    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • B
      Ben Ritter
      Didier,
      Fantastic tools! Thank you very much.
      • O
        otb designworks
        @didier bur said:
        Hi Chuck,
        It seems you have the same problem than rv1974. An "uninitialized constant" error message means that the script within the "Projection" folder is not loaded, and an "undefined method" error message too. Check for the file "projection.rbs" in the Projection" sub-folder of plugins. Please tell me if it is there. πŸŽ‰
        Hi Didier, thanks for the quick response.
        Yes, the projection.rbs is in the projection folder.
        I trashed the file and still no functionality. I have nothing but png's and the projection.pdf filesin the projection folder and still the same error messages. I tried placing the rbs file back in and still nothing works.
        thanks for the help
        Cheers, Chuck
        Cheers, Chuck
        OTB Designworks is on Youtube
        • takesh hT
          takesh h
          Hi Didier, this looks like another sweeeet update, however with my iMac nothing so far works.
          My situation is just like Chuck's, they don't seem like doing anything whatsoever upon my clicking icons.
          I've been using Projection tools for the longest time and am very familiar with how they work.
          They have been doing beautifully until I updated to ver.2.
          I clean-installed them as well.
          I just noticed that if I install them in [HD]-[user]-[username]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin],
          instead of usual [HD]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin], everything works.
          Hope this will be fixed... Thanks in advance!
          • Bob JamesB
            Bob James
            I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
            The same is true for Profile Builder (for me, at least)
              rv1974
              @didier bur said:
              Another thing: Could you add multiple not connected edges extrusion?
              You can do that already. Select unconnected edges as you would do with connected edges !
              You simply turned me into francophil 😍
              http://www.youtube.com/watch?v=ye0_QCUgwO4&eurl=http%3A%2F%2Fdirty.ru%2Fcomments%2F255512&feature=player_embedded
                πŸ’š
                • O
                  otb designworks
                  This works for me as well! Thanks guys, I had forgotten that some scripts just don't like the "regular" library location.
                  Cheers, chuck
                  Cheers, Chuck
                  • Didier BurD
                    Didier Bur
                    Were you francophobe ??? 🀣
                    I'm far from an expert in MacOs, but this sounds to me to be like when on Windows you install some software for "all users" or for just one user.
                    I'll put that in the doc. Thanks for the tip !
                    DB
                    • EdsonE
                      Edson
                      thanks, didier. a great plugin has become even better!
                      http://www.mahfuz.arq.br
                        rv1974
                        Nope I was francophag πŸ˜„
                          Didier
                          It occurs to me that my recent tool cpointAtLineFaceIntersection.rb http://forums.sketchucation.com/viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit...
                          • JClementsJ
                            JClements
                            Didier:
                            Your last icon creates faces from a curve (a continuous curve), but the faces are not smoothed (like those created when push-pulling a circle or "welded" segments).
                            Wondering if you can incorporate this into another or the same tool?
                            What do others think. Good, bad, or unecessary?
                            • Didier BurD
                              Didier Bur
                              It occurs to me that my recent tool cpointAtLineFaceIntersection.rb viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset
                              That's just what I was going to ask you for ! Thanks for contributing πŸ‘
                              This feature is incorporated in the code actually, but apparently doesn't work every time 😳
                              I'll check that asap.
                              Regards,
                              DB
                              • C
                                cyan.archnet
                                THANK YOU!, will definitely try this updated plugin!
                                  accabrera
                                  πŸ‘ Thanks !!!
                                  • B
                                    boilingsnow
                                    thank you very much Didier Bur
                                    but you have probably forgotten to add the new images for the new buttons of the latest update. they are missing...
                                    • boofredlayB
                                      boofredlay
                                      Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
                                        define
                                        Yes agree - I was just about to send the very same screenshot, since I'm also missing 4 icons.
                                        anyway - thx a lot for your good work on this - absolutely amazing!
                                        • mitcorbM
                                          mitcorb
                                          I am also not seeing buttons 1, 5, 8, 9. If I mouse over these buttons their descriptions show up. I have not fully tested the functions yet. At first I thought the update would overwrite the previous. And then I reviewed the first post where you say to delete the previous, so I did that. However, the four mentioned buttons do not get their png's, which I believe are in the auxiliary folder.
                                          • Bob JamesB
                                            Bob James
                                            I see all the buttons, but agree that the surface is not smoothed
                                            • 3 / 8
