    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 238.2k Views 76 Watching
    • urgenU Offline
      urgen
      👍 👍 👍 great tool! thanks!
      --pupil forever...------
        REDS
        Its very useful thing. Thanks
          rv1974
          Hi TIG! Instead\in addition to(?) of consistant orientation mode (in the center: extrudeEdgesByEdges.rb) It'd be perfect to get the one of profiles get turned along another one (the right example: push-pull+eraser)
          Thanks.
            donkey_b
            it's GOOD thx
              Thanks.
              For that use followme tool or followme_and_keep script... add lines to the profile to make a face then erase the 'back' edges to make the shape required. EEbyE works with non-coplanar profiles and paths, and non-contiguous edges in paths and profile[as FAK] - which isn't possible with traditional followme...
              • CadFatherC Offline
                CadFather
                Hi TIG, Thank you for the gem..
                could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
                  silver_shadow
                  i wanted this soooo much
                  • free agentF Offline
                    free agent
                    thats because the the script doesnt rotate the profile along the path so it apears as if the circle is being extruded, to which TIG will reply: if you want that function use Follow Me or Follow me and Keep.
                    Tig: it seems people would really really like that function 😄 👍
                    http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                      And if you want multiple curves along a path use "Simple-Loft" by Chris Fullmer 😉
                      The extrudeEdgesbyEgdes is for particular uses as sections are always parallel!
                        dylan
                        Thanks TIG, this is a big script and works so well 👍
                        http://dmdarchitecture.co.uk/
                          CadFather
                          gotcha!.. 😒 😆
                          ..the script does lead you into 'lofty' considerations..
                          • mitcorbM Offline
                            mitcorb
                            TIG:
                            Did you notice the plugin will displace the resulting group a distance away from the originating groups? I don't know if this is a random distance or a proportional distance, or if it is dependent on the geometry of the originating elements. This is just an observation, and not necessarily a problem.
                            mitcorb
                              @mitcorb said:
                              TIG:
                              mitcorb
                              The result sometimes displaces... It's to do with the translations of the two groups, I haven't yet worked out how to ensure it always snaps over the original - the displacement is the bounds of the new group v. the originals...
                                majid
                                Thanks for the ideas...
                                Peace, hello: I am happy that the website is active ?
                                My Farsi is not so good...
                                  Ben Ritter
                                  TIG,
                                  Very grateful for your talent, and for sharing.
                                  Thank you.
                                  • majidM Offline
                                    majid
                                    thanx dear TIG .. it is great. maybe the next step is adding options so that it could do something like Follow me ,+ FollowMe&Keep, but whit a noncouplanar profile (like your scrip is doing)... again :it is great TIG 👍
                                    تیگ عزیز،ممنون از سخاوت تو
                                    • plot-parisP Offline
                                      plot-paris
                                      wow, really a nice plugin! thanks a lot, TIG! jumps out of his seat
                                      (and thanks Gaieus, for pointing me here...)
                                      that is quite a useful tool.
                                      next step: birial operation? (two different path-curves and/or several different base-curves...) 😉
                                      • mitcorbM Offline
                                        mitcorb
                                        As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) 😉 and then morph along rails to preset sectional outlines, and who knows what else?
                                        I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
                                        Thank you TIG
                                        mitcorb
                                        • olisheaO Offline
                                          olishea
                                          does it work well for mac?
                                          oli
                                            dylan
                                            Works perfectly on the Mac Oli 😎
                                            • 2 / 10
