    [Plugin] 2D Tools
    785 Posts 178 Posters 462.6k Views 177 Watching
    • CadFatherC Offline
      CadFather
      Thanks TIG, some alternative icons if needed..
      Icons.zip
        CadFather
        Hi TIG, how difficult would a double click to fillet all the corners be? (or something similar)
        also: is text tag now redundant?
          dedmin
          Couldn't get the 2d line style tool to work?
          • halroachH Offline
            halroach
            can't get the line styles to work either. Would it have to do with the styles?
            FlexTools - Super Quick Windows, Doors, Slats...
              rv1974
              Fillet tool is a nice addition. Thank you TIG!
              P.S.I have 2 sets of the same icons on one tollbar. How to solve it?
              • TIGT Online
                TextTag works similarly but sticks onto on 3D Faces and has a few more options like 'face_camera'...
                The fillet tool works by picking two edges so your idea might be difficult ?
                • TIGT Online
                  Please ensure that earlier folders and 2D .rbs have been removed - perhaps (re)do a 'clean' install ?
                  • TIGT Online
                    There's aglitch on the layer creation... I'll issue an update to fix it asap...
                    • TIGT Online
                      v2.3 now available here http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                      Tweaks to LineStyle Tools [layer visibility glitch etc] and now CafFather's alternative icon set included [as zip], if desired...
                        dedmin
                        Line styles still don't work - I can see layers are visible, but lines don't chance.
                        • TIGT Online
                          Check you have materials to show mode is set 'on' - i.e. face materials show up... Check View/Hidden-Geometry is 'off'.
                          Start the linestyle tool, right-click in empty space, in the dialog that opens set the style to a line-width you know will show up at the size of model (default=1, if the edges are very long than perhaps =6, very small =.25 ???) and then style='Dashed' and color='Red' - so it'll be clearly distinguishable from the original edge. Pick an edge - that edge should get moved onto the ...HIDN layer [and disappear as it's switched 'off'] and a new dashed styled-line 'group' should be made and appear on the ...STYL layer ? Open the Outliner to see what groups you have... Get Entity Info on the edge and new group to check what happens...
                          Run the tool with the Windows/Ruby Console open and copy/paste us any error messages that you get, if it persists...
                          Consider posting a small [purged] model with the problem if it's not fixed ?
                          D 1 Reply Last reply Reply Quote 0
                          • N Offline
                            NewOne
                            Wonderful set of tools. ☀ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!
                            However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                            One more thing: could Set Z-Plane tool to have inference? I'd like to be able to snap on vertexes and edges.
                            Thanks again for all the tools you made!.
                              dedmin
                              • TIGT Online
                                dedmin
                                I see from the video it's not working... The ...HIDN layer should turn off if you have it 'on'. I suspect it's something to do with scenes/pages... Do you get any Ruby Console Errors ?
                                I notie the lines are only afew mm long so choose a small width - 4 = 4" ~= 100mm x10 the length of the line !
                                • TIGT Online
                                  @newone said:
                                  Wonderful set of tools. ☀ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                                  I'll look into the rectangle's drawing clipping.
                                  The Z-plane tool does have inferencing tooltips and will snap to these points but the cursor doesn't cahnge, I look at this too...
                                    dedmin
                                    @tig said:
                                    dedmin
                                    Error; #<NoMethodError; undefined method `set_visibility' for nil;NilClass>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DlinestyleTool.rb;188;in `style_line'
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DlinestyleTool.rb;166;in `onLButtonDown'
                                    • EarthMoverE Offline
                                      EarthMover
                                      I'm getting the same errors as dedmin with the line style tool.
                                      Content Creator at Skapeup
                                      • kenK Offline
                                        ken
                                        Attached is the VCB during drawing an arc. Not sure, what VCB is displaying, however your help guide indicated that the VCB should be displaying the “swept-angle”
                                        Thanks for the plugin
                                        Ken
                                        • EdsonE Offline
                                          Edson
                                          warning to mac users: in order for this pluging to open you must put it at USER\Libray\application support\google\google sketchup 7\plugins, not in the main plugins folder.
                                          TIG: i click on the help icon and get nothing. is this a problem or there is nothing there?
                                          http://www.mahfuz.arq.br
                                            TIG, I'm getting the same message in the console when I click on the first edge when trying to change the line style.
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 39 / 40
