    Flags on onKeyDown?
    21 Posts 8 Posters 3.1k Views 8 Watching
      Jim
      Ah, so maybe that is what these constants are for?
      ["CONSTRAIN_MODIFIER_KEY", "CONSTRAIN_MODIFIER_MASK", "ALT_MODIFIER_KEY", "ALT_MODIFIER_MASK", "COPY_MODIFIER_KEY", "COPY_MODIFIER_MASK"]
        tomasz
        .. I am writing about a case without creating a new tool.
        Actually creating a tool in not a big deal, but I thought there is a way to omit that.
        In SU2KT there is no need for creating the tool and all necessary methods to handle it.
        I just need to read a state of CTRL\MENU key upon the start-up of the plugin.
          Jim
          Can't be done, as far as I know. I agree it would be nice.
            tomasz
            class SU2KT_key
            	def SU2KT_key;;key_pressed?
            		@key
            	def SU2KT_key;;activate
            		@key=false
            	def SU2KT_key;;onKeyDown(key, repeat, flags, view)
            		@key=(key==COPY_MODIFIER_KEY)
            		puts @key
            keytool=SU2KT_key.new
            Sketchup.active_model.select_tool SU2KT_key
            sleep 1
            puts SU2KT_key.key_pressed?
            Why does it always give me 'false' on reload of the script? It looks that SU doesn't check the keyboard on creation of a new tool, otherwise I would get the @key value BEFORE sleep 1. Am I right?
            Tomasz
            • fredo6F Offline
              Did you try with the event OnMouseMove, which has a flags argument too?
                BTM
                … This is a bit off-topic, but on windows
                ` class Flagtest
                def onMouseMove(flags,x,y,view)
                UI.messagebox flags
                Sketchup.active_model.select_tool Flagtest.new`
                will come up with 0 on mouse move, if no keys are pressed. on my mac, it's 256. Any idea why?
                update:
                Also, onMouseMove only activates when the mouse moves in the model area, so it wouldn't activate on startup of the plugin.
                • Chris FullmerC Offline
                  ok, I am using the "flags" parameter of the onLButtonUp method to determine ctrl, alt key status. This is my code so far. It works, but I have a feeling it could be optimized. I really don't manipulate strings very well. I nearly turned it all into an array.
                  ` def onLButtonUp(flags, x, y, view)
                  flag_bin = flags.to_s(2)
                  flag_bin_to_add = 6 - flag_bin.length
                  zeros = "0"*flag_bin_to_add
                  adjusted_flag = (zeros + flag_bin).reverse
                  ctrlk = true if adjusted_flag[3,1] == "1"
                  altk = true if adjusted_flag[5,1] == "1"`
                  So I take the flag, turn it into binary as Jim showed. But a value less than 32 makes a binary with less than 6 digits in it. So if the user is holding alt, then a 6 digit binary is given. If they are holding ctrl, then only a 4 digit binary is given. So I am adding zeros to the binary string, then reversing it because I like the binary to be ordered according to the numerical representations for each key, lowest number key on the left, highest number key on the right.
                  Then I set my variables to be true if their binary digit is true, indicating that their key was pressed.
                  I hope that makes sense. Again, this seems to work great. But it feels klunky. Is there an easier way to parse the bit field?
                  Any optimization ideas?
                  ps - I tacked it onto this thread since this thread is what pointed me in the direction of how to work with the "flags" parameter.
                    shift = (flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK
                    Use the & for bitwise comparison.
                      I don't quite understand what that means. What is bitwise?
                        http://en.wikipedia.org/wiki/Bitwise_operation
                          Nice little list of Ruby's operators http://www.tutorialspoint.com/ruby/ruby_operators.htm
                            MartinRinehart
                            @chris fullmer said:
                            flag_bin = flags.to_s(2) flag_bin_to_add = 6 - flag_bin.length zeros = "0"*flag_bin_to_add adjusted_flag = (zeros + flag_bin).reverse
                            Stick in a non-zero bit to the left of the flags.
                            Quickly: (flags | 128).to_s(2)[2..7].reverse
                            Slowly:
                            flags
                                    # 00bbbbbb
                            flags | 128
                                    # 10bbbbbb
                                    # 8-char string version
                                    # the 6 chars your really want
                              Converting to string is very inefficient.
                                Jim
                                Think in binary, then compare them column for column. It's a logical, bit-to-bit comparison.
                                5 in binary is 101
                                6 in binary is 110
                                5 & 6 is; logical AND each column (bit position)
                                    Columns
                                ________________
                                |  1  |  0  |  1   <- decimal 5
                                | and | and | and
                                |  1  |  1  |  0   <- decimal 6
                                   1     0     0
                                so 101 & 110 = 100 <- decimal 4
                                The masks are constants, which are set to some convenient values:
                                # I just made these up
                                001 = CONSTRAIN_MASK
                                010 = ALT_MASK
                                100 = COPY_MASK
                                So if the flag is decimal value 7:
                                111  <- decimal 7
                                In order to check the CONSTRAIN_MASK, you logical AND the CONSTRAIN_MASK with the flag value:
                                    111  <- flag value decimal 7
                                  & 001  <- contain mask constant
                                    001 <- CONSTRAIN_MASK set true
                                or in real ruby as Thomas wrote;
                                contrain_key_down = ((flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK)
                                copy_key_down = ((flags & COPY_MODIFIER_MASK) == COPY_MODIFIER_MASK)
                                alt_key_down = ((flags & ALT_MODIFIER_MASK) == ALT_MODIFIER_MASK)
                                Although Adam B might know a clever way to decode them all in one elegant statement.
