    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.3k Views 76 Watching
      putnik
      Thank you TIG!
      http://keshas.info
      • olisheaO Offline
        olishea
        amazing plugin, works really smooth too. gonna have some fun with this! ๐Ÿ˜†
        oli
          Version 1.1 20090625
          Speed improvements - face making time ~halved,
          typename >> kind_of?, triangulation glitch trapped
          and orientation improved.
          It's here http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
          Another example...
            The funny of your plug ๐Ÿ˜‰
            (Click the image)
            • MALAISEM Offline
              MALAISE
              Great TIG, thanks a lot for this SU enhancement.
              MALAISE
              La Connaissance n'a de valeur que partagรฉe
              • JClementsJ Offline
                JClements
                Congratulations TIG!
                A very useful and well executed script.
                Questions/Suggestions:
                1- I assume the order in which the two groups were assigned determines the alignment of the mesh; to the last defined of the two selected groups.
                2- Not critical, but could there be a Smoothing Dialog that prompts: "a)Smooth or b)Smooth and Soften"?
                3- A defaults dialog triggered by pressing the [Tab] key? You'd would then be able to assign defaults of a Yes or No for each prompt and which which dialogs would be shown (if shown, then user could temporarily change their default as the script is playing).
                  Here's an update...
                  Version 1.2 20090625
                  Orientation speed optimised.
                  Glitch on groups erase fixed.
                  Get it here... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                  • I Offline
                    ideas_arte
                    Wow...!
                    Many thank you very much ...!
                    Excellent tool, thank you very much again and a hug from Central America ...! ๐Ÿ˜„
                    • massimoM Offline
                      massimo Moderator
                      Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
                        Massimo
                        Have you tried the latest version v1.2 ? I've just tried to reproduce your path/profile and I get all faces made - no gaps - Any edge that can get a face should get a face ? Your faces aren't reversed are they, so look 'gappped' ?
                        The only problem I have was because of the convoluted result some faces orient wrongly [inside out] - both in the script AND within SUp later - the only fix is to reverse the problem faces manually ...
                        I had to guess your model's details - I could test it better with the real thing - if after trying with the latest version it still gaps please PM me with the model attached, so I can see if I get the same problem...
                          Can you subsequently get the face made if you redraw an edge ? If so then EEbyE should have made that face...
                          I haven't managed to reproduce it, can one of you PM me a [small] model with the problem ?
                            I have same result but seems normal as this function is not adapted to this!
                            As the profil stay parallel ๐Ÿ˜’
                            At each "rotation" there are creation of an external or internal horizontal face ๐Ÿ˜„
                            For ovoid that make just an half circle ๐Ÿ˜‰
                            And a mirror after ๐Ÿ˜‰
                            But even with this there some gaps ๐Ÿ˜‰
                              file of the mirror above ๐Ÿ˜‰
                              gap.skp
                                I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
                                  Here's v1.3 ...
                                  It's been trapped for rare unfaced edges - it either forces the edge to have a face, or erases the edge if it's not possible to add a face ...
                                    Have you tried this latest version ?
                                      There is always no possible to close some faces (my gap file above) ๐Ÿ˜‰
                                      The curious is this is a "big face" ๐Ÿ˜ฎ
                                      Maybe because angle is too flat?
                                      Not so a big deal to close it by hand ๐Ÿ˜‰
                                        Did you still get unfaced edges ?
                                          yes the same than on my image above! (orange pale one)
                                          After Auto self convoluted stay 2 "big faces" (second of the revolution, and second of the profil)
                                          AND I have this one " 1.3 20090626 Edges not facing in convoluted shapes trapped."
                                            Of ourse yes ๐Ÿ˜‰
                                            The curious was there same size so maybe you have not posted the good version?
                                            • 3 / 10
