    Render this: SSS
    174 Posts 44 Posters 47.6k Views 44 Watching
      dacad
      Wow guys, great renders you're pulling out. I'm really liking this thread.
      But can i ask for the ones using twilight to, instead saying the number of the preset, can you say the method of render?like photon mappping, ppt, mtp, bpt, etc etc etc. Just to compare results and see how diferent methods afect the materials in the final image. Thanks
      avariant
      Great material and render. Is that MLT?
      • E
        Ecuadorian
        Thanks, Sid.
        DacaD, in Twilight, presets Easy 01-07 use Photon Mapping. Easy 08 use Progressive Path Tracing. Easy 09 is MLT. Easy 10 is BiPT-MLT.
        I liked Remus' blue rubber dragon so much that here's my attempt to have an Aerogel dragon in Kerkythea:
        -Miguel Lescano
        • T
          tallbridgeguy
          I'm still having some trouble making a decent render in kerkythea. The dragon I tried looked great but I don't think it was sss.
          I downloaded some sss materials from the KT website, coke, red, blue, yellow and gum. I am using the the three backlights and the front light suggested by Pete (with MLT) but I can't get the sss light changing direction thingy. Just a well lit dragon. (which I like and the software is free.)
          Could someone post some KT settings for a sss dragon? It would be very helpful if the comparison settings were shown for Vray vs KT and the matching images to see how the two systems compare.
          Great renders in this thread!
          thanks!
          s
          Nielsen
          http://www.tallbridgeguy.com/
          • N
            nomeradona
            joining you here... using translucent material vray sketchup.. which the equivalent of SSS
            http://i334.photobucket.com/albums/m421/nomeradona_1234/dragon.jpg
            • E
              Ecuadorian
              TBG, I gave up trying to achieve SSS in Kerkythea, too; I do most of my renders in Twilight, which uses the same engine. My last blue dragon in Kerkythea is literally filled with air; it's just fog. Here are my settings. I scaled the dragon a lot (it is around 30m long) so the fog would become visible.
              -Miguel Lescano
                d12dozr
                My attempt on the dragon...Thanks for starting this thread, Pete, I've learned so much and the subjects are so fun that I'm really excited to render them 👍 ...oh, and the amazing images are an incentive as well
                Twilight Render, White Wax Library material I think, #10 preset - I stopped cooking after 8 hours (this SSS is killing my poor laptop) 💚
                Say, is there a way to change the library colors in Twilight, or to I have to do that in Kerkythea?
                http://goo.gl/f7ooYh
                • olisheaO
                  olishea
                  you can change templates but not library.....but im sure u can change library in kerkythea, maybe im wrong. and yes sss is very slow
                  oli
                  • soloS
                    These are fun, and some excellent renders as well as some great learning.
                    We may not need SSS on a daily basis, but on the off chance we do, we now have learned how it can be achieved.
                    So we have covered studios, SSS, what next you ask....
                    Keep an eye out for the next learning challenge, one a little more relevant.
                    • E
                      Ecuadorian
                      LED lighting?
                      Neon signs?
                      Water?
                      Vegetation? (Vue wins. End of thread) 💚
                      -Miguel Lescano
                      • jeff hammondJ
                        vegetation...
                        +1
                        clip maps
                        3d vs 2.5d vs 2d
                        rendered vs postpro
                        etc.
                          @ecuadorian said:
                          LED lighting?
                          My vote goes to this. I've been trying to render LEDs many times, without luck. http://forums.sketchucation.com/viewtopic.php?f=81&p=157487
                          • soloS
                            Thomas, I promise to make that the next challenge, do you have a great model to share?
                            Or should I make one?
                              hm... "great" ... meh!
                              I made a model of an LED. Attached that one - you can have a look.
                              And I also attached the space invader scene.
                              LED2.skp
                              Space Invader scene
                              • jeff hammondJ
                                had this one going for about and hour.. had to stop it as i need the resources for something a tad more important 😄
                                ice
                                http://homepage.mac.com/jeffhammond/.Public/scf/dragonice.jpg
                                • jeff hammondJ
                                  exported a jpg while setting that one up in SU.. thought it looked pretty good this way..
                                  • P
                                    pav_3j
                                    has anyone here rendered these in vray?
                                    i have no idea how to achieve sss in it?
                                    feel like a fool...again!
                                    pav
                                    Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                      d12dozr
                                      That's neat Jeff - the ice turned out really good - it even looks "frosty" where its thinner in the mouth 😉
                                        d12dozr
                                        pav, Nomeradona did here: http://forums.sketchucation.com/viewtopic.php?p=200104#p200104
                                        • stefanqS
                                          stefanq
                                          Too late for another set of dragons???
                                          Modo renders:
                                          http://img41.imageshack.us/img41/9620/dragon1vy.jpg
                                          http://img10.imageshack.us/img10/8263/dragon2r.jpg
                                          http://img10.imageshack.us/img10/598/dragon3o.jpg
                                          • T
                                            tallbridgeguy
                                            Thanks for the help Miguel, I believe it is a bit of a touchy subject to discuss the differences between rendering systems.
                                            I'm sure KT can do sss but I can't. (I will keep trying.)
                                            Since I am new to the rendering world and I have read on this forum that different systems have different advantages/disadvantages, can users tell when a system is unsuited for a particular task?
                                            Not trying to start a fight but sometimes I think I need several rendering systems to get a "particular" look for a "particular" image.
                                            But I could also just suck at rendering...
                                            thanks Miguel for the help!
                                            Nielsen
                                            • 6 / 9
