    [Plugin] Blend ver 1.12.
    80 Posts 35 Posters 72.8k Views 35 Watching
    • majidM
      majid
      woooow...it would be a dreamy plugin if no bugs!!..I gave it a try , but it seems that previous versions were better on freehand lines, while the last version doesn't works fine... also on closed line doesn;t works at all (su 6)..seeing forward to see the improvements mate btw thanks thanx thanx! ๐Ÿ‘
        This is a useful plugin. Well, for me it was until I installed the latest version (1.5). Now I get what you see in the attached screen shot. Unfortunately I installed over the previous version. Keep working at it. I'm sure you'll get it all working.
        Thank you.
          Daniel S
          Thank you for adding color blending ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
          I have problems with this new version too (I use SU7).
          Sometimes work with results like the ones Dave R post above.
          In other cases the plugin dosenยดt do anything and prints this in the ruby console:
          Error: #<NoMethodError: undefined method back_material' for #<Sketchup::Edge:0x67b7f70>> C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:68:in blend'
          C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:270
          C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:248:in `call'
          Daniel S
          • W
            watkins
            Dear Kirill,
            It might be a good idea to post versions 1.0 to 1.5 as the later versions seem to be problematic. Version 1.0 seemed to work quite nicely. I too have over-written previous versions and so cannot go back a step or two.
            Kind regards,
            Bob
            • W
              watkins
              Dear Kirill,
              Version 5 doesn't seem to work in SU Pro 7, even for simple shapes, but don't give up.
              • W
                watkins
                Thanks for posting versions 1.2 and 1.4. I will test them out with areas. Previously, I only tested this plugin with arcs, and that still works in V1.5.
                • B
                  blajnov
                  @watkins said:
                  Dear Kirill,
                  Kind regards,
                  Bob
                  There are three previous versions:
                  v 1.2
                  v 1.3
                  v 1.4
                  Rename files in sublend.rb
                  sublend__1.2.rb
                  sublend_1.4.rb
                  sublend_1.3.rb
                  • K
                    kirill2008
                    Guys, I don't know yet how to prevent skin (mesh) turning inside out ๐Ÿ˜ž The point is that script processes vertices with corresponding indices: so maybe flipping normal or 180 degrees rotation (or 90) of one of 2 faces may help.
                    Missing triangles (they vanished after color blending feature addition) have come back now ๐Ÿ˜„ (ver. 1.6)
                    Error messages kind of "undefined method `back_material' for... " debugged (I guess ๐Ÿ˜„ ).
                    • W
                      watkins
                      Dear Kirill,
                      Here is a quick question. You mention Sketchup 6 in both the first post and in the introduction to your plugin. Does this plugin work well in version 6? Many people have migrated to version 7, although with little added benefit.
                      Keep going, you are doing a great job.
                      Kind regards,
                      Bob
                      • C
                        cosycat
                        Thanks for all of the updates, this is really getting there. I have noticed that the result (v6) does depend on the order in which the points are drawn (for closed shapes at least) - this might explain some of the inside out results people are getting.
                        Quick example, the numbers show the order in which the upper shape points were added
                        • K
                          kirill2008
                          Ver 1.6 demo videos:
                          Filtration capabilities video:
                          [flash=425,344:17c3bm6v]http://www.youtube.com/v/Pml0gn-5fuY&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                          Blending between different types of entities demo:
                          [flash=425,344:17c3bm6v]http://www.youtube.com/v/0gchAp7Yje8&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                          Fixing inside out problem variant:
                          [flash=425,344:17c3bm6v]http://www.youtube.com/v/6PvRKfzm-g4&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                          As cosycat mentioned:
                          • olisheaO
                            olishea
                            WOW. This is an awesome plugin. I tried using skin.rb for meshing between edges but it never worked for mac (i think). so im glad you can do it with this plugin!!
                            Amazing work, one of the best plugins around. the modeling possibilities are endless, I'm loving it!
                            oli
                            • utilerU
                              utiler
                              Kirill2008,
                              Have you thought about adding a path function to this script?
                              [see attached]
                              Your generosity is much appreciated, I only wish I knew ruby too so I could reply the favor....
                              Just Curious...
                              • K
                                kirill2008
                                Yes, I think about it almost every day (and some times night ๐Ÿ˜„ too). I want to add a path processing very much, but it looks like such task is less obvious than already implemented algorithm. And maybe it's better to make a brand-new plugin with path processing, because it will work the other way than existing plugin.
                                Ver. 1.7. demo video, shows blending between face and construction point and context menu "Blend" command usage.
                                [flash=425,344:269yb5p5]http://www.youtube.com/v/-dfMofxc3pw&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:269yb5p5]
                                I don't know yet how to implement custumization of context menu items, so "Blend" command appears always when more than 1 object is selected
                                • kenK
                                  ken
                                  Not sure how you are fixing the inside out problem. I can't tell exactly what you are doing. Could you please try again?
                                  Thanks in advance
                                  Ken
                                  • B
                                    Ben Ritter
                                    Kirill,
                                    Thank you so much for the script, very useful.
                                    Is there a bug with the blending of colors, I can't seem to get that to work?
                                    • K
                                      kirill2008
                                      Ken
                                      I'm flipping the face normal (lower one).
                                      Maybe. Note that color blending enabled only for 2 faces yet (does not work for curves, edges and construction points) and both face front material and face back material has to differ from default one. Hope that helps.
                                      • K
                                        kirill2008
                                        Olishea, glad to hear sublend works on mac ๐Ÿ‘ (I was just going to ask someone to try it on mac). Thank's for testing and feedback and happy blendings ๐Ÿ˜„
                                        Ofcourse it's not my achievement ๐Ÿ˜„ , it's just because ruby is cross platform.
                                        • K
                                          kirill2008
                                          Now the implementation of interaction is in progress (it is not yet stable so ver 1.8 will appear a little bit later). I think that interaction ability will solve (more or less) the inside out problem. I mean it will be easier to fix it by moving, rotating and/or flipping one of the initial faces and the result mesh or set of intermediate faces/curves will refresh automatically. This will be the step towards path processing also.
                                          [flash=425,344:f7q8z0yv]http://www.youtube.com/v/IYS69O6idg8&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:f7q8z0yv]
                                          • GaieusG
                                            Come on, Kirill, this is too much for me today. ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜• ๐Ÿ˜’
                                            • 2 / 4
