    Flags on onKeyDown?
    21 Posts 8 Posters 3.4k Views 8 Watching
    • fredo6F
      I just need to read a state of CTRL\MENU key upon the start-up of the plugin.
      Did you try with the event OnMouseMove, which has a flags argument too?
      • B
        BTM
        … This is a bit off-topic, but on windows
        ` class Flagtest
        def onMouseMove(flags,x,y,view)
        UI.messagebox flags
        Sketchup.active_model.select_tool Flagtest.new`
        will come up with 0 on mouse move, if no keys are pressed. on my mac, it's 256. Any idea why?
        update:
        Also, onMouseMove only activates when the mouse moves in the model area, so it wouldn't activate on startup of the plugin.
        • Chris FullmerC
          ok, I am using the "flags" parameter of the onLButtonUp method to determine ctrl, alt key status. This is my code so far. It works, but I have a feeling it could be optimized. I really don't manipulate strings very well. I nearly turned it all into an array.
          ` def onLButtonUp(flags, x, y, view)
          flag_bin = flags.to_s(2)
          flag_bin_to_add = 6 - flag_bin.length
          zeros = "0"*flag_bin_to_add
          adjusted_flag = (zeros + flag_bin).reverse
          ctrlk = true if adjusted_flag[3,1] == "1"
          altk = true if adjusted_flag[5,1] == "1"`
          So I take the flag, turn it into binary as Jim showed. But a value less than 32 makes a binary with less than 6 digits in it. So if the user is holding alt, then a 6 digit binary is given. If they are holding ctrl, then only a 4 digit binary is given. So I am adding zeros to the binary string, then reversing it because I like the binary to be ordered according to the numerical representations for each key, lowest number key on the left, highest number key on the right.
          Then I set my variables to be true if their binary digit is true, indicating that their key was pressed.
          I hope that makes sense. Again, this seems to work great. But it feels klunky. Is there an easier way to parse the bit field?
          Any optimization ideas?
          ps - I tacked it onto this thread since this thread is what pointed me in the direction of how to work with the "flags" parameter.
            shift = (flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK
            Use the & for bitwise comparison.
            • Chris FullmerC
              I don't quite understand what that means. What is bitwise?
                http://en.wikipedia.org/wiki/Bitwise_operation
                  Nice little list of Ruby's operators http://www.tutorialspoint.com/ruby/ruby_operators.htm
                    MartinRinehart
                    @chris fullmer said:
                    flag_bin = flags.to_s(2) flag_bin_to_add = 6 - flag_bin.length zeros = "0"*flag_bin_to_add adjusted_flag = (zeros + flag_bin).reverse
                    Stick in a non-zero bit to the left of the flags.
                    Quickly: (flags | 128).to_s(2)[2..7].reverse
                    Slowly:
                    flags
                            # 00bbbbbb
                    flags | 128
                            # 10bbbbbb
                            # 8-char string version
                            # the 6 chars your really want
                      Converting to string is very inefficient.
                        Jim
                        Think in binary, then compare them column for column. It's a logical, bit-to-bit comparison.
                        5 in binary is 101
                        6 in binary is 110
                        5 & 6 is; logical AND each column (bit position)
                            Columns
                        ________________
                        |  1  |  0  |  1   <- decimal 5
                        | and | and | and
                        |  1  |  1  |  0   <- decimal 6
                           1     0     0
                        so 101 & 110 = 100 <- decimal 4
                        The masks are constants, which are set to some convenient values:
                        # I just made these up
                        001 = CONSTRAIN_MASK
                        010 = ALT_MASK
                        100 = COPY_MASK
                        So if the flag is decimal value 7:
                        111  <- decimal 7
                        In order to check the CONSTRAIN_MASK, you logical AND the CONSTRAIN_MASK with the flag value:
                            111  <- flag value decimal 7
                          & 001  <- contain mask constant
                            001 <- CONSTRAIN_MASK set true
                        or in real ruby as Thomas wrote;
                        contrain_key_down = ((flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK)
                        copy_key_down = ((flags & COPY_MODIFIER_MASK) == COPY_MODIFIER_MASK)
                        alt_key_down = ((flags & ALT_MODIFIER_MASK) == ALT_MODIFIER_MASK)
                        Although Adam B might know a clever way to decode them all in one elegant statement.
                        • 2 / 2
