    [Plugin] Multi face offset
    49 Posts 15 Posters 67.0k Views 15 Watching
      remus
      No, the faces can be on any plane. It wont work on curvy things, though.
      As for windowizer doing the same thing, it probably can, and i think Fred06's offset on surface could do it as well, i just fancied writing it for a bit of practice.
        DIEGO-RODRIGUEZ
        Thanks, but does not work.
        Using sketchup 6 and 7, windowsxp SP3 in Spanish
        If you have a solution, thank you
          remus
          Could you open the ruby console (window->ruby console), run the script and post whatever comes up in the console?
            DIEGO-RODRIGUEZ
            Error: #<NoMethodError: undefined method offset' for #<Sketchup::Face:0x5aad818>> C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:23:in multi_face_offset'
            C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in each' C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in multi_face_offset'
            C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:34
            C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:33:in `call'
              remus
              most unusual, i'll have a look in to it and see if i can find out whats going on.
              • TIGT Online
                Remus - do you have RickW's [free from Smustard] 'offset.rb' and elcorto doesn't ?
                  DIEGO-RODRIGUEZ
                  Thanks Tig, I had no offset.rb.
                  Now works fine
                    remus
                    I havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
                    • TIGT Online
                      It's the simple things that are often the most complicated !
                      [¡Se trata de las cosas simples que a menudo son las más complicadas!]
                        And seems Protrude by Jim Foltz makes the same and more! 💚
                          remus
                          A veritable Smörgåsbord of repeated functionality 😛
                            @Remus
                            Thx for this new curious name 😆
                            http://www.cliffordawright.com/caw/assets/Mezze table al-waha rest.jpg
                            • PixeroP Offline
                              Pixero
                              Smörgåsbord is a swedish word. 👍
                                DIEGO-RODRIGUEZ
                                Be possible. After applying offset. be selected the new drawing?
                                then able to apply, for example, multiple Push Pull
                                http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
                                sorry for my English. Thank you
                                  DIEGO-RODRIGUEZ
                                  "Pilou" You're right, thank you very much
                                    Protrude above can make that , just offset= 0 after use it and enable Height = that you want 😉
                                    Only Protrude keep the selection 😉 Protrude is a very funny plug! 😎
                                    For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur 😉
                                    But both lost the selection! 😮
                                    • CadFatherC Offline
                                      CadFather
                                      Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
                                        remus
                                        So it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
                                          CadFather
                                          the hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
                                            CadFather
                                            Remus, couple of icons if needed..
                                            • 1 / 3
