    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 228.7k Views 76 Watching
      Tip: single lines and arcs won't group, so draw another edge,
      then group everything, edit the group and erase the temporary
      edge...
      Seems it's not necessary! 😉 (line, arc)
      Just go Menu Edit / Make Group for each object! 😉
      Then launch the plug
      Works like a charm! Bravo! 😎
      Here with 2 arcs without "another edge"! 😉
        Next steps will be with 4 curves closed so Coons surfaces 😉
          chango70
          WOW This is like Rhino Sweep alone rail. Very cool!
            sepo
            Thanks TIG..
            I noticed it actually does not follow and rotate along the path. Although interesting proposition, and it works without any problems, it would be usefull if it coud also work in manner that can be predictable in design terms.
              sepo
              I pushed it with a lot of geometry and it seems very stable. It performs orienting and reversing faces without problem. Triangulation did not make any problems as well. 👍 👍
                dtrarch
                One can add a point too and then group. ☀
                Killer script.
                dtr
                  It doesn't matter what's in the groups - only edges get processed...
                    @sepo said:
                    Thanks TIG... I noticed it actually does not follow and rotate along the path. Although interesting proposition, and it works without any problems, it would be usefull if it coud also work in manner that can be predictable in design terms.
                    This tool extrudes edges by edges without rotation. If you want rotation use followme tool or followme_and_keep script: you'll need to make the profile faced first by adding a back set of lines - you also need to unhide/unsmooth all edges to get a 'mesh'... The advantage of extrudeEdgesByEdges is that the profile and path can be in complex in 3D and also not continuous...
                    • EarthMoverE Offline
                      EarthMover
                      Thanks TIG!
                      Content Creator at Skapeup
                      • mitcorbM Offline
                        mitcorb
                        TIG:
                        This was the subject of one of my first wishful posts. "Extrude" a curve along a curve.
                        Excellent work!!!! This is another one of those jaw droppers. We're gonna have you bronzed. Plotparis will jump out of his seat when he sees this.
                        Thank you.
                        mitcorb
                        • mitcorbM Offline
                          mitcorb
                          TIG:
                          This also works with the freehand tool in SU6, if anybody was wondering.
                          mitcorb
                          • utilerU Offline
                            utiler
                            Really great tool, TIG!!!!
                            Just Curious...
                            • N Offline
                              nino
                              TIG,
                              It is great, Thanks
                              http://www.iran-eng.com/images/smilies/icon_gol.gif
                              • urgenU Offline
                                urgen
                                👍 👍 👍 great tool! thanks!
                                --pupil forever...------
                                  REDS
                                  Its very useful thing. Thanks
                                  • R Do not disturb
                                    rv1974
                                    Hi TIG! Instead\in addition to(?) of consistant orientation mode (in the center: extrudeEdgesByEdges.rb) It'd be perfect to get the one of profiles get turned along another one (the right example: push-pull+eraser)
                                    Thanks.
                                      donkey_b
                                      it's GOOD thx
                                        Thanks.
                                        For that use followme tool or followme_and_keep script... add lines to the profile to make a face then erase the 'back' edges to make the shape required. EEbyE works with non-coplanar profiles and paths, and non-contiguous edges in paths and profile[as FAK] - which isn't possible with traditional followme...
                                        • CadFatherC Offline
                                          CadFather
                                          Hi TIG, Thank you for the gem..
                                          could be me doing something wrong.. i noticed that if i draw a circle on any plane (as path) and an edge in elevation (profile), the script always considers the circle the path
                                            silver_shadow
                                            i wanted this soooo much
                                            • 1 / 10
