    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 242.4k Views 76 Watching
      Tip: single lines and arcs won't group, so draw another edge,
      then group everything, edit the group and erase the temporary
      edge...
      Seems it's not necessary! 😉 (line, arc)
      Just go Menu Edit / Group for each object! 😉
      Then launch the plug
      I find that single lines or arcs won't group, but drawing another temporary line with it then grouping, then editing the group and deleting the temporary line seems to work to give a single arc group... It's because I use ashortcut key that isn't available on a single selection, BUT the Menu Edit >> Make-Group item is still OK... So if you can group single arcs via the menu without a hitch then that's great...
      Any ideas on improvements or clever uses welcomed...
        edge...
        Just go Menu Edit / Make Group for each object! 😉
        Works like a charm! Bravo! 😎
        Here with 2 arcs without "another edge"! 😉
          Next steps will be with 4 curves closed so Coons surfaces 😉
          • C
            chango70
            WOW This is like Rhino Sweep alone rail. Very cool!
              sepo
              Thanks TIG..
              I noticed it actually does not follow and rotate along the path. Although interesting proposition, and it works without any problems, it would be usefull if it coud also work in manner that can be predictable in design terms.
                sepo
                I pushed it with a lot of geometry and it seems very stable. It performs orienting and reversing faces without problem. Triangulation did not make any problems as well. 👍 👍
                  dtrarch
                  One can add a point too and then group. ☀
                  Killer script.
                  dtr
                    It doesn't matter what's in the groups - only edges get processed...
                      @sepo said:
                      Thanks TIG... I noticed it actually does not follow and rotate along the path. Although interesting proposition, and it works without any problems, it would be usefull if it coud also work in manner that can be predictable in design terms.
                      This tool extrudes edges by edges without rotation. If you want rotation use followme tool or followme_and_keep script: you'll need to make the profile faced first by adding a back set of lines - you also need to unhide/unsmooth all edges to get a 'mesh'... The advantage of extrudeEdgesByEdges is that the profile and path can be in complex in 3D and also not continuous...
                      • EarthMoverE
                        EarthMover
                        Thanks TIG!
                        Content Creator at Skapeup
                        • mitcorbM
                          mitcorb
                          TIG:
                          This was the subject of one of my first wishful posts. "Extrude" a curve along a curve.
                          Excellent work!!!! This is another one of those jaw droppers. We're gonna have you bronzed. Plotparis will jump out of his seat when he sees this.
                          Thank you.
                          mitcorb
                          • mitcorbM
                            mitcorb
                            TIG:
                            This also works with the freehand tool in SU6, if anybody was wondering.
                            mitcorb
                            • utilerU
                              utiler
                              Really great tool, TIG!!!!
                              Just Curious...
                              • N
                                nino
                                TIG,
                                It is great, Thanks
                                http://www.iran-eng.com/images/smilies/icon_gol.gif
                                • urgenU
                                  urgen
                                  👍 👍 👍 great tool! thanks!
                                  --pupil forever...------
                                    REDS
                                    Its very useful thing. Thanks
                                      rv1974
                                      Hi TIG! Instead\in addition to(?) of consistant orientation mode (in the center: extrudeEdgesByEdges.rb) It'd be perfect to get the one of profiles get turned along another one (the right example: push-pull+eraser)
                                      Thanks.
                                        donkey_b
                                        it's GOOD thx
                                          Thanks.
                                          For that use followme tool or followme_and_keep script... add lines to the profile to make a face then erase the 'back' edges to make the shape required. EEbyE works with non-coplanar profiles and paths, and non-contiguous edges in paths and profile[as FAK] - which isn't possible with traditional followme...
                                          • CadFatherC
                                            CadFather
                                            Hi TIG, Thank you for the gem..
                                            could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
                                            • 1 / 10
