    Flags on onKeyDown?
    21 Posts 8 Posters 2.7k Views 8 Watching
    • Chris FullmerC Offline
      The flags are (as best as I could ever tell)
      1 = left mouse button down
      2 = right mouse button down
      4 = shift down
      8 = ctrl down
      16 = ?
      32 = alt down
      Then add them together to determine if the user has more than one key down. So shift + ctrl would give a flag of 12. Alt + ctrl gives a flag of 40. All of them down together give a flag of 47 (not including 16. I can't find 16, so I can't press it).
      Now, I don't know how to use that info in a script though. Sorry, I probably didn't help very much. Can you think of a good way to examine the flag 47 and decide what keys that means are being held down?
        Jim
        Well, it's a bit field. So using your information...
        47.to_s(2)
        101111
        Each position in the binary would represent a key state.
        1 - left mouse on
        0 - right mouse off
        1 - shift on
        1 - ctrl on
        1 - ?
        1 - alt on
        But my problem is the flag value does not change if I have the SHIFT key down or not, when I think it should. Maybe I'm making bad assumptions.
          didn't know you could convert to binary that way. neat.
            Oh, here's a thought. onKeyDown/Up use the "key" argument, while the others (onMouseMove, onRButtonDown, etc) use the "flag" argument. So with onkeyup, its not really a flag, but a keycode or keyID, whereas the other methods return a flag using the system I described above.
            Don't know how that changes things....
              tomasz
              What would be the best way to read the CTRL key in Win and its corresponding key on MAC. I am writing about a case without creating a new tool.
              I would like to read a state of CTRL key when an user presses a toolbar icon.
              Tomasz
              • W Offline
                wikii
                if (flags & 4)==4
                shift=true
                  Jim
                  Ah, so maybe that is what these constants are for?
                  ["CONSTRAIN_MODIFIER_KEY", "CONSTRAIN_MODIFIER_MASK", "ALT_MODIFIER_KEY", "ALT_MODIFIER_MASK", "COPY_MODIFIER_KEY", "COPY_MODIFIER_MASK"]
                    tomasz
                    .. I am writing about a case without creating a new tool.
                    Actually creating a tool in not a big deal, but I thought there is a way to omit that.
                    In SU2KT there is no need for creating the tool and all necessary methods to handle it.
                    I just need to read a state of CTRL\MENU key upon the start-up of the plugin.
                      Jim
                      Can't be done, as far as I know. I agree it would be nice.
                        tomasz
                        class SU2KT_key
                        	def SU2KT_key;;key_pressed?
                        		@key
                        	def SU2KT_key;;activate
                        		@key=false
                        	def SU2KT_key;;onKeyDown(key, repeat, flags, view)
                        		@key=(key==COPY_MODIFIER_KEY)
                        		puts @key
                        keytool=SU2KT_key.new
                        Sketchup.active_model.select_tool SU2KT_key
                        sleep 1
                        puts SU2KT_key.key_pressed?
                        Why does it always give me 'false' on reload of the script? It looks that SU doesn't check the keyboard on creation of a new tool, otherwise I would get the @key value BEFORE sleep 1. Am I right?
                        Tomasz
                        • fredo6F Offline
                          Did you try with the event OnMouseMove, which has a flags argument too?
                            BTM
                            … This is a bit off-topic, but on windows
                            ` class Flagtest
                            def onMouseMove(flags,x,y,view)
                            UI.messagebox flags
                            Sketchup.active_model.select_tool Flagtest.new`
                            will come up with 0 on mouse move, if no keys are pressed. on my mac, it's 256. Any idea why?
                            update:
                            Also, onMouseMove only activates when the mouse moves in the model area, so it wouldn't activate on startup of the plugin.
                              ok, I am using the "flags" parameter of the onLButtonUp method to determine ctrl, alt key status. This is my code so far. It works, but I have a feeling it could be optimized. I really don't manipulate strings very well. I nearly turned it all into an array.
                              ` def onLButtonUp(flags, x, y, view)
                              flag_bin = flags.to_s(2)
                              flag_bin_to_add = 6 - flag_bin.length
                              zeros = "0"*flag_bin_to_add
                              adjusted_flag = (zeros + flag_bin).reverse
                              ctrlk = true if adjusted_flag[3,1] == "1"
                              altk = true if adjusted_flag[5,1] == "1"`
                              So I take the flag, turn it into binary as Jim showed. But a value less than 32 makes a binary with less than 6 digits in it. So if the user is holding alt, then a 6 digit binary is given. If they are holding ctrl, then only a 4 digit binary is given. So I am adding zeros to the binary string, then reversing it because I like the binary to be ordered according to the numerical representations for each key, lowest number key on the left, highest number key on the right.
                              Then I set my variables to be true if their binary digit is true, indicating that their key was pressed.
                              I hope that makes sense. Again, this seems to work great. But it feels klunky. Is there an easier way to parse the bit field?
                              Any optimization ideas?
                              ps - I tacked it onto this thread since this thread is what pointed me in the direction of how to work with the "flags" parameter.
                                shift = (flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK
                                Use the & for bitwise comparison.
                                  I don't quite understand what that means. What is bitwise?
                                    Bitwise operation - Wikipedia
                                    (en.wikipedia.org)
                                      Nice little list of Ruby's operators http://www.tutorialspoint.com/ruby/ruby_operators.htm
                                        MartinRinehart
                                        @chris fullmer said:
                                        flag_bin = flags.to_s(2) flag_bin_to_add = 6 - flag_bin.length zeros = "0"*flag_bin_to_add adjusted_flag = (zeros + flag_bin).reverse
                                        Stick in a non-zero bit to the left of the flags.
                                        Quickly: (flags | 128).to_s(2)[2..7].reverse
                                        Slowly:
                                        flags
                                                # 00bbbbbb
                                        flags | 128
                                                # 10bbbbbb
                                                # 8-char string version
                                                # the 6 chars your really want
                                          Converting to string is very inefficient.
                                            Jim
                                            Think in binary, then compare them column for column. It's a logical, bit-to-bit comparison.
                                            5 in binary is 101
                                            6 in binary is 110
                                            5 & 6 is; logical AND each column (bit position)
                                                Columns
                                            ________________
                                            |  1  |  0  |  1   <- decimal 5
                                            | and | and | and
                                            |  1  |  1  |  0   <- decimal 6
                                               1     0     0
                                            so 101 & 110 = 100 <- decimal 4
                                            The masks are constants, which are set to some convenient values:
                                            # I just made these up
                                            001 = CONSTRAIN_MASK
                                            010 = ALT_MASK
                                            100 = COPY_MASK
                                            So if the flag is decimal value 7:
                                            111  <- decimal 7
                                            In order to check the CONSTRAIN_MASK, you logical AND the CONSTRAIN_MASK with the flag value:
                                                111  <- flag value decimal 7
                                              & 001  <- contain mask constant
                                                001 <- CONSTRAIN_MASK set true
                                            or in real ruby as Thomas wrote;
                                            contrain_key_down = ((flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK)
                                            copy_key_down = ((flags & COPY_MODIFIER_MASK) == COPY_MODIFIER_MASK)
                                            alt_key_down = ((flags & ALT_MODIFIER_MASK) == ALT_MODIFIER_MASK)
                                            Although Adam B might know a clever way to decode them all in one elegant statement.
