    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
    • EdsonE
      Edson
      thanks, didier. a great plugin has become even better!
      http://www.mahfuz.arq.br
        rv1974
        @didier bur said:
        @didier bur said:
        You simply turned me into francophil
        Were you francophobe ??? 🤣
        Nope I was francophag 😄
          Didier
          It occurs to me that my recent tool cpointAtLineFaceIntersection.rb http://forums.sketchucation.com/viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit...
          • JClementsJ
            JClements
            Didier:
            Your last icon creates faces from a curve (a continuous curve), but the faces are not smoothed (like those created when push-pulling a circle or "welded" segments).
            Wondering if you can incorporate this into another or the same tool?
            What do others think. Good, bad, or unecessary?
            • Didier BurD
              Didier Bur
              It occurs to me that my recent tool cpointAtLineFaceIntersection.rb viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset
              That's just what I was going to ask you for ! Thanks for contributing 👍
              This feature is incorporated in the code actually, but apparently doesn't work every time 😳
              I'll check that asap.
              Regards,
              DB
              • C
                cyan.archnet
                THANK YOU!, will definitely try this updated plugin!
                  accabrera
                  👍 Thanks !!!
                  • B
                    boilingsnow
                    thank you very much Didier Bur
                    but you have probably forgotten to add the new images for the new buttons of the latest update. they are missing...
                    • boofredlayB
                      boofredlay
                      Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
                        define
                        Yes agree - I was just about to send the very same screenshot, since I'm also missing 4 icons.
                        anyway - thx a lot for your good work on this - absolutely amazing!
                        • mitcorbM
                          mitcorb
                          I am also not seeing buttons 1, 5, 8, 9. If I mouse over these buttons their descriptions show up. I have not fully tested the functions yet. At first I thought the update would overwrite the previous. And then I reviewed the first post where you say to delete the previous, so I did that. However, the four mentioned buttons do not get their png's, which I believe are in the auxiliary folder.
                          • Bob JamesB
                            Bob James
                            I see all the buttons, but agree that the surface is not smoothed
                            • B
                              blajnov
                              Here, all the buttons, change the folder from the archive of "Projection"
                              Projection.zip
                              • B
                                boilingsnow
                                What you have is not the latest version...so you can get or the buttons loaded.
                                The latest version updated on 3. July is missing buttons.
                                So waiting for Didier Bur.
                                • B
                                  boilingsnow
                                  No they are still not "all the buttons" compared to the latest update in first page. There are at least three buttons missing.
                                  It seems Didier Bur has updated the .rb but forgotten to change the folder. You can get all the buttons loaded because your .rb is not the latest one.
                                  • Didier BurD
                                    Didier Bur
                                    Sorry for the missing icons. Zip updated.
                                    DB
                                    • boofredlayB
                                      boofredlay
                                      Thanks.
                                      • CadFatherC
                                        CadFather
                                        Hi Didier, regarding your smooth problem - have a look at Matt's script here
                                        404 Not Found
                                        (forums.sketchucation.com)
                                        • Didier BurD
                                          Didier Bur
                                          Hi Cadfathher,
                                          Thanks a million. I knew that smoothing was possible, but the ruby doc is REALLY bad, it doesn't mention that an edge can be smoothed only when it shares 2 faces.
                                          It works now. Patch published.
                                          DB
                                          • CadFatherC
                                            CadFather
                                            fantastic 👍
                                            • 3 / 8
