    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 227.0k Views 61 Watching
    • Didier BurD Offline
      Didier Bur
      Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
      Regards,
      DB
      • massimoM Offline
        massimo Moderator
        Thanks Didier, now it works very well. πŸ‘
        • O Offline
          otb designworks
          I am using a MAC pro, and this version 2 has no functionality on my computer.
          Choosing any function has no effect whatsoever.
          I am attaching the errors indicated in the Ruby console.
          I have deleted all previous versions from my plug in folder.
          Thanks and help! I use these all the time, especially extrude lines, which is a god send sometimes.
          Cheers, Chuck
          Cheers, Chuck
          OTB Designworks is on Youtube
            rv1974
            Regards,
            Indeed it goes OK πŸ˜›
            Another thing: Could you add multiple not connected edges extrusion? It'd really add a lot
              DIEGO-RODRIGUEZ
              Thank you very much for update Didier.
              Three suggestion.
              a - be possible to customize the toolbar?for example Plugins 1001bit 1.1.6
              Leaving active in the toolbar only the tools I'm interested
              b - Erase guides, Could have an option to delete all guides of the drawing?
              c - Insert Insert guides and guides at intervals at divisions, after using them, are active at the same starting point.
              the tool could be active. But choose a new edge?
              http://img20.imageshack.us/img20/7672/sinttulo2qdv.jpg
              and a question.
              Achieve as the result of this picture?
              http://forums.sketchucation.com/download/file.php?id=29592&t=1
              • kenK Offline
                ken
                Didier
                Would it be possible to have a choice for Tools #6 and #7 to place either points or guide lines?
                Thanks for me a very useful plugin
                Ken
                  Didier Bur
                  Hi Chuck,
                  It seems you have the same problem than rv1974. An "uninitialized constant" error message means that the script within the "Projection" folder is not loaded, and an "undefined method" error message too. Check for the file "projection.rbs" in the Projection" sub-folder of plugins. Please tell me if it is there. πŸŽ‰
                  DB
                    Didier Bur
                    You can do that already. Select unconnected edges as you would do with connected edges !
                    You can do that already too. After a first guides insertion, hit Enter to select a new edge (watch your status bar). Please read the doc folks ! πŸ˜„
                    DB
                    • urgenU Offline
                      urgen
                      ...Thanks for update Didier,very useful. πŸ‘
                      --pupil forever...------
                        Ben Ritter
                        Didier,
                        Fantastic tools! Thank you very much.
                        • O Offline
                          otb designworks
                          @didier bur said:
                          Hi Chuck,
                          Hi Didier, thanks for the quick response.
                          Yes, the projection.rbs is in the projection folder.
                          I trashed the file and still no functionality. I have nothing but png's and the projection.pdf filesin the projection folder and still the same error messages. I tried placing the rbs file back in and still nothing works.
                          thanks for the help
                          Cheers, Chuck
                          Cheers, Chuck
                          • takesh hT Offline
                            takesh h
                            Hi Didier, this looks like another sweeeet update, however with my iMac nothing so far works.
                            My situation is just like Chuck's, they don't seem like doing anything whatsoever upon my clicking icons.
                            I've been using Projection tools for the longest time and am very familiar with how they work.
                            They have been doing beautifully until I updated to ver.2.
                            I clean-installed them as well.
                            I just noticed that if I install them in [HD]-[user]-[username]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin],
                            instead of usual [HD]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin], everything works.
                            Hope this will be fixed... Thanks in advance!
                            • Bob JamesB Offline
                              Bob James
                              I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
                              The same is true for Profile Builder (for me, at least)
                                rv1974
                                You simply turned me into francophil 😍
                                http://www.youtube.com/watch?v=ye0_QCUgwO4&eurl=http%3A%2F%2Fdirty.ru%2Fcomments%2F255512&feature=player_embedded
                                  πŸ’š
                                  • O Offline
                                    otb designworks
                                    This works for me as well! Thanks guys, I had forgotten that some scripts just don't like the "regular" library location.
                                    Cheers, chuck
                                    Cheers, Chuck
                                      Didier Bur
                                      Were you francophobe ??? 🀣
                                      I'm far from an expert in MacOs, but this sounds to me to be like when on Windows you install some software for "all users" or for just one user.
                                      I'll put that in the doc. Thanks for the tip !
                                      DB
                                      • EdsonE Offline
                                        Edson
                                        thanks, didier. a great plugin has become even better!
                                        http://www.mahfuz.arq.br
                                          rv1974
                                          Nope I was francophag πŸ˜„
                                            Didier
                                            It occurs to me that my recent tool cpointAtLineFaceIntersection.rb http://forums.sketchucation.com/viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit...
                                            • 2 / 8
