    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 227.5k Views 76 Watching
    • EarthMoverE Offline
      EarthMover
      Thanks TIG!
      Content Creator at Skapeup
      • mitcorbM Offline
        mitcorb
        TIG:
        This was the subject of one of my first wishful posts. "Extrude" a curve along a curve.
        Excellent work!!!! This is another one of those jaw droppers. We're gonna have you bronzed. Plotparis will jump out of his seat when he sees this.
        Thank you.
        mitcorb
        • mitcorbM Offline
          mitcorb
          TIG:
          This also works with the freehand tool in SU6, if anybody was wondering.
          mitcorb
          • utilerU Offline
            utiler
            Really great tool, TIG!!!!
            Just Curious...
            • N Offline
              nino
              TIG,
              It is great, Thanks
              http://www.iran-eng.com/images/smilies/icon_gol.gif
              • urgenU Offline
                urgen
                👍 👍 👍 great tool! thanks!
                --pupil forever...------
                  REDS
                  Its very useful thing. Thanks
                    rv1974
                    Hi TIG! Instead\in addition to(?) of consistant orientation mode (in the center: extrudeEdgesByEdges.rb) It'd be perfect to get the one of profiles get turned along another one (the right example: push-pull+eraser)
                    Thanks.
                      donkey_b
                      it's GOOD thx
                        Thanks.
                        For that use followme tool or followme_and_keep script... add lines to the profile to make a face then erase the 'back' edges to make the shape required. EEbyE works with non-coplanar profiles and paths, and non-contiguous edges in paths and profile[as FAK] - which isn't possible with traditional followme...
                        • CadFatherC Offline
                          CadFather
                          Hi TIG, Thank you for the gem..
                          could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
                            silver_shadow
                            i wanted this soooo much
                            • free agentF Offline
                              free agent
                              thats because the the script doesnt rotate the profile along the path so it apears as if the circle is being extruded, to which TIG will reply: if you want that function use Follow Me or Follow me and Keep.
                              Tig: it seems people would really really like that function 😄 👍
                                And if you want multiple curves along a path use "Simple-Loft" by Chris Fullmer 😉
                                The extrudeEdgesbyEgdes is for particular uses as sections are always parallel!
                                  dylan
                                  Thanks TIG, this is a big script and works so well 👍
                                  http://dmdarchitecture.co.uk/
                                    CadFather
                                    gotcha!.. 😒 😆
                                    ..the script does lead you into 'lofty' considerations..
                                    • mitcorbM Offline
                                      mitcorb
                                      TIG:
                                      Did you notice the plugin will displace the resulting group a distance away from the originating groups? I don't know if this is a random distance or a proportional distance, or if it is dependent on the geometry of the originating elements. This is just an observation, and not necessarily a problem.
                                      mitcorb
                                        @mitcorb said:
                                        TIG:
                                        mitcorb
                                        The result sometimes displaces... It's to do with the translations of the two groups, I haven't yet worked out how to ensure it always snaps over the original - the displacement is the bounds of the new group v. the originals...
                                          majid
                                          Thanks for the ideas...
                                          Peace, hello: I am happy that the website is active ?
                                          My Farsi is not so good...
                                            Ben Ritter
                                            TIG,
                                            Very grateful for your talent, and for sharing.
                                            Thank you.
                                            • 2 / 10
