worked like a dream! Very useful and easy to incorporate into sketchup...thanks too to the icon-maker! Looks good!
          • CarrozzaC Offline
            Carrozza
            Go Fredo Go!!!
            • N Offline
              NawaGK
              Thank +++
                Jebimasta
                Thanks, Fredo, for your brilliant plugin!
                unfortunatly the model I needed to use it on includes instances where concave meets convex.
                Obviously this is a problem πŸ˜› Any headway on solving this issue?
                Thanks again πŸ˜„
                • fredo6F Offline
                  Jebimasta,
                  Then you should look at a more recent plugin, RoundCorner 2.0
                  Download, doc and video is at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
                  • N Offline
                    novice
                    Cool Fredo!
                    Thank you!
                      burgerlord
                      thanks friend. cool plugin. XD
                      nature sings in the ears of the world.. be GREEN!
                        darkme
                        hello
                        dose it work on os x?
                        • fredo6F Offline
                          @darkme said:
                          does it work on os x?
                          Probably, but you should consider the more rcenet version RoundCorner that handles 'real' round edges.
                          See http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin#p171721
                            Fredo: do we need these old versions around? I see several times people refering to these older versions without being aware of the newer ones. Can't we just shut them down and direct to the latest?
                            • fredo6F Offline
                              Tom,
                              We could remove previous versions in the general case. However, for RoundEdges by Bezier, the situation is a little bit differenet. It is not the same script as RoundCorner, and it does perform better the sharp junction with numerous edges (more than 5). Anyway, I already put a redirection to RoundCorner in the top message.
                              • mike60M Offline
                                mike60
                                were i can find the download???
                                Michael
                                  driven
                                  this one, top of page one, at the end of Fredo's 1st entry, most people leave the latest versions in that spot on the plugin page.
                                    balloon
                                    Thanks Fredo Thanks!!!
                                    • 0 Offline
                                      09qt
                                      Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself.
                                      πŸ˜•
                                      • fredo6F Offline
                                        @09qt said:
                                        Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself. πŸ˜•
                                        Are you referring to RoundEdge or to RoundCorner?
                                        Do you have a model on which you get this systematic crash?
                                        • 0 Offline
                                          09qt
                                          Dear Fredo, the issue with Round Edges by Bezier. Attached is a SU7 file where the crash occurs. I'm unable to load this file because extension skb not allowed. I'm happy to email it to you.
                                            Rename it .skp and it'll upload OR 'zip' it... πŸ’­
                                            • 8 / 9
