    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 230.7k Views 76 Watching
      sepo
      Thanks TIG..
      I noticed it actually does not follow and rotate along the path. Although interesting proposition, and it works without any problems, it would be usefull if it coud also work in manner that can be predictable in design terms.
        sepo
        I pushed it with a lot of geometry and it seems very stable. It performs orienting and reversing faces without problem. Triangulation did not make any problems as well. 👍 👍
          dtrarch
          One can add a point too and then group. ☀
          Killer script.
          dtr
            It doesn't matter what's in the groups - only edges get processed...
              @sepo said:
              Thanks TIG... I noticed it actually does not follow and rotate along the path. Although interesting proposition, and it works without any problems, it would be usefull if it coud also work in manner that can be predictable in design terms.
              This tool extrudes edges by edges without rotation. If you want rotation use followme tool or followme_and_keep script: you'll need to make the profile faced first by adding a back set of lines - you also need to unhide/unsmooth all edges to get a 'mesh'... The advantage of extrudeEdgesByEdges is that the profile and path can be in complex in 3D and also not continuous...
              • EarthMoverE Offline
                EarthMover
                Thanks TIG!
                Content Creator at Skapeup
                • mitcorbM Offline
                  mitcorb
                  TIG:
                  This was the subject of one of my first wishful posts. "Extrude" a curve along a curve.
                  Excellent work!!!! This is another one of those jaw droppers. We're gonna have you bronzed. Plotparis will jump out of his seat when he sees this.
                  Thank you.
                  mitcorb
                  • mitcorbM Offline
                    mitcorb
                    TIG:
                    This also works with the freehand tool in SU6, if anybody was wondering.
                    mitcorb
                    • utilerU Offline
                      utiler
                      Really great tool, TIG!!!!
                      Just Curious...
                      • N Offline
                        nino
                        TIG,
                        It is great, Thanks
                        http://www.iran-eng.com/images/smilies/icon_gol.gif
                        • urgenU Offline
                          urgen
                          👍 👍 👍 great tool! thanks!
                          --pupil forever...------
                            REDS
                            Its very useful thing. Thanks
                              rv1974
                              Hi TIG! Instead\in addition to(?) of consistant orientation mode (in the center: extrudeEdgesByEdges.rb) It'd be perfect to get the one of profiles get turned along another one (the right example: push-pull+eraser)
                              Thanks.
                                donkey_b
                                it's GOOD thx
                                  Thanks.
                                  For that use followme tool or followme_and_keep script... add lines to the profile to make a face then erase the 'back' edges to make the shape required. EEbyE works with non-coplanar profiles and paths, and non-contiguous edges in paths and profile[as FAK] - which isn't possible with traditional followme...
                                  • CadFatherC Offline
                                    CadFather
                                    Hi TIG, Thank you for the gem..
                                    could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
                                      silver_shadow
                                      i wanted this soooo much
                                      • free agentF Offline
                                        free agent
                                        thats because the the script doesnt rotate the profile along the path so it apears as if the circle is being extruded, to which TIG will reply: if you want that function use Follow Me or Follow me and Keep.
                                        Tig: it seems people would really really like that function 😄 👍
                                          And if you want multiple curves along a path use "Simple-Loft" by Chris Fullmer 😉
                                          The extrudeEdgesbyEgdes is for particular uses as sections are always parallel!
                                            dylan
                                            Thanks TIG, this is a big script and works so well 👍
                                            http://dmdarchitecture.co.uk/
                                            • 1 / 10
