    Flags on onKeyDown?
    21 Posts 8 Posters 3.1k Views 8 Watching
      didn't know you could convert to binary that way. neat.
      • Chris FullmerC Offline
        Oh, here's a thought. onKeyDown/Up use the "key" argument, while the others (onMouseMove, onRButtonDown, etc) use the "flag" argument. So with onkeyup, its not really a flag, but a keycode or keyID, whereas the other methods return a flag using the system I described above.
        Don't know how that changes things....
          tomasz
          What would be the best way to read the CTRL key in Win and its corresponding key on MAC. I am writing about a case without creating a new tool.
          I would like to read a state of CTRL key when an user presses a toolbar icon.
          Tomasz
          • W Offline
            wikii
            if (flags & 4)==4
            shift=true
              Jim
              Ah, so maybe that is what these constants are for?
              ["CONSTRAIN_MODIFIER_KEY", "CONSTRAIN_MODIFIER_MASK", "ALT_MODIFIER_KEY", "ALT_MODIFIER_MASK", "COPY_MODIFIER_KEY", "COPY_MODIFIER_MASK"]
                tomasz
                .. I am writing about a case without creating a new tool.
                Actually creating a tool in not a big deal, but I thought there is a way to omit that.
                In SU2KT there is no need for creating the tool and all necessary methods to handle it.
                I just need to read a state of CTRL\MENU key upon the start-up of the plugin.
                  Jim
                  Can't be done, as far as I know. I agree it would be nice.
                    tomasz
                    class SU2KT_key
                    	def SU2KT_key;;key_pressed?
                    		@key
                    	def SU2KT_key;;activate
                    		@key=false
                    	def SU2KT_key;;onKeyDown(key, repeat, flags, view)
                    		@key=(key==COPY_MODIFIER_KEY)
                    		puts @key
                    keytool=SU2KT_key.new
                    Sketchup.active_model.select_tool SU2KT_key
                    sleep 1
                    puts SU2KT_key.key_pressed?
                    Why does it always give me 'false' on reload of the script? It looks that SU doesn't check the keyboard on creation of a new tool, otherwise I would get the @key value BEFORE sleep 1. Am I right?
                    Tomasz
                    • fredo6F Offline
                      Did you try with the event OnMouseMove, which has a flags argument too?
                        BTM
                        … This is a bit off-topic, but on windows
                        ` class Flagtest
                        def onMouseMove(flags,x,y,view)
                        UI.messagebox flags
                        Sketchup.active_model.select_tool Flagtest.new`
                        will come up with 0 on mouse move, if no keys are pressed. on my mac, it's 256. Any idea why?
                        update:
                        Also, onMouseMove only activates when the mouse moves in the model area, so it wouldn't activate on startup of the plugin.
                          ok, I am using the "flags" parameter of the onLButtonUp method to determine ctrl, alt key status. This is my code so far. It works, but I have a feeling it could be optimized. I really don't manipulate strings very well. I nearly turned it all into an array.
                          ` def onLButtonUp(flags, x, y, view)
                          flag_bin = flags.to_s(2)
                          flag_bin_to_add = 6 - flag_bin.length
                          zeros = "0"*flag_bin_to_add
                          adjusted_flag = (zeros + flag_bin).reverse
                          ctrlk = true if adjusted_flag[3,1] == "1"
                          altk = true if adjusted_flag[5,1] == "1"`
                          So I take the flag, turn it into binary as Jim showed. But a value less than 32 makes a binary with less than 6 digits in it. So if the user is holding alt, then a 6 digit binary is given. If they are holding ctrl, then only a 4 digit binary is given. So I am adding zeros to the binary string, then reversing it because I like the binary to be ordered according to the numerical representations for each key, lowest number key on the left, highest number key on the right.
                          Then I set my variables to be true if their binary digit is true, indicating that their key was pressed.
                          I hope that makes sense. Again, this seems to work great. But it feels klunky. Is there an easier way to parse the bit field?
                          Any optimization ideas?
                          ps - I tacked it onto this thread since this thread is what pointed me in the direction of how to work with the "flags" parameter.
                            shift = (flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK
                            Use the & for bitwise comparison.
                              I don't quite understand what that means. What is bitwise?
                                http://en.wikipedia.org/wiki/Bitwise_operation
                                  Nice little list of Ruby's operators http://www.tutorialspoint.com/ruby/ruby_operators.htm
                                    MartinRinehart
                                    @chris fullmer said:
                                    flag_bin = flags.to_s(2) flag_bin_to_add = 6 - flag_bin.length zeros = "0"*flag_bin_to_add adjusted_flag = (zeros + flag_bin).reverse
                                    Stick in a non-zero bit to the left of the flags.
                                    Quickly: (flags | 128).to_s(2)[2..7].reverse
                                    Slowly:
                                    flags
                                            # 00bbbbbb
                                    flags | 128
                                            # 10bbbbbb
                                            # 8-char string version
                                            # the 6 chars your really want
                                      Converting to string is very inefficient.
                                        Jim
                                        Think in binary, then compare them column for column. It's a logical, bit-to-bit comparison.
                                        5 in binary is 101
                                        6 in binary is 110
                                        5 & 6 is; logical AND each column (bit position)
                                            Columns
                                        ________________
                                        |  1  |  0  |  1   <- decimal 5
                                        | and | and | and
                                        |  1  |  1  |  0   <- decimal 6
                                           1     0     0
                                        so 101 & 110 = 100 <- decimal 4
                                        The masks are constants, which are set to some convenient values:
                                        # I just made these up
                                        001 = CONSTRAIN_MASK
                                        010 = ALT_MASK
                                        100 = COPY_MASK
                                        So if the flag is decimal value 7:
                                        111  <- decimal 7
                                        In order to check the CONSTRAIN_MASK, you logical AND the CONSTRAIN_MASK with the flag value:
                                            111  <- flag value decimal 7
                                          & 001  <- contain mask constant
                                            001 <- CONSTRAIN_MASK set true
                                        or in real ruby as Thomas wrote;
                                        contrain_key_down = ((flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK)
                                        copy_key_down = ((flags & COPY_MODIFIER_MASK) == COPY_MODIFIER_MASK)
                                        alt_key_down = ((flags & ALT_MODIFIER_MASK) == ALT_MODIFIER_MASK)
                                        Although Adam B might know a clever way to decode them all in one elegant statement.
