    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 203.0k Views 75 Watching
      Dan
      Thanks, TIG for this very useful script (and for all the other free scripts you shared with us)!
      Marry Christmas and a very Happy New Year!
      • KrisidiousK
        Krisidious
        awesome Tig... now that's a Christmas present.
        By: Kristoff Rand
        • JClementsJ
          JClements
          My thanks, also.
          'tis the season for sharing.
          All you skills and contributions are appreciated.
          • B
            bellwells
            Whew.....you are something else, TIG!! Tireless, selfless, competent, sharing....the list goes on.
            Merrrrrry Christmas and Happy New Year to all.
            Ron
            • N
              Nexus009
              Hi TIG! an extern file to language and a toolbar of Roof??? for next release??? 😄
              TAAAAAANKS!!!! 😉 💚 👍
              Il mio Teschio è una Bandiera che vuol dire Libertà
              • G
                GhossbGood
                HOHOHO....I'l try this
                & Thank's a lot 👍 👍 👍
                  juanjo06
                  muchas gracias TIGger 👍
                  • PatrickDP
                    PatrickD
                    Hi TIG
                    I am a relatively new SU user (now addicted!)
                    I have just used your roof tool for the first time and think it's brilliant. Thank you for sharing such a fabulous resource.
                    A Merry Christmas to you also.
                    Regards
                    PatrickD
                    • E
                      ELYSIUM
                      Tks Tig!!
                      • E
                        ELYSIUM
                        I made a quick test and it worked fine, but i tried to make a roof on a volume with a courtyard, and the script didn't recognized the void. It only worked when i when i made it in to a U type plan. Is it possible to change it in a way that it recognizes holes in the geometry of the plan??
                        tks again for this wonderful script!
                        • E
                          ELYSIUM
                          roger! tks for the help! 😄
                            Making holes in the plan makes Roof.rb just too complex (than it already is !). Your solution of splitting the 'doughnut' is the best way round it. You should split the base-face twice at a central spot (gap a little wider than twice the roof overhang) - then the resulting roof shape is easily editable to 'heal' it. Once the roof is made then open the roof's Group for editing and start to heal the two hips that are temporarily made at the 'split'.
                            Use the Move tool - pick on one of the un-needed 'cross' fascias and move it to snap onto the other un-needed one, then pick a top vertex on one of the un-needed hips and move it across onto the other un-needed hip's equivalent vertex to heal the 2 roof faces. The vertices should snap together and leave the roof planes coplanar but with unwanted splitting lines (you erase these next).
                            Now you need to heal the bits of soffit etc and get rid of unwanted bits of the roof inside where you have joined these two temporary 'ends' together. It's easiest to do this if you set the Component/Group edit-mode to hide everything else during editing. That way you can simple look at the roof volume from below (its 'ceiling' is left open and any other walls etc below it will be temporarily hidden): then you can add 4 extra Lines to split the unwanted bits of 'cross' soffits off, then Erase the unwanted Edges splitting the 2 healed roof plane, the 2 unwanted 'internal' fascia's horizontal edges and the 2 long-side fascias unwanted vertical splitting Edges; finally Erase the 3 Edges of the 2 unwanted 'cross' pieces of 'internal' soffit to tidy up. Exit the Group edit and it should now look as desired, with its central hole...
                            It's actually much quicker to do all of this than it is to write it down !!!
                              Here's RoofHelp.doc (zipped) covering v3.0 - Unzip it and put it in the Plugins folder...
                              The .mht and .pdf formats will have to wait until the new year - the laptop I'm having to use over the holidays can't access the big-upload server...
                              RoofHelp.zip
                              1 Reply Last reply 👍
                                How does your plugin work? In general concept? Intersecting planes?
                                  The hipped roof one works by doing a followme around the face loop on a large roof-pitch triangle and intersecting everything with itself, then it erases any geometry that's not needed [the tricky bit], orients faces, applies materials etc. It will fail if the shape can't have a single pitch roof over it... possible with cranked star shapes or re-entrant curved sections where the valleys would diverge up the roof. My recent tutorial shows how to replicate it manually and heal the problem areas manually by redrawing the bits that need another pitch...
                                    Ravage
                                      DJMX1
                                      Superb plugin. However, why not create toolbar and how can I do to translate it into French?
                                      I can create the icons if you want 🎉
                                        This is one of my rare encrypted plugins so translation is not easy/possible - I recently had a PM about an ES version...
                                        A toolbar would be good - easy to do [after decryption] - as would better web-dialog interface...
                                        Unfortunately 'Roof' is quite near the bottom of the list... 😞
                                        But... good things come to those who wait ☀
                                          sketchdown
                                          @tig said:
                                          This is v3.0 of my 'Roof' script.
                                          It now incorporates options for sloping fascias and soffits.
                                          The help stuff has also been redone.
                                          This Roof.rb file replaces the older one in the Plugins folder.
                                          The RoofHelp.doc (zipped) file and some alternative larger 'help' file formats (mht and pdf) in separate threads - they are too big for one go...
                                          Feedback please...
                                          Merry Christams to one and all...
                                          how can I dwnload the plugin?
                                            From the link in the box saying "Attachments" right under the text you quoted.
                                            • 1 / 9
