    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
      Daniel S
      Daniel,
      If you don't mind, I will make them the primary icons, because mine were really ugly.
      Of course you can, and thanks again for working in this plugin.
      @craigslist.men said:
      is there any way i can round the edge only bit like a 1/16 or even less?
      A workaround is to scale the model. For example with my units you canΒ΄t round less than 0,5 cm. So if you need to round 0,4 cm you can scale up the model 10 times and round 4 cm. Then you scale down (0,1) and you have the rounded edges in 0,4 cm.
      If you need less you can scale 100 times larger or even more, and scale down when done.
      Daniel S
      • plot-parisP
        plot-paris
        oooh, I am so looking forward to this new version! I guess there is a whole community eagerly awaiting your next breakthrough.
        so no pressure there, fredo πŸ˜„
        • T
          TeamSDA
          We also want to Chime in and agree that a professional grade tool for bullnosing and filletting is much needed.
          Team SDA
            magpie
            Many thanks Fredo for your elegant plugin.
            As a new user to all this, it has worked like a dream! Very useful and easy to incorporate into sketchup...thanks too to the icon-maker! Looks good!
            • CarrozzaC
              Carrozza
              Go Fredo Go!!!
              • N
                NawaGK
                Thank +++
                  Jebimasta
                  Thanks, Fredo, for your brilliant plugin!
                  unfortunatly the model I needed to use it on includes instances where concave meets convex.
                  Obviously this is a problem πŸ˜› Any headway on solving this issue?
                  Thanks again πŸ˜„
                  • fredo6F
                    Jebimasta,
                    Then you should look at a more recent plugin, RoundCorner 2.0
                    Download, doc and video is at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
                    • N
                      novice
                      Cool Fredo!
                      Thank you!
                      • B
                        burgerlord
                        thanks friend. cool plugin. XD
                        nature sings in the ears of the world.. be GREEN!
                          darkme
                          hello
                          dose it work on os x?
                          • fredo6F
                            @darkme said:
                            does it work on os x?
                            Probably, but you should consider the more rcenet version RoundCorner that handles 'real' round edges.
                            See http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin#p171721
                              Fredo: do we need these old versions around? I see several times people refering to these older versions without being aware of the newer ones. Can't we just shut them down and direct to the latest?
                              • fredo6F
                                Tom,
                                We could remove previous versions in the general case. However, for RoundEdges by Bezier, the situation is a little bit differenet. It is not the same script as RoundCorner, and it does perform better the sharp junction with numerous edges (more than 5). Anyway, I already put a redirection to RoundCorner in the top message.
                                • mike60M
                                  mike60
                                  were i can find the download???
                                  Michael
                                    driven
                                    this one, top of page one, at the end of Fredo's 1st entry, most people leave the latest versions in that spot on the plugin page.
                                    • B
                                      balloon
                                      Thanks Fredo Thanks!!!
                                      • 0
                                        09qt
                                        Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself.
                                        πŸ˜•
                                        • fredo6F
                                          @09qt said:
                                          Hi, I get bugsplat with SU7 when trying to get this round edge by bezier to work. I tried a 100in cube test and still a splat. Would it be like the issue with round corners. Is anyone else having issue with SU7? Love your work. Just would like to see it work for myself. πŸ˜•
                                          Are you referring to RoundEdge or to RoundCorner?
                                          Do you have a model on which you get this systematic crash?
                                          • 0
                                            09qt
                                            Dear Fredo, the issue with Round Edges by Bezier. Attached is a SU7 file where the crash occurs. I'm unable to load this file because extension skb not allowed. I'm happy to email it to you.
                                            • 8 / 9
