    [Plugin] 2D Tools
    791 Posts 178 Posters 770.7k Views 177 Watching
      Get the latest version from the SketchUcation PluginStore
      http://sketchucation.com/resources/pluginstore?pln=2Dtools
      or why not use the AutoInstall feature of the 'SketchUcation Plugin Store' toolset's dialog...
        โ“
          remus
          the disappointment of the forgotten attachment strikes a crushing blow.
          • CadFatherC
            CadFather
            ๐Ÿ˜„
            • EarthMoverE
              EarthMover
              Awesome update TIG! Thanks! You've brought line weight and styles to SU!!!!! Setting the Z plane and toggling to construction lines were things I asked for initially....thanks for implementing them!!!
              Content Creator at Skapeup
                Does the Z-Plane set the elevation the lines are drawn on, or is it also possible to define a plane that's different than the standard axis?
                  Only on a flat Z-plane - these are 2D Tools... ๐Ÿ˜„
                  Although some like Fillet work in '3D' too...
                    2D, yes - just wondered if you could specify the 2D work-plane arbitrary - not just top-down from the world axis.
                      Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                      ๐Ÿค“
                      • CadFatherC
                        CadFather
                        Thanks TIG, some alternative icons if needed..
                        Icons.zip
                        • CadFatherC
                          CadFather
                          Hi TIG, how difficult would a double click to fillet all the corners be? (or something similar)
                          also: is text tag now redundant?
                            dedmin
                            Couldn't get the 2d line style tool to work?
                            • halroachH
                              halroach
                              can't get the line styles to work either. Would it have to do with the styles?
                              FlexTools - Super Quick Windows, Doors, Slats...
                                rv1974
                                Fillet tool is a nice addition. Thank you TIG!
                                P.S.I have 2 sets of the same icons on one tollbar. How to solve it?
                                  TextTag works similarly but sticks onto on 3D Faces and has a few more options like 'face_camera'...
                                  The fillet tool works by picking two edges so your idea might be difficult ?
                                    Please ensure that earlier folders and 2D .rbs have been removed - perhaps (re)do a 'clean' install ?
                                      There's aglitch on the layer creation... I'll issue an update to fix it asap...
                                        v2.3 now available here http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                        Tweaks to LineStyle Tools [layer visibility glitch etc] and now CafFather's alternative icon set included [as zip], if desired...
                                          dedmin
                                          Line styles still don't work - I can see layers are visible, but lines don't chance.
                                            Check you have materials to show mode is set 'on' - i.e. face materials show up... Check View/Hidden-Geometry is 'off'.
                                            Start the linestyle tool, right-click in empty space, in the dialog that opens set the style to a line-width you know will show up at the size of model (default=1, if the edges are very long than perhaps =6, very small =.25 ???) and then style='Dashed' and color='Red' - so it'll be clearly distinguishable from the original edge. Pick an edge - that edge should get moved onto the ...HIDN layer [and disappear as it's switched 'off'] and a new dashed styled-line 'group' should be made and appear on the ...STYL layer ? Open the Outliner to see what groups you have... Get Entity Info on the edge and new group to check what happens...
                                            Run the tool with the Windows/Ruby Console open and copy/paste us any error messages that you get, if it persists...
                                            Consider posting a small [purged] model with the problem if it's not fixed ?
                                            D 1 Reply Last reply
                                            • 39
                                            • 40
                                            • 1 / 40
