    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • kenK
      ken
      Didier
      Would it be possible to have a choice for Tools #6 and #7 to place either points or guide lines?
      Thanks for me a very useful plugin
      Ken
      • Didier BurD
        Didier Bur
        Hi Chuck,
        It seems you have the same problem than rv1974. An "uninitialized constant" error message means that the script within the "Projection" folder is not loaded, and an "undefined method" error message too. Check for the file "projection.rbs" in the Projection" sub-folder of plugins. Please tell me if it is there. πŸŽ‰
        DB
        • Didier BurD
          Didier Bur
          Another thing: Could you add multiple not connected edges extrusion?
          You can do that already. Select unconnected edges as you would do with connected edges !
          Insert Insert guides and guides at intervals at divisions, after using them, are active at the same starting point.
          the tool could be active. But choose a new edge?
          You can do that already too. After a first guides insertion, hit Enter to select a new edge (watch your status bar). Please read the doc folks ! πŸ˜„
          DB
          • urgenU
            urgen
            ...Thanks for update Didier,very useful. πŸ‘
            --pupil forever...------
            • B
              Ben Ritter
              Didier,
              Fantastic tools! Thank you very much.
              • O
                otb designworks
                @didier bur said:
                Hi Chuck,
                Hi Didier, thanks for the quick response.
                Yes, the projection.rbs is in the projection folder.
                I trashed the file and still no functionality. I have nothing but png's and the projection.pdf filesin the projection folder and still the same error messages. I tried placing the rbs file back in and still nothing works.
                thanks for the help
                Cheers, Chuck
                Cheers, Chuck
                OTB Designworks is on Youtube
                • takesh hT
                  takesh h
                  Hi Didier, this looks like another sweeeet update, however with my iMac nothing so far works.
                  My situation is just like Chuck's, they don't seem like doing anything whatsoever upon my clicking icons.
                  I've been using Projection tools for the longest time and am very familiar with how they work.
                  They have been doing beautifully until I updated to ver.2.
                  I clean-installed them as well.
                  I just noticed that if I install them in [HD]-[user]-[username]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin],
                  instead of usual [HD]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin], everything works.
                  Hope this will be fixed... Thanks in advance!
                  • Bob JamesB
                    Bob James
                    I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
                    The same is true for Profile Builder (for me, at least)
                      rv1974
                      You simply turned me into francophil 😍
                      http://www.youtube.com/watch?v=ye0_QCUgwO4&eurl=http%3A%2F%2Fdirty.ru%2Fcomments%2F255512&feature=player_embedded
                        πŸ’š
                        • O
                          otb designworks
                          This works for me as well! Thanks guys, I had forgotten that some scripts just don't like the "regular" library location.
                          Cheers, chuck
                          Cheers, Chuck
                          • Didier BurD
                            Didier Bur
                            Were you francophobe ??? 🀣
                            I'm far from an expert in MacOs, but this sounds to me to be like when on Windows you install some software for "all users" or for just one user.
                            I'll put that in the doc. Thanks for the tip !
                            DB
                            • EdsonE
                              Edson
                              thanks, didier. a great plugin has become even better!
                              http://www.mahfuz.arq.br
                                rv1974
                                Nope I was francophag πŸ˜„
                                  Didier
                                  It occurs to me that my recent tool cpointAtLineFaceIntersection.rb http://forums.sketchucation.com/viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit...
                                  • JClementsJ
                                    JClements
                                    Didier:
                                    Your last icon creates faces from a curve (a continuous curve), but the faces are not smoothed (like those created when push-pulling a circle or "welded" segments).
                                    Wondering if you can incorporate this into another or the same tool?
                                    What do others think. Good, bad, or unecessary?
                                    • Didier BurD
                                      Didier Bur
                                      It occurs to me that my recent tool cpointAtLineFaceIntersection.rb viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset
                                      That's just what I was going to ask you for ! Thanks for contributing πŸ‘
                                      This feature is incorporated in the code actually, but apparently doesn't work every time 😳
                                      I'll check that asap.
                                      Regards,
                                      DB
                                      • C
                                        cyan.archnet
                                        THANK YOU!, will definitely try this updated plugin!
                                          accabrera
                                          πŸ‘ Thanks !!!
                                          • B
                                            boilingsnow
                                            thank you very much Didier Bur
                                            but you have probably forgotten to add the new images for the new buttons of the latest update. they are missing...
                                            • 3 / 8
