    Flags on onKeyDown?
    21 Posts 8 Posters 1.8k Views 8 Watching
      Jim
      Can anyone explain to me the flags argument for the onKeyDown method. I had assumed it would have a certain, predictable value when the one of the modifier keys was being help down, but it doesn't make any sense to me.
      I am trying to avoid code like the following:
       if key == VK_SHIFT
         @shift = true
       if key == VK_CONTROL
         @ctrl = true
      • Chris FullmerC Offline
        The flags are (as best as I could ever tell)
        1 = left mouse button down
        2 = right mouse button down
        4 = shift down
        8 = ctrl down
        16 = ?
        32 = alt down
        Then add them together to determine if the user has more than one key down. So shift + ctrl would give a flag of 12. Alt + ctrl gives a flag of 40. All of them down together give a flag of 47 (not including 16. I can't find 16, so I can't press it).
        Now, I don't know how to use that info in a script though. Sorry, I probably didn't help very much. Can you think of a good way to examine the flag 47 and decide what keys that means are being held down?
          Jim
          Well, it's a bit field. So using your information...
          47.to_s(2)
          101111
          Each position in the binary would represent a key state.
          1 - left mouse on
          0 - right mouse off
          1 - shift on
          1 - ctrl on
          1 - ?
          1 - alt on
          But my problem is the flag value does not change if I have the SHIFT key down or not, when I think it should. Maybe I'm making bad assumptions.
            didn't know you could convert to binary that way. neat.
              Oh, here's a thought. onKeyDown/Up use the "key" argument, while the others (onMouseMove, onRButtonDown, etc) use the "flag" argument. So with onkeyup, its not really a flag, but a keycode or keyID, whereas the other methods return a flag using the system I described above.
              Don't know how that changes things....
                tomasz
                What would be the best way to read the CTRL key in Win and its corresponding key on MAC. I am writing about a case without creating a new tool.
                I would like to read a state of CTRL key when an user presses a toolbar icon.
                Tomasz
                Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                • W Offline
                  wikii
                  if (flags & 4)==4
                  shift=true
                    Jim
                    Ah, so maybe that is what these constants are for?
                    ["CONSTRAIN_MODIFIER_KEY", "CONSTRAIN_MODIFIER_MASK", "ALT_MODIFIER_KEY", "ALT_MODIFIER_MASK", "COPY_MODIFIER_KEY", "COPY_MODIFIER_MASK"]
                      tomasz
                      .. I am writing about a case without creating a new tool.
                      Actually creating a tool in not a big deal, but I thought there is a way to omit that.
                      In SU2KT there is no need for creating the tool and all necessary methods to handle it.
                      I just need to read a state of CTRL\MENU key upon the start-up of the plugin.
                        Jim
                        Can't be done, as far as I know. I agree it would be nice.
                          tomasz
                          class SU2KT_key
                          	def SU2KT_key;;key_pressed?
                          		@key
                          	def SU2KT_key;;activate
                          		@key=false
                          	def SU2KT_key;;onKeyDown(key, repeat, flags, view)
                          		@key=(key==COPY_MODIFIER_KEY)
                          		puts @key
                          keytool=SU2KT_key.new
                          Sketchup.active_model.select_tool SU2KT_key
                          sleep 1
                          puts SU2KT_key.key_pressed?
                          Why does it always give me 'false' on reload of the script? It looks that SU doesn't check the keyboard on creation of a new tool, otherwise I would get the @key value BEFORE sleep 1. Am I right?
                          Tomasz
                          • fredo6F Offline
                            Did you try with the event OnMouseMove, which has a flags argument too?
                              BTM
                              … This is a bit off-topic, but on windows
                              ` class Flagtest
                              def onMouseMove(flags,x,y,view)
                              UI.messagebox flags
                              Sketchup.active_model.select_tool Flagtest.new`
                              will come up with 0 on mouse move, if no keys are pressed. on my mac, it's 256. Any idea why?
                              update:
                              Also, onMouseMove only activates when the mouse moves in the model area, so it wouldn't activate on startup of the plugin.
                                ok, I am using the "flags" parameter of the onLButtonUp method to determine ctrl, alt key status. This is my code so far. It works, but I have a feeling it could be optimized. I really don't manipulate strings very well. I nearly turned it all into an array.
                                ` def onLButtonUp(flags, x, y, view)
                                flag_bin = flags.to_s(2)
                                flag_bin_to_add = 6 - flag_bin.length
                                zeros = "0"*flag_bin_to_add
                                adjusted_flag = (zeros + flag_bin).reverse
                                ctrlk = true if adjusted_flag[3,1] == "1"
                                altk = true if adjusted_flag[5,1] == "1"`
                                So I take the flag, turn it into binary as Jim showed. But a value less than 32 makes a binary with less than 6 digits in it. So if the user is holding alt, then a 6 digit binary is given. If they are holding ctrl, then only a 4 digit binary is given. So I am adding zeros to the binary string, then reversing it because I like the binary to be ordered according to the numerical representations for each key, lowest number key on the left, highest number key on the right.
                                Then I set my variables to be true if their binary digit is true, indicating that their key was pressed.
                                I hope that makes sense. Again, this seems to work great. But it feels klunky. Is there an easier way to parse the bit field?
                                Any optimization ideas?
                                ps - I tacked it onto this thread since this thread is what pointed me in the direction of how to work with the "flags" parameter.
                                  shift = (flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK
                                  Use the & for bitwise comparison.
                                    I don't quite understand what that means. What is bitwise?
                                      Bitwise operation - Wikipedia
                                      (en.wikipedia.org)
                                        Nice little list of Ruby's operators http://www.tutorialspoint.com/ruby/ruby_operators.htm
                                          MartinRinehart
                                          @chris fullmer said:
                                          flag_bin = flags.to_s(2) flag_bin_to_add = 6 - flag_bin.length zeros = "0"*flag_bin_to_add adjusted_flag = (zeros + flag_bin).reverse
                                          Stick in a non-zero bit to the left of the flags.
                                          Quickly: (flags | 128).to_s(2)[2..7].reverse
                                          Slowly:
                                          flags
                                                  # 00bbbbbb
                                          flags | 128
                                                  # 10bbbbbb
                                                  # 8-char string version
                                                  # the 6 chars your really want
                                            Converting to string is very inefficient.
