    [Plugin] Multi face offset
    49 Posts 15 Posters 70.7k Views 15 Watching
      remus
      Could you open the ruby console (window->ruby console), run the script and post whatever comes up in the console?
        DIEGO-RODRIGUEZ
        Error: #<NoMethodError: undefined method offset' for #<Sketchup::Face:0x5aad818>> C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:23:in multi_face_offset'
        C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in each' C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in multi_face_offset'
        C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:34
        C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:33:in `call'
          remus
          most unusual, i'll have a look in to it and see if i can find out whats going on.
            Remus - do you have RickW's [free from Smustard] 'offset.rb' and elcorto doesn't ?
              DIEGO-RODRIGUEZ
              Thanks Tig, I had no offset.rb.
              Now works fine
                remus
                I havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
                  It's the simple things that are often the most complicated !
                  [¡Se trata de las cosas simples que a menudo son las más complicadas!]
                    And seems Protrude by Jim Foltz makes the same and more! 💚
                      remus
                      A veritable Smörgåsbord of repeated functionality 😛
                        @Remus
                        Thx for this new curious name 😆
                        http://www.cliffordawright.com/caw/assets/Mezze table al-waha rest.jpg
                        • PixeroP
                          Pixero
                          Smörgåsbord is a swedish word. 👍
                            DIEGO-RODRIGUEZ
                            Be possible. After applying offset. be selected the new drawing?
                            then able to apply, for example, multiple Push Pull
                            http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
                            sorry for my English. Thank you
                              DIEGO-RODRIGUEZ
                              "Pilou" You're right, thank you very much
                                Protrude above can make that , just offset= 0 after use it and enable Height = that you want 😉
                                Only Protrude keep the selection 😉 Protrude is a very funny plug! 😎
                                For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur 😉
                                But both lost the selection! 😮
                                • CadFatherC
                                  CadFather
                                  Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
                                    remus
                                    So it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
                                    • CadFatherC
                                      CadFather
                                      the hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
                                      • CadFatherC
                                        CadFather
                                        Remus, couple of icons if needed..
                                          remus
                                          I dont know how to do toolbars 😳
                                          I'll give it a go, though, those icons are too nice to waste 👍
                                          • CadFatherC
                                            CadFather
                                            i think it's something along these lines.. check out Chris's loft or other tools - they will make sense
                                            	if !file_loaded?(__FILE__) then
                                            		toolbar = UI;;Toolbar.new "RTK"
                                            		cmd = UI;;Command.new("Offset Multiple Faces (Remus Knowles)"){RTK.multi_face_offset}
                                            		cmd.small_icon = "RTK/moffset_16.png"
                                            		cmd.large_icon = "RTK/moffset_24.png"
                                            		cmd.tooltip = "Offset Multiple Faces"
                                            		toolbar = toolbar.add_item cmd
                                            • 2 / 3
