    Sketchup 7.1 bugs
    66 Posts 24 Posters 14.3k Views 24 Watching
    • N Offline
      NewOne
      The wireframe remains without section edges if I move the plane, but the shaded version regains its edges if I focus on a face or I move the section plane.
        mirjman
        I get a bugsplat when trying to export a jpg at 9000x5700, shadows on, anti-alias off
        I recall exporting large resolution images has been a problem for a while, has the reason for this error ever been formally addressed? It also seems to be sporadic.
          Aerilius
          I have the impression that it's similar to z-fighting: the section cut is in plane to the roofing face.
          • N Offline
            NewOne
            But it's not happening on vertical or horizontan plane, only on slope.
              berling
              Regarding the section cut bug.
              I am finding that the perspective has no affect section cut bug.
              But one thing about z-fighting, it is a rendering problem of having two faces on top of each other. This section cut bug is clearly triangulating the faces with what appears to be hidden geometry.
              Also, the problem is even worse if you have more geometry on the surface (see attached model).
              Do other users have this problem from a fresh model? I would hate to reinstall as a test if I don't have to.
              Also,
              MacBook Pro, 10.5.8 w/ 2.4 GHz Intel Core 2 Duo, 2 GB SDRAM
              SketchUp_SectionTool-ERROR-2.skp
              • SketchUp Guide TommyS Offline
                Oops. It looks like a missed a step:
                1. Go into Perspective mode.
                2. Move the section plane further into the model so it goes past the roof surface.
                3. Move the section plane back to the starting position. The triangulation should be gone.
                4. Go back to Parallel Projection.
                Sorry about that 😕
                Regards,
                SGT
                  dedmin
                  Scrolling in component browser and material browser doesn't work.
                    At least in the component browser, as far as I can remember, it has never worked. If only it did, of course.
                      dedmin
                      It works, but only in list view.
                      • massimoM Offline
                        massimo Moderator
                        Had two bugsplats simply running Firefox with only SU 7.1 opened and minimized. 😕
                          markozeta
                          I can't select a section plane once I put it in my model!
                          Help!
                          BSME - Cal Poly Pomona
                          Sketchup Pipe Maniac
                            berling
                            Help!
                            The section plane is a little strange. If you have geometry on the other side of the section cut you will select it. Zoom out some to a point where there is no geometry behind the section and select from there.
                            Also, Tommys fix does not actually fix the bug but it is sort of a work around. The section plain does not snap back to the face so after moving it it is no longer on it. For now, the best thing to do to avoid this bug is to move the section into the building, something like .1". Its not perfect but it does the trick.
                            • takesh hT Offline
                              takesh h
                              I thought somebody reported the loss of their plugins... now I cannot find the post, was I dreaming?
                              Anyway, after upgrading to 7.1, looks like all of my toolset is gone except Google's.
                              Script files are physically there, sitting in two "Plugins" folders (I'm on a Mac), and they are enabled at [SketchUp]>[Preferences]>[Extensions].
                              Some of them are visible in my workspace. Others I have no way to start them.
                              IF anybody encountered the similar problems and solved it, please let me know.
                                tfdesign
                                Sorry for repeating this (I mentioned it within a post on keying in length- which appears to be buggy too),
                                I'm drawing a line out from a corner at a 45º angle, but I've got no angle snap (despite changing the model info preferences between different angle snap sizes). Sometimes the snap will work, but most of the time, I'm there pulling my hair out trying to get it to snap to something. I don't remember having this problem before.
                                Anyone else seeing or finding this?
                                (Macbook Pro 2.16GHz Intel Core Duo 2, 3 gigs ram, ATI Radeon X1600)
                                Tom
                                PS I'm also repeating the parallel projection bug, as mentioned earlier too. This is also really frustrating!! I want to upgrade to Pro, and I've got the money too, but these little things always make me put my credit card away again. And if I go back to using (ie reinstall) SU7, then how can I find these bugs? (and I pick up the previous bugs too!). Software should work when it is sold- not half work. This is not good.
                                  bjanzen
                                  I attempted to answer your other post. "I think you're mis-understanding angle snap", Barry snapped.
                                    tfdesign
                                    Yes, I probably am. I need to spend some more time with the manual (well Aidan Chopra's manual. Absolutely Brilliant Aidan! 😄 ). It's crazy but I trained using Solidworks, but I'm finding relearning SketchUp a bit of a tough one!! (probably because there is no history).
                                    We're getting there 😄
                                    Thanks for the reply, Barry.
                                    Tom
                                      bjanzen
                                      No problem... it does depend on what you're coming from to understand some of the things about SketchUp. When I started, I was not accustomed to being able to modify things after the second click (via the Measurements box / VCB). But after you get into SketchUp, it's a real joy to use, as displayed by my many feeble attempts at humor and fun.
                                      So I'm guessing a typical SketchUp user would draw a line, select it, select the rotate tool, click on one end, click on the other end, hold down option (I'm on Mac) to copy move, rotate a bit and then type "45" and return and have 2 lines, same length, 45º angle.
                                      b
                                        tim
                                        I've had a couple of very odd SUpro crashes in the last few days; no crashlog, no report to Apple, just .... gone. The Console shows
                                        05-10-09 6:30:29 PM com.apple.launchd.peruser.501[121] ([0x0-0x2c02c].com.google.sketchuppro7[296]) Exited with exit code: 1
                                        which isn't so very helpful.
                                        Interestingly Layout has done the same thing a couple of times
                                        06-10-09 6:47:59 PM com.apple.launchd.peruser.501[121] ([0x0-0x3af3af].com.google.LayOut[7913]) Exited with exit code: 1
                                        Possibly associated with theLO crash are some messages about Intrinsic Alchemy v3.2 Beta-0903
                                        I haven't been doing anything different to my normal work, the machine hasn't changed in recent days (no hardware alterations, no updates loaded etc) and it's all been running pretty well generally.
                                          bishopski
                                          Help!
                                          I've got the same problem.
                                          I can get around it by grouping everything together, adding the section plane, selecting all then subtracting everything bar the plane, but it's not ideal
                                            anglaret
                                            I notice that color selection from the drawing does not work regularly.
                                            I am working in 2D and alt-click in paint select everything but the chosen square and do not recuparate the color from the square beside
                                            Selection does not work so well also when selecting between two lines side by side
                                            Marc
                                            • 1 / 4
