    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 227.0k Views 61 Watching
      • O Offline
        otb designworks
        I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
        The same is true for Profile Builder (for me, at least)
        This works for me as well! Thanks guys, I had forgotten that some scripts just don't like the "regular" library location.
        Cheers, chuck
        Cheers, Chuck
        OTB Designworks is on Youtube
        • Didier BurD Offline
          Didier Bur
          You simply turned me into francophil
          Were you francophobe ??? 🤣
          I'm far from an expert in MacOs, but this sounds to me to be like when on Windows you install some software for "all users" or for just one user.
          I'll put that in the doc. Thanks for the tip !
          DB
          • EdsonE Offline
            Edson
            thanks, didier. a great plugin has become even better!
            http://www.mahfuz.arq.br
              rv1974
              Nope I was francophag 😄
                Didier
                It occurs to me that my recent tool cpointAtLineFaceIntersection.rb http://forums.sketchucation.com/viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit...
                • JClementsJ Offline
                  JClements
                  Didier:
                  Your last icon creates faces from a curve (a continuous curve), but the faces are not smoothed (like those created when push-pulling a circle or "welded" segments).
                  Wondering if you can incorporate this into another or the same tool?
                  What do others think. Good, bad, or unecessary?
                    Didier Bur
                    It occurs to me that my recent tool cpointAtLineFaceIntersection.rb viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset
                    That's just what I was going to ask you for ! Thanks for contributing 👍
                    This feature is incorporated in the code actually, but apparently doesn't work every time 😳
                    I'll check that asap.
                    Regards,
                    DB
                      cyan.archnet
                      THANK YOU!, will definitely try this updated plugin!
                        accabrera
                        👍 Thanks !!!
                          boilingsnow
                          thank you very much Didier Bur
                          but you have probably forgotten to add the new images for the new buttons of the latest update. they are missing...
                          • boofredlayB Offline
                            boofredlay
                            Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
                              define
                              Yes agree - I was just about to send the very same screenshot, since I'm also missing 4 icons.
                              anyway - thx a lot for your good work on this - absolutely amazing!
                              • mitcorbM Offline
                                mitcorb
                                I am also not seeing buttons 1, 5, 8, 9. If I mouse over these buttons their descriptions show up. I have not fully tested the functions yet. At first I thought the update would overwrite the previous. And then I reviewed the first post where you say to delete the previous, so I did that. However, the four mentioned buttons do not get their png's, which I believe are in the auxiliary folder.
                                • Bob JamesB Offline
                                  Bob James
                                  I see all the buttons, but agree that the surface is not smoothed
                                    blajnov
                                    Here, all the buttons, change the folder from the archive of "Projection"
                                    Projection.zip
                                      boilingsnow
                                      What you have is not the latest version...so you can get or the buttons loaded.
                                      The latest version updated on 3. July is missing buttons.
                                      So waiting for Didier Bur.
                                        boilingsnow
                                        No they are still not "all the buttons" compared to the latest update in first page. There are at least three buttons missing.
                                        It seems Didier Bur has updated the .rb but forgotten to change the folder. You can get all the buttons loaded because your .rb is not the latest one.
                                          Didier Bur
                                          Sorry for the missing icons. Zip updated.
                                          DB
                                            boofredlay
                                            Thanks.
                                            • 3 / 8
