    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.1k Views 76 Watching
      rv1974
      Hi TIG! Instead\in addition to(?) of consistant orientation mode (in the center: extrudeEdgesByEdges.rb) It'd be perfect to get the one of profiles get turned along another one (the right example: push-pull+eraser)
      Thanks.
        donkey_b
        it's GOOD thx
          Thanks.
          For that use followme tool or followme_and_keep script... add lines to the profile to make a face then erase the 'back' edges to make the shape required. EEbyE works with non-coplanar profiles and paths, and non-contiguous edges in paths and profile[as FAK] - which isn't possible with traditional followme...
          • CadFatherC Offline
            CadFather
            Hi TIG, Thank you for the gem..
            could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
              silver_shadow
              i wanted this soooo much
              • free agentF Offline
                free agent
                thats because the the script doesnt rotate the profile along the path so it apears as if the circle is being extruded, to which TIG will reply: if you want that function use Follow Me or Follow me and Keep.
                Tig: it seems people would really really like that function 😄 👍
                  And if you want multiple curves along a path use "Simple-Loft" by Chris Fullmer 😉
                  The extrudeEdgesbyEgdes is for particular uses as sections are always parallel!
                    dylan
                    Thanks TIG, this is a big script and works so well 👍
                    http://dmdarchitecture.co.uk/
                      CadFather
                      gotcha!.. 😒 😆
                      ..the script does lead you into 'lofty' considerations..
                      • mitcorbM Offline
                        mitcorb
                        TIG:
                        Did you notice the plugin will displace the resulting group a distance away from the originating groups? I don't know if this is a random distance or a proportional distance, or if it is dependent on the geometry of the originating elements. This is just an observation, and not necessarily a problem.
                        mitcorb
                          @mitcorb said:
                          TIG:
                          mitcorb
                          The result sometimes displaces... It's to do with the translations of the two groups, I haven't yet worked out how to ensure it always snaps over the original - the displacement is the bounds of the new group v. the originals...
                            majid
                            Thanks for the ideas...
                            Peace, hello: I am happy that the website is active ?
                            My Farsi is not so good...
                              Ben Ritter
                              TIG,
                              Very grateful for your talent, and for sharing.
                              Thank you.
                              • majidM Offline
                                majid
                                thanx dear TIG .. it is great. maybe the next step is adding options so that it could do something like Follow me ,+ FollowMe&Keep, but whit a noncouplanar profile (like your scrip is doing)... again :it is great TIG 👍
                                تیگ عزیز،ممنون از سخاوت تو
                                • plot-parisP Offline
                                  plot-paris
                                  wow, really a nice plugin! thanks a lot, TIG! jumps out of his seat
                                  (and thanks Gaieus, for pointing me here...)
                                  that is quite a useful tool.
                                  next step: birial operation? (two different path-curves and/or several different base-curves...) 😉
                                  • mitcorbM Offline
                                    mitcorb
                                    As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) 😉 and then morph along rails to preset sectional outlines, and who knows what else?
                                    I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
                                    Thank you TIG
                                    mitcorb
                                    • olisheaO Offline
                                      olishea
                                      does it work well for mac?
                                      oli
                                        dylan
                                        Works perfectly on the Mac Oli 😎
                                          putnik
                                          Thank you TIG!
                                          http://keshas.info
                                          • olisheaO Offline
                                            olishea
                                            amazing plugin, works really smooth too. gonna have some fun with this! 😆
                                            oli
                                            • 2 / 10
