    [Plugin] Multi face offset
    49 Posts 15 Posters 70.7k Views 15 Watching
      Remus - do you have RickW's [free from Smustard] 'offset.rb' and elcorto doesn't ?
        DIEGO-RODRIGUEZ
        Thanks Tig, I had no offset.rb.
        Now works fine
          remus
          I havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
            It's the simple things that are often the most complicated !
            [¡Se trata de las cosas simples que a menudo son las más complicadas!]
              And seems Protrude by Jim Foltz makes the same and more! 💚
                remus
                A veritable Smörgåsbord of repeated functionality 😛
                  @Remus
                  Thx for this new curious name 😆
                  http://www.cliffordawright.com/caw/assets/Mezze table al-waha rest.jpg
                  • PixeroP
                    Pixero
                    Smörgåsbord is a swedish word. 👍
                      DIEGO-RODRIGUEZ
                      Be possible. After applying offset. be selected the new drawing?
                      then able to apply, for example, multiple Push Pull
                      http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
                      sorry for my English. Thank you
                        DIEGO-RODRIGUEZ
                        "Pilou" You're right, thank you very much
                          Protrude above can make that , just offset= 0 after use it and enable Height = that you want 😉
                          Only Protrude keep the selection 😉 Protrude is a very funny plug! 😎
                          For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur 😉
                          But both lost the selection! 😮
                          • CadFatherC
                            CadFather
                            Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
                              remus
                              So it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
                              • CadFatherC
                                CadFather
                                the hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
                                • CadFatherC
                                  CadFather
                                  Remus, couple of icons if needed..
                                    remus
                                    I dont know how to do toolbars 😳
                                    I'll give it a go, though, those icons are too nice to waste 👍
                                    • CadFatherC
                                      CadFather
                                      i think it's something along these lines.. check out Chris's loft or other tools - they will make sense
                                      	if !file_loaded?(__FILE__) then
                                      		toolbar = UI;;Toolbar.new "RTK"
                                      		cmd = UI;;Command.new("Offset Multiple Faces (Remus Knowles)"){RTK.multi_face_offset}
                                      		cmd.small_icon = "RTK/moffset_16.png"
                                      		cmd.large_icon = "RTK/moffset_24.png"
                                      		cmd.tooltip = "Offset Multiple Faces"
                                      		toolbar = toolbar.add_item cmd
                                      • pep75P
                                        pep75
                                        Hey All!
                                        Does anyone has this fantastic plugin working in version 8?! I installed offset.rb and the latest Multifaceoffset.rb but only the input dialogue appears and it doesn't do anything...
                                        Thank you!
                                        Grtzz
                                        Pep
                                        ....or does anyone know how to offset multi faces in another way?!
                                          @pep75 said:
                                          Hey All!
                                          Thank you!
                                          Grtzz
                                          Pep
                                          It works fine in v8 for me [and others].
                                          Have you tried running it with the Ruby Console open to see error messages.
                                          It seems to be failing after the dialog, so probbaly an 'offest' error/deficiency...
                                          You need both the Multifaceoffset.rb and the offset.rb in the main Plugins folder...
                                          • pep75P
                                            pep75
                                            Hey TIG, Thanks!
                                            I already placed the both *.rb files in the main plugins folder, just as usual...And I got the following error message in the Ruby Console but that is Chinese to me! 😲
                                            I don't know what's wrong?
                                            • 2 / 3
