    [Plugin] 2D Tools
    791 Posts 178 Posters 770.7k Views 177 Watching
      remus
      the disappointment of the forgotten attachment strikes a crushing blow.
      • CadFatherC
        CadFather
        ๐Ÿ˜„
        • EarthMoverE
          EarthMover
          Awesome update TIG! Thanks! You've brought line weight and styles to SU!!!!! Setting the Z plane and toggling to construction lines were things I asked for initially....thanks for implementing them!!!
          Content Creator at Skapeup
            Does the Z-Plane set the elevation the lines are drawn on, or is it also possible to define a plane that's different than the standard axis?
              Only on a flat Z-plane - these are 2D Tools... ๐Ÿ˜„
              Although some like Fillet work in '3D' too...
                2D, yes - just wondered if you could specify the 2D work-plane arbitrary - not just top-down from the world axis.
                  Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                  ๐Ÿค“
                  • CadFatherC
                    CadFather
                    Thanks TIG, some alternative icons if needed..
                    Icons.zip
                    • CadFatherC
                      CadFather
                      Hi TIG, how difficult would a double click to fillet all the corners be? (or something similar)
                      also: is text tag now redundant?
                        dedmin
                        Couldn't get the 2d line style tool to work?
                        • halroachH
                          halroach
                          can't get the line styles to work either. Would it have to do with the styles?
                          FlexTools - Super Quick Windows, Doors, Slats...
                            rv1974
                            Fillet tool is a nice addition. Thank you TIG!
                            P.S.I have 2 sets of the same icons on one tollbar. How to solve it?
                              TextTag works similarly but sticks onto on 3D Faces and has a few more options like 'face_camera'...
                              The fillet tool works by picking two edges so your idea might be difficult ?
                                Please ensure that earlier folders and 2D .rbs have been removed - perhaps (re)do a 'clean' install ?
                                  There's aglitch on the layer creation... I'll issue an update to fix it asap...
                                    v2.3 now available here http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                    Tweaks to LineStyle Tools [layer visibility glitch etc] and now CafFather's alternative icon set included [as zip], if desired...
                                      dedmin
                                      Line styles still don't work - I can see layers are visible, but lines don't chance.
                                        Check you have materials to show mode is set 'on' - i.e. face materials show up... Check View/Hidden-Geometry is 'off'.
                                        Start the linestyle tool, right-click in empty space, in the dialog that opens set the style to a line-width you know will show up at the size of model (default=1, if the edges are very long than perhaps =6, very small =.25 ???) and then style='Dashed' and color='Red' - so it'll be clearly distinguishable from the original edge. Pick an edge - that edge should get moved onto the ...HIDN layer [and disappear as it's switched 'off'] and a new dashed styled-line 'group' should be made and appear on the ...STYL layer ? Open the Outliner to see what groups you have... Get Entity Info on the edge and new group to check what happens...
                                        Run the tool with the Windows/Ruby Console open and copy/paste us any error messages that you get, if it persists...
                                        Consider posting a small [purged] model with the problem if it's not fixed ?
                                        D 1 Reply Last reply
                                        • N
                                          NewOne
                                          Wonderful set of tools. โ˜€ I'm not a McDonand's fan, but this time i must say: I'm lovin' It!
                                          However, one thing is annoying. As you can see in attached image, the line is clipped when drawing (the mouse cursor is not seen, but this img was captured while drawing with 2d rectangle tool). I think this is because the drawing gets out its boundingbox and if that boundingbox is updated on mouse move, this clipping will not occur anymore.
                                          One more thing: could Set Z-Plane tool to have inference? I'd like to be able to snap on vertexes and edges.
                                          Thanks again for all the tools you made!.
                                            dedmin
                                            • 39
                                            • 40
                                            • 1 / 40
