    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 182.8k Views 75 Watching
    • N Offline
      Nexus009
      Hi TIG! an extern file to language and a toolbar of Roof??? for next release??? 😄
      TAAAAAANKS!!!! 😉 💚 👍
      Il mio Teschio è una Bandiera che vuol dire Libertà
        GhossbGood
        HOHOHO....I'l try this
        & Thank's a lot 👍 👍 👍
          juanjo06
          muchas gracias TIGger 👍
          • PatrickDP Offline
            PatrickD
            Hi TIG
            I am a relatively new SU user (now addicted!)
            I have just used your roof tool for the first time and think it's brilliant. Thank you for sharing such a fabulous resource.
            A Merry Christmas to you also.
            Regards
            PatrickD
            • E Offline
              ELYSIUM
              Tks Tig!!
              • E Offline
                ELYSIUM
                I made a quick test and it worked fine, but i tried to make a roof on a volume with a courtyard, and the script didn't recognized the void. It only worked when i when i made it in to a U type plan. Is it possible to change it in a way that it recognizes holes in the geometry of the plan??
                tks again for this wonderful script!
                • E Offline
                  ELYSIUM
                  roger! tks for the help! 😄
                    Making holes in the plan makes Roof.rb just too complex (than it already is !). Your solution of splitting the 'doughnut' is the best way round it. You should split the base-face twice at a central spot (gap a little wider than twice the roof overhang) - then the resulting roof shape is easily editable to 'heal' it. Once the roof is made then open the roof's Group for editing and start to heal the two hips that are temporarily made at the 'split'.
                    Use the Move tool - pick on one of the un-needed 'cross' fascias and move it to snap onto the other un-needed one, then pick a top vertex on one of the un-needed hips and move it across onto the other un-needed hip's equivalent vertex to heal the 2 roof faces. The vertices should snap together and leave the roof planes coplanar but with unwanted splitting lines (you erase these next).
                    Now you need to heal the bits of soffit etc and get rid of unwanted bits of the roof inside where you have joined these two temporary 'ends' together. It's easiest to do this if you set the Component/Group edit-mode to hide everything else during editing. That way you can simple look at the roof volume from below (its 'ceiling' is left open and any other walls etc below it will be temporarily hidden): then you can add 4 extra Lines to split the unwanted bits of 'cross' soffits off, then Erase the unwanted Edges splitting the 2 healed roof plane, the 2 unwanted 'internal' fascia's horizontal edges and the 2 long-side fascias unwanted vertical splitting Edges; finally Erase the 3 Edges of the 2 unwanted 'cross' pieces of 'internal' soffit to tidy up. Exit the Group edit and it should now look as desired, with its central hole...
                    It's actually much quicker to do all of this than it is to write it down !!!
                      Here's RoofHelp.doc (zipped) covering v3.0 - Unzip it and put it in the Plugins folder...
                      The .mht and .pdf formats will have to wait until the new year - the laptop I'm having to use over the holidays can't access the big-upload server...
                      RoofHelp.zip
                        How does your plugin work? In general concept? Intersecting planes?
                          The hipped roof one works by doing a followme around the face loop on a large roof-pitch triangle and intersecting everything with itself, then it erases any geometry that's not needed [the tricky bit], orients faces, applies materials etc. It will fail if the shape can't have a single pitch roof over it... possible with cranked star shapes or re-entrant curved sections where the valleys would diverge up the roof. My recent tutorial shows how to replicate it manually and heal the problem areas manually by redrawing the bits that need another pitch...
                            Ravage
                            Thanks, TIG for this very useful script
                            Marry Christmas and a very Happy New Year!
                              DJMX1
                              Superb plugin. However, why not create toolbar and how can I do to translate it into French?
                              I can create the icons if you want 🎉
                                This is one of my rare encrypted plugins so translation is not easy/possible - I recently had a PM about an ES version...
                                A toolbar would be good - easy to do [after decryption] - as would better web-dialog interface...
                                Unfortunately 'Roof' is quite near the bottom of the list... 😞
                                But... good things come to those who wait ☀
                                  sketchdown
                                  @tig said:
                                  This is v3.0 of my 'Roof' script.
                                  It now incorporates options for sloping fascias and soffits.
                                  The help stuff has also been redone.
                                  This Roof.rb file replaces the older one in the Plugins folder.
                                  The RoofHelp.doc (zipped) file and some alternative larger 'help' file formats (mht and pdf) in separate threads - they are too big for one go...
                                  Feedback please...
                                  Merry Christams to one and all...
                                  how can I dwnload the plugin?
                                    From the link in the box saying "Attachments" right under the text you quoted.
                                    • utilerU Offline
                                      utiler
                                      Hi TIG and others,
                                      Just a few observations and possibly a feature to add.
                                      1. The eaves fascia size offer users to set thickness of the roof however the result is a thickness measured vertically. [see attached]. Considering roof systems consist of known thickness, would it be possible to change [or add a feature] to offer the input of actual roof thickness?
                                      2. Also, as with the gable roof function, is it possible to add a skillion [single pitch] roof option?
                                        I would expect it to operate similar the the gable function; pick gable side first the single pitch side and execute.....
                                      Just Curious...
                                        ar_max
                                        thank you 😄
                                          @utiler said:
                                          Hi TIG and others,
                                          Sorry to be so tardy in my reply 😒
                                          Most users will have a fascia height [vertical] in mind - although the roof structure [timbers] are a given thickness [though this will vary if it's been 'regularized' too], the fascia has to 'mask' the soffit material and also take into account the tiling laths and so on to kick up the bottom tile correctly. Also you might use differing depth timbers in differing areas BUT want a constant fascia to be seen.
                                          If is not that difficult to sit down before jumping in and work out the likely fascia height from a guess of the roof's build up. You are usually using SUp to make a sketch model - if you were making it physically from card or drawing it with a pencil you'd think to yourself 'I want a 200mm deep fascia' and make/draw it at about that - an initial design should be about proportion and scale not real life wood sizes... If later on the detailed design comes up with 175mm timbers and a 65mm roof build up and a 15mm soffit it's not miles off and can be adjusted to suit ???
                                          If you know the final build-ups then doing a quick bit of trig just the once will give the fascia's vertical height -
                                          FasciaHeight = TotalRoofThickness **/** cos(RoofAngleInDegrees)
                                          If you work in A:B pitch format then it's -
                                          FasciaHeight = TotalRoofThickness ***** (SquareRoot**(**(A*A)+(B*B)**)**) **/** B
                                          A 'mono-pitched' roof is so easy to make in SUp that I didn't add it... use the protractor tool to set pitch, guide-lines to offset, draw the profile and make the form including the top/bottom overhangs, and with pushpull as needed, including any verge overhangs - color to suit ?
                                          I've no plans to do any work on **Roof** for a while as there are many things in front of it in the queue 😢
                                          • utilerU Offline
                                            utiler
                                            Thanks TIG, can see you have been busy..... 👍
                                            Trig' is what I currently apply to work-out the roof profile vertically; or just set a fascia depth that is close. I just thought if it was a simple addition [obviously I don't speak the language] it would be a great alternative.....
                                            No problem, I can live with it. Keep up your great work!
                                            Just Curious...
                                            • 1 / 9
