    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 238.2k Views 76 Watching
      @massimo said:
      Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
      Massimo
      Have you tried the latest version v1.2 ? I've just tried to reproduce your path/profile and I get all faces made - no gaps - Any edge that can get a face should get a face ? Your faces aren't reversed are they, so look 'gappped' ?
      The only problem I have was because of the convoluted result some faces orient wrongly [inside out] - both in the script AND within SUp later - the only fix is to reverse the problem faces manually ...
      I had to guess your model's details - I could test it better with the real thing - if after trying with the latest version it still gaps please PM me with the model attached, so I can see if I get the same problem...
        Can you subsequently get the face made if you redraw an edge ? If so then EEbyE should have made that face...
        I haven't managed to reproduce it, can one of you PM me a [small] model with the problem ?
          I have same result but seems normal as this function is not adapted to this!
          As the profil stay parallel 😒
          At each "rotation" there are creation of an external or internal horizontal face 😄
          For ovoid that make just an half circle 😉
          And a mirror after 😉
          But even with this there some gaps 😉
            file of the mirror above 😉
            gap.skp
              I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
                Here's v1.3 ...
                http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                It's been trapped for rare unfaced edges - it either forces the edge to have a face, or erases the edge if it's not possible to add a face ...
                  Have you tried this latest version ?
                    There is always no possible to close some faces (my gap file above) 😉
                    The curious is this is a "big face" 😮
                    Maybe because angle is too flat?
                    Not so a big deal to close it by hand 😉
                      Did you still get unfaced edges ?
                        yes the same than on my image above! (orange pale one)
                        After Auto self convoluted stay 2 "big faces" (second of the revolution, and second of the profil)
                        AND I have this one " 1.3 20090626 Edges not facing in convoluted shapes trapped."
                          Of ourse yes 😉
                          The curious was there same size so maybe you have not posted the good version?
                            Koosie van Tutte
                            thanks a lot!
                              AcesHigh
                              TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
                              http://www.kxcad.net/autodesk/Autodesk_VIZ_Help/graphics/il_nurbs_sweep2.jpg
                              http://moi3d.com/1.0/docs/screenshots/Sweep9.jpg
                              http://moi3d.com/1.0/docs/screenshots/Sweep10.jpg
                              http://moi3d.com/1.0/docs/screenshots/Sweep11.jpg
                              http://moi3d.com/1.0/docs/screenshots/Sweep12.jpg
                              http://moi3d.com/1.0/docs/screenshots/Sweep13.jpg
                                It's on the list...
                                  seems one of the Moi's example above is 3 rails 😉
                                  • MALAISEM Offline
                                    MALAISE
                                    Hi TIG
                                    May you'll better understand as me that message. I loaded the V1.3, but no results
                                    I reload the file.rb but get the same result.captured screen using ExtrudeEdge to edge
                                    Do you have the V1.2 somewhere ? ( It worked )
                                    MALAISE 👍
                                      Malaise I've PM'd you about getting the skp sent so I can test it...
                                      Are the selected just two groups of edges ?
                                      • JClementsJ Offline
                                        JClements
                                        Well TIG, this is a nice script and I hope sweep-two-rails can be done (keeping my fingers crossed 😄 ). It could be a big time saver for doing landscape/topographical, asymetrical surfaces.
                                        • O Offline
                                          orei
                                          i hope sooo!!! wonderful script!!!
                                          • MALAISEM Offline
                                            MALAISE
                                            Hi All
                                            I have encountered some strange behaviour of TIG' last Plugin. Have you notice that Experimental SketchyPhysic 3X may block ExtrudeEdges ?
                                            Using SketchyPhysic 2 , no problem at all .... please let's share your comments
                                            MALAISE 😄
                                            • 3 / 10
