    [Plugin] Blend ver 1.12.
    80 Posts 35 Posters 69.2k Views 35 Watching
    • utilerU Offline
      utiler
      This is a nice plugin, mate! I'm going to play!!!!
      Just Curious...
        tomot
        Nice plugin! but still needs some tweaking.
        I find it first works with a new fresh startup screen. but then the more experimenting I do with Blend the more inconsistant the results become, finally the Bend of the left Y's in the picture did not take place at all.
        Error; #<NoMethodError; undefined method `vertices' for nil;NilClass>
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/sublend.rb;45;in `blend'
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/sublend.rb;174
        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/sublend.rb;153;in `call'
        please don't give up!
        my plugins
        tomot
          kirill2008
          Color blending demo video (for Daniel S πŸ˜‰ 😞
          [flash=425,344:1ki2zgl4]http://www.youtube.com/v/CqqRssCqONk&hl=ru&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:1ki2zgl4]
          cosycat, please try ver. 1.5. I tried to solve the problem of missing mesh pieces.
          tomot, I'll try to find out, what's the problem with rotated Y's...
          And speaking about the 3'd curve (the path): looks like, it demands a kind of major refactoring πŸ˜• It is more complex task than I thought and it will take a little time...
            tomot
            I don't want you to misunderstand. This is not only related to the "y" shape. Other shapes have produced the same inconsistent results in SU 7.
            another example:
            make 2 identical closed shapes, scale one larger, apply bend, same code error occurs
            cheers.
            my plugins
            tomot
              kirill2008
              another example:
              Looks like it is SU7 issue... SU6 processes correctly:
              [flash=425,344:1p1mvbbo]http://www.youtube.com/v/1D8WUYsS9hw&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:1p1mvbbo]
              When processing faces it is necessary to select them by single click (not a fence).
              • majidM Offline
                majid
                woooow...it would be a dreamy plugin if no bugs!!..I gave it a try , but it seems that previous versions were better on freehand lines, while the last version doesn't works fine... also on closed line doesn;t works at all (su 6)..seeing forward to see the improvements mate btw thanks thanx thanx! πŸ‘
                  This is a useful plugin. Well, for me it was until I installed the latest version (1.5). Now I get what you see in the attached screen shot. Unfortunately I installed over the previous version. Keep working at it. I'm sure you'll get it all working.
                  Thank you.
                    Daniel S
                    Thank you for adding color blending 😍 😍 😍
                    I have problems with this new version too (I use SU7).
                    Sometimes work with results like the ones Dave R post above.
                    In other cases the plugin dosenΒ΄t do anything and prints this in the ruby console:
                    Error: #<NoMethodError: undefined method back_material' for #<Sketchup::Edge:0x67b7f70>> C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:68:in blend'
                    C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:270
                    C:/Archivos de programa/Google/Google SketchUp 7/Plugins/sublend.rb:248:in `call'
                    Daniel S
                    • W Offline
                      watkins
                      Dear Kirill,
                      It might be a good idea to post versions 1.0 to 1.5 as the later versions seem to be problematic. Version 1.0 seemed to work quite nicely. I too have over-written previous versions and so cannot go back a step or two.
                      Kind regards,
                      Bob
                      • W Offline
                        watkins
                        Dear Kirill,
                        Version 5 doesn't seem to work in SU Pro 7, even for simple shapes, but don't give up.
                        • W Offline
                          watkins
                          Thanks for posting versions 1.2 and 1.4. I will test them out with areas. Previously, I only tested this plugin with arcs, and that still works in V1.5.
                            blajnov
                            @watkins said:
                            Dear Kirill,
                            Kind regards,
                            Bob
                            There are three previous versions:
                            v 1.2
                            v 1.3
                            v 1.4
                            Rename files in sublend.rb
                            sublend__1.2.rb
                            sublend_1.4.rb
                            sublend_1.3.rb
                              kirill2008
                              Guys, I don't know yet how to prevent skin (mesh) turning inside out 😞 The point is that script processes vertices with corresponding indices: so maybe flipping normal or 180 degrees rotation (or 90) of one of 2 faces may help.
                              Missing triangles (they vanished after color blending feature addition) have come back now πŸ˜„ (ver. 1.6)
                              Error messages kind of "undefined method `back_material' for... " debugged (I guess πŸ˜„ ).
                              • W Offline
                                watkins
                                Dear Kirill,
                                Here is a quick question. You mention Sketchup 6 in both the first post and in the introduction to your plugin. Does this plugin work well in version 6? Many people have migrated to version 7, although with little added benefit.
                                Keep going, you are doing a great job.
                                Kind regards,
                                Bob
                                  cosycat
                                  Thanks for all of the updates, this is really getting there. I have noticed that the result (v6) does depend on the order in which the points are drawn (for closed shapes at least) - this might explain some of the inside out results people are getting.
                                  Quick example, the numbers show the order in which the upper shape points were added
                                    kirill2008
                                    Ver 1.6 demo videos:
                                    Filtration capabilities video:
                                    [flash=425,344:17c3bm6v]http://www.youtube.com/v/Pml0gn-5fuY&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                                    Blending between different types of entities demo:
                                    [flash=425,344:17c3bm6v]http://www.youtube.com/v/0gchAp7Yje8&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                                    Fixing inside out problem variant:
                                    [flash=425,344:17c3bm6v]http://www.youtube.com/v/6PvRKfzm-g4&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:17c3bm6v]
                                    As cosycat mentioned:
                                    • olisheaO Offline
                                      olishea
                                      WOW. This is an awesome plugin. I tried using skin.rb for meshing between edges but it never worked for mac (i think). so im glad you can do it with this plugin!!
                                      Amazing work, one of the best plugins around. the modeling possibilities are endless, I'm loving it!
                                      oli
                                      • utilerU Offline
                                        utiler
                                        Kirill2008,
                                        Have you thought about adding a path function to this script?
                                        [see attached]
                                        Your generosity is much appreciated, I only wish I knew ruby too so I could reply the favor....
                                        Just Curious...
                                          kirill2008
                                          Yes, I think about it almost every day (and some times night πŸ˜„ too). I want to add a path processing very much, but it looks like such task is less obvious than already implemented algorithm. And maybe it's better to make a brand-new plugin with path processing, because it will work the other way than existing plugin.
                                          Ver. 1.7. demo video, shows blending between face and construction point and context menu "Blend" command usage.
                                          [flash=425,344:269yb5p5]http://www.youtube.com/v/-dfMofxc3pw&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:269yb5p5]
                                          I don't know yet how to implement custumization of context menu items, so "Blend" command appears always when more than 1 object is selected
                                          • kenK Offline
                                            ken
                                            Not sure how you are fixing the inside out problem. I can't tell exactly what you are doing. Could you please try again?
                                            Thanks in advance
                                            Ken
                                            • 2 / 4
