    [Plugin] Multi face offset
    49 Posts 15 Posters 71.6k Views 15 Watching
    • GaieusG
      Remus, please, post some image in the first post so that we can have some clue what it does (and I can rip it for TDC, too)
        rv1974
        @thomthom said:
        Windowizer generates window components. This is just plain offset.
        A "window component" is a pure abstraction. With glass inset =0 it makes the same plain offset+ additional options (i.e. materials assignment, edit and eraze in the future)
        • C
          chango70
          Does the faces have to be on the same plane?
            remus
            No, the faces can be on any plane. It wont work on curvy things, though.
            As for windowizer doing the same thing, it probably can, and i think Fred06's offset on surface could do it as well, i just fancied writing it for a bit of practice.
              DIEGO-RODRIGUEZ
              Thanks, but does not work.
              Using sketchup 6 and 7, windowsxp SP3 in Spanish
              If you have a solution, thank you
                remus
                Could you open the ruby console (window->ruby console), run the script and post whatever comes up in the console?
                  DIEGO-RODRIGUEZ
                  Error: #<NoMethodError: undefined method offset' for #<Sketchup::Face:0x5aad818>> C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:23:in multi_face_offset'
                  C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in each' C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in multi_face_offset'
                  C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:34
                  C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:33:in `call'
                    remus
                    most unusual, i'll have a look in to it and see if i can find out whats going on.
                      Remus - do you have RickW's [free from Smustard] 'offset.rb' and elcorto doesn't ?
                        DIEGO-RODRIGUEZ
                        Thanks Tig, I had no offset.rb.
                        Now works fine
                          remus
                          I havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
                            It's the simple things that are often the most complicated !
                            [¡Se trata de las cosas simples que a menudo son las más complicadas!]
                              And seems Protrude by Jim Foltz makes the same and more! 💚
                                remus
                                A veritable Smörgåsbord of repeated functionality 😛
                                  @Remus
                                  Thx for this new curious name 😆
                                  http://www.cliffordawright.com/caw/assets/Mezze table al-waha rest.jpg
                                  • PixeroP
                                    Pixero
                                    Smörgåsbord is a swedish word. 👍
                                      DIEGO-RODRIGUEZ
                                      Be possible. After applying offset. be selected the new drawing?
                                      then able to apply, for example, multiple Push Pull
                                      http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
                                      sorry for my English. Thank you
                                        DIEGO-RODRIGUEZ
                                        "Pilou" You're right, thank you very much
                                          Protrude above can make that , just offset= 0 after use it and enable Height = that you want 😉
                                          Only Protrude keep the selection 😉 Protrude is a very funny plug! 😎
                                          For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur 😉
                                          But both lost the selection! 😮
                                          • CadFatherC
                                            CadFather
                                            Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
