    Render this: SSS
    174 Posts 44 Posters 38.5k Views 44 Watching
      Click Draw
      looks like I'm a bit behind.....oops 😳 Guess I've been Dragon my ass.... 🤣
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        d12dozr
        Fantastic renders, guys! This is so cool 😎
        Using Twilight, I also had the same problem as Rich, I started using the Low and Medium presets and it was taking forever, but I'm getting much better results after switching to #10 - Interior+ (but not good enough to post here yet)
        http://goo.gl/f7ooYh
        • W Offline
          woodtick
          Very interesting thread........thanks for starting this.I've just started working with Twilight and rendering in general.Keep in mind I'm a carpenter, not a graphic artist so any breach of rendering etiquette is purely unintentional. This is what I came up with....not sure it meets any of the sss criteria but it sure was fun trying.
          Rich
          • E Offline
            Ecuadorian
            Twilight Render's Easy 09 preset should be enough; Easy 10 enables color dispersion and some other special FX, however.
            I made two more tries: One with Easy 09 and another one with Easy 10. I stacked them together:
            And then added some airbrush to the eyes and altered the curves a little bit in GIMP:
            Hey, Pete, how about "Emitters and LEMs" for the next "Render this"?
            -Miguel Lescano
              avariant
              I started with the Twilight SSS template (Wax I think), then I made some extra changes in KT to produce this material. I was really surprised how it turned out; I really like it.
              • massimoM Offline
                massimo Moderator
                Coca-cola version. Just a Kerkythea material.
                • E Offline
                  Ecuadorian
                  Another try with Kerkythea. I didn't let it cook for more than a couple minutes as I'm preparing another one.
                  -Miguel Lescano
                    sepo
                    Guys I am really impressed with varied and good output. Seems all unbiased are doing really well, but I am very impressed with Vray/Max combo and Vue. 👍 👍
                      @ecuadorian said:
                      Next time you ignore kitty, the dog will pay.
                        dacad
                        Wow guys, great renders you're pulling out. I'm really liking this thread.
                        But can i ask for the ones using twilight to, instead saying the number of the preset, can you say the method of render?like photon mappping, ppt, mtp, bpt, etc etc etc. Just to compare results and see how diferent methods afect the materials in the final image. Thanks
                        avariant
                        Great material and render. Is that MLT?
                        • E Offline
                          Ecuadorian
                          Thanks, Sid.
                          DacaD, in Twilight, presets Easy 01-07 use Photon Mapping. Easy 08 use Progressive Path Tracing. Easy 09 is MLT. Easy 10 is BiPT-MLT.
                          I liked Remus' blue rubber dragon so much that here's my attempt to have an Aerogel dragon in Kerkythea:
                          -Miguel Lescano
                            tallbridgeguy
                            I'm still having some trouble making a decent render in kerkythea. The dragon I tried looked great but I don't think it was sss.
                            I downloaded some sss materials from the KT website, coke, red, blue, yellow and gum. I am using the the three backlights and the front light suggested by Pete (with MLT) but I can't get the sss light changing direction thingy. Just a well lit dragon. (which I like and the software is free.)
                            Could someone post some KT settings for a sss dragon? It would be very helpful if the comparison settings were shown for Vray vs KT and the matching images to see how the two systems compare.
                            Great renders in this thread!
                            thanks!
                            s
                            Nielsen
                            http://www.tallbridgeguy.com/
                            • N Offline
                              nomeradona
                              joining you here... using translucent material vray sketchup.. which the equivalent of SSS
                              http://i334.photobucket.com/albums/m421/nomeradona_1234/dragon.jpg
                              • E Offline
                                Ecuadorian
                                TBG, I gave up trying to achieve SSS in Kerkythea, too; I do most of my renders in Twilight, which uses the same engine. My last blue dragon in Kerkythea is literally filled with air; it's just fog. Here are my settings. I scaled the dragon a lot (it is around 30m long) so the fog would become visible.
                                -Miguel Lescano
                                  d12dozr
                                  My attempt on the dragon...Thanks for starting this thread, Pete, I've learned so much and the subjects are so fun that I'm really excited to render them 👍 ...oh, and the amazing images are an incentive as well
                                  Twilight Render, White Wax Library material I think, #10 preset - I stopped cooking after 8 hours (this SSS is killing my poor laptop) 💚
                                  Say, is there a way to change the library colors in Twilight, or to I have to do that in Kerkythea?
                                  • olisheaO Offline
                                    olishea
                                    you can change templates but not library.....but im sure u can change library in kerkythea, maybe im wrong. and yes sss is very slow
                                    oli
                                    • soloS Offline
                                      These are fun, and some excellent renders as well as some great learning.
                                      We may not need SSS on a daily basis, but on the off chance we do, we now have learned how it can be achieved.
                                      So we have covered studios, SSS, what next you ask....
                                      Keep an eye out for the next learning challenge, one a little more relevant.
                                      • E Offline
                                        Ecuadorian
                                        LED lighting?
                                        Neon signs?
                                        Water?
                                        Vegetation? (Vue wins. End of thread) 💚
                                        -Miguel Lescano
                                        • jeff hammondJ Offline
                                          vegetation...
                                          +1
                                          clip maps
                                          3d vs 2.5d vs 2d
                                          rendered vs postpro
                                          etc.
                                            @ecuadorian said:
                                            LED lighting?
                                            My vote goes to this. I've been trying to render LEDs many times, without luck. http://forums.sketchucation.com/viewtopic.php?f=81&p=157487
                                            • 5 / 9
