    [Plugin] Multi face offset
    49 Posts 15 Posters 70.3k Views 15 Watching
      rv1974
      Isn't windowizer already make the same ?
        Windowizer generates window components. This is just plain offset.
          Remus, please, post some image in the first post so that we can have some clue what it does (and I can rip it for TDC, too)
            rv1974
            A "window component" is a pure abstraction. With glass inset =0 it makes the same plain offset+ additional options (i.e. materials assignment, edit and eraze in the future)
              chango70
              Does the faces have to be on the same plane?
                remus
                No, the faces can be on any plane. It wont work on curvy things, though.
                As for windowizer doing the same thing, it probably can, and i think Fred06's offset on surface could do it as well, i just fancied writing it for a bit of practice.
                  DIEGO-RODRIGUEZ
                  Thanks, but does not work.
                  Using sketchup 6 and 7, windowsxp SP3 in Spanish
                  If you have a solution, thank you
                    remus
                    Could you open the ruby console (window->ruby console), run the script and post whatever comes up in the console?
                      DIEGO-RODRIGUEZ
                      Error: #<NoMethodError: undefined method offset' for #<Sketchup::Face:0x5aad818>> C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:23:in multi_face_offset'
                      C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in each' C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in multi_face_offset'
                      C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:34
                      C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:33:in `call'
                        remus
                        most unusual, i'll have a look in to it and see if i can find out whats going on.
                          Remus - do you have RickW's [free from Smustard] 'offset.rb' and elcorto doesn't ?
                            DIEGO-RODRIGUEZ
                            Thanks Tig, I had no offset.rb.
                            Now works fine
                              remus
                              I havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
                                It's the simple things that are often the most complicated !
                                [¡Se trata de las cosas simples que a menudo son las más complicadas!]
                                  And seems Protrude by Jim Foltz makes the same and more! 💚
                                    remus
                                    A veritable Smörgåsbord of repeated functionality 😛
                                      @Remus
                                      Thx for this new curious name 😆
                                      http://www.cliffordawright.com/caw/assets/Mezze table al-waha rest.jpg
                                      • PixeroP Offline
                                        Pixero
                                        Smörgåsbord is a swedish word. 👍
                                          DIEGO-RODRIGUEZ
                                          Be possible. After applying offset. be selected the new drawing?
                                          then able to apply, for example, multiple Push Pull
                                          http://img72.imageshack.us/img72/6033/sinttulo1p.jpg
                                          sorry for my English. Thank you
                                            DIEGO-RODRIGUEZ
                                            "Pilou" You're right, thank you very much
                                            • 1 / 3
