    [Plugin] Blend ver 1.12.
    80 Posts 35 Posters 69.2k Views 35 Watching
    • W Offline
      watkins
      Dear Kirill,
      Version 5 doesn't seem to work in SU Pro 7, even for simple shapes, but don't give up.
      • W Offline
        watkins
        Thanks for posting versions 1.2 and 1.4. I will test them out with areas. Previously, I only tested this plugin with arcs, and that still works in V1.5.
          blajnov
          @watkins said:
          Dear Kirill,
          It might be a good idea to post versions 1.0 to 1.5 as the later versions seem to be problematic. Version 1.0 seemed to work quite nicely. I too have over-written previous versions and so cannot go back a step or two.
          Kind regards,
          Bob
          There are three previous versions:
          v 1.2
          v 1.3
          v 1.4
          Rename files in sublend.rb
          sublend__1.2.rb
          sublend_1.4.rb
          sublend_1.3.rb
            kirill2008
            Guys, I don't know yet how to prevent skin (mesh) turning inside out ๐Ÿ˜ž The point is that script processes vertices with corresponding indices: so maybe flipping normal or 180 degrees rotation (or 90) of one of 2 faces may help.
            Missing triangles (they vanished after color blending feature addition) have come back now ๐Ÿ˜„ (ver. 1.6)
            Error messages kind of "undefined method `back_material' for... " debugged (I guess ๐Ÿ˜„ ).
            • W Offline
              watkins
              Dear Kirill,
              Here is a quick question. You mention Sketchup 6 in both the first post and in the introduction to your plugin. Does this plugin work well in version 6? Many people have migrated to version 7, although with little added benefit.
              Keep going, you are doing a great job.
              Kind regards,
              Bob
                cosycat
                Thanks for all of the updates, this is really getting there. I have noticed that the result (v6) does depend on the order in which the points are drawn (for closed shapes at least) - this might explain some of the inside out results people are getting.
                Quick example, the numbers show the order in which the upper shape points were added
                  kirill2008
                  Ver 1.6 demo videos:
                  Filtration capabilities video:
                  [flash=425,344:17c3bm6v]http://www.youtube.com/v/Pml0gn-5fuY&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                  Blending between different types of entities demo:
                  [flash=425,344:17c3bm6v]http://www.youtube.com/v/0gchAp7Yje8&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                  Fixing inside out problem variant:
                  [flash=425,344:17c3bm6v]http://www.youtube.com/v/6PvRKfzm-g4&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                  As cosycat mentioned:
                  • olisheaO Offline
                    olishea
                    WOW. This is an awesome plugin. I tried using skin.rb for meshing between edges but it never worked for mac (i think). so im glad you can do it with this plugin!!
                    Amazing work, one of the best plugins around. the modeling possibilities are endless, I'm loving it!
                    oli
                    • utilerU Offline
                      utiler
                      Kirill2008,
                      Have you thought about adding a path function to this script?
                      [see attached]
                      Your generosity is much appreciated, I only wish I knew ruby too so I could reply the favor....
                      Just Curious...
                        kirill2008
                        Yes, I think about it almost every day (and some times night ๐Ÿ˜„ too). I want to add a path processing very much, but it looks like such task is less obvious than already implemented algorithm. And maybe it's better to make a brand-new plugin with path processing, because it will work the other way than existing plugin.
                        Ver. 1.7. demo video, shows blending between face and construction point and context menu "Blend" command usage.
                        [flash=425,344:269yb5p5]http://www.youtube.com/v/-dfMofxc3pw&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:269yb5p5]
                        I don't know yet how to implement custumization of context menu items, so "Blend" command appears always when more than 1 object is selected
                        • kenK Offline
                          ken
                          Not sure how you are fixing the inside out problem. I can't tell exactly what you are doing. Could you please try again?
                          Thanks in advance
                          Ken
                            Ben Ritter
                            Kirill,
                            Thank you so much for the script, very useful.
                            Is there a bug with the blending of colors, I can't seem to get that to work?
                              kirill2008
                              Ken
                              I'm flipping the face normal (lower one).
                              Maybe. Note that color blending enabled only for 2 faces yet (does not work for curves, edges and construction points) and both face front material and face back material has to differ from default one. Hope that helps.
                                kirill2008
                                Olishea, glad to hear sublend works on mac ๐Ÿ‘ (I was just going to ask someone to try it on mac). Thank's for testing and feedback and happy blendings ๐Ÿ˜„
                                Ofcourse it's not my achievement ๐Ÿ˜„ , it's just because ruby is cross platform.
                                  kirill2008
                                  Now the implementation of interaction is in progress (it is not yet stable so ver 1.8 will appear a little bit later). I think that interaction ability will solve (more or less) the inside out problem. I mean it will be easier to fix it by moving, rotating and/or flipping one of the initial faces and the result mesh or set of intermediate faces/curves will refresh automatically. This will be the step towards path processing also.
                                  [flash=425,344:f7q8z0yv]http://www.youtube.com/v/IYS69O6idg8&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:f7q8z0yv]
                                    Come on, Kirill, this is too much for me today. ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜• ๐Ÿ˜’
                                    • EarthMoverE Offline
                                      EarthMover
                                      Mr Krillshot....fantastic work and dedication to continually improving your script. Can't wait to see v. 1.8! Thanks so much!
                                      Content Creator at Skapeup
                                      • kenK Offline
                                        ken
                                        Mr Krillshot
                                        Great pluging, however, I am having trouble duplicating all the video you are showing. Would it be possible to also attach the Sketchup file so I can try out the same file as you are using. This way I would know if the problems I am having are with my computer or the plugin.
                                        Again thanks for the pluging
                                        Ken
                                        • utilerU Offline
                                          utiler
                                          This is nuts; really. I can't beleive how fast you are developing this plugin, Mr Kirill!!!
                                          Just Curious...
                                            kirill2008
                                            interactive tests file
                                            File with the model, that appears in the demo video of ver. 1.8.
                                            Unfortunately interactivity enabled only in run-time (untill skp file is not closed) and I don't know yet how to save interaction data to skp file (maybe it's not possible at all). So if you want to play with initial faces, then it is necessary to make new blended object.
                                            Ver. 1.8. does not support interaction with curves yet, because it is difficult to get the curve object from the Sketchup.active_model... The point is that active_model contains no curves (curve is just a 'conceptual entity' "all circles, arcs, and arbitrary curves are really just edges that are bound together in sequence"). So it's necessary to perform some tricky things to obtain the certain curve, that you need.
                                            Edges also behave strange: moving of the edge or moving of the edge vertex does not envoke onChangeEntity event handler ๐Ÿ˜•. Only if you change some properties of the edge (for example layer or smoothness), then modify event rises and onChangeEntity envokes.
                                            [flash=425,344:2o85cxyz]http://www.youtube.com/v/ZgOUZR3Z2xE&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:2o85cxyz]
                                            So ver. 1.8. supports interaction only between 2 faces and face+construction point. I'm not sure if I can solve myself edge and curve problems.
                                            • 2 / 4
