    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      I think I found the issue. I have inadvertedly included a statement that only works with another version of LibFredo6.
      Here is a version that should work hopefully
      to drop into FREESCALE_Dir_20 folder
      • fredo6F Offline
        @cadfather said:
        Hi Fredo
        what are the chances i can remove the separators from the icons toolbar?
        Drop the attached file into the FREESCALE_Dir_20 folder.
        Then restart Sketchup, set the option in the Default Parameters dialog box, and then restart sketchup again.
        to drop into FREESCALE_Dir_20 subfolder
        • fredo6F Offline
          @cadfather said:
          Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
          it's not a big deal though - whenever you stumble upon it..
          It works for me. Could you redownload it and try again.
          Just in case, here is the version I use:
          By the way, does it do what it is suppose to do, that is remove the separators in the toolbar?
          [Edit] See this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&p=158953#p158953
          • CadFatherC Offline
            CadFather
            fantastico Fredo - it works! β˜€
            • H Offline
              hansschatz
              Thank you! It's very useful!
              • fredo6F Offline
                NEW VERSION 2.0g NOW RELEASED
                IMPORTANT: I decided to change the name of this plugin, as the previous name could create confusion with an existing company and infringe their trademark. Please use now the new name FredoScale when referring to this plugin.
                This version is identical to the previous one 2.0f, except the possibility to configure the toolbar without separators (a request from CadFather). The option can be selected in the Default Parameter dialog box.
                See main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                It works with the current LibFredo6 3.1f
                • COSEDIMARCOC Offline
                  COSEDIMARCO
                  Updated the Italian Translation File
                  Italian Translation of FredoScale 2.0g
                  [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                    Can the old Freescale folders be deleted?
                    • Jean-FrancoJ Offline
                      Jean-Franco
                      Yes, I did it and it works, no problem.
                      Jean-Franco
                      • utilerU Offline
                        utiler
                        The reason for my latest posts, Thom.
                        301 Moved Permanently
                        (www.sketchucation.com)
                        Just Curious...
                        • fredo6F Offline
                          Yes, in general you can safely erase the subfolder (here FREESCALE_Dir_20) once you have installed a more recent version.
                          • david_hD Offline
                            david_h
                            Anybody else having a problem getting the install to work? Mine deosn't show up. The old one worked fine. .. but the new one. . .nuthin'.
                            EDITGot it figgered out. Crisis averted. πŸ˜„
                            • marleusM Offline
                              marleus
                              THANK YOU Fredo!!!!!!
                              You're brilliant.
                              Finally I get my chair seats right πŸ‘
                              Markus Sillander
                              Vantaa, Finland
                              I'm on FormFonts now
                              http://www.formfonts.com
                                Marinho
                                Hi Fredo, morning, meu name is Marinho, and I live in Luciara, Mato Grosso state, Brasil (nearly 11Β°30'00"S - 50Β°30'00"W at side of Araguaia River). I want you if you can send me please the your famous plugin, now with changed name, FREDOSCALE 2.0f. I use the Sketchup 6.0 and lake very match can use this plugin.I dont find it to download in anyplace in internet.
                                Tanks a lot,
                                Best regards
                                Marinho.
                                  Tanks a lot,
                                  Best regards
                                  Marinho.
                                  Check the first post of this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180
                                    Marinho
                                    Hi Thomthom, I checked the link viewtopic.php?f=180&t=17948#p144180 but I dont find nothing about download FredScale 2.0g. Am I wrong? 😠
                                    Tanks,...
                                      At the end of the post, there's a little box saying "Attachments" - In that there's a link "FredoScale 2.0g.zip"
                                        Download link is here:
                                        http://www.sketchucation.com/forums/scf/download/file.php?id=27660
                                          mics_54
                                          πŸ‘Ž
                                            Marinho
                                            Hi Thomthom, Hi TIG, tanks... but I am litle craze.... I have password
                                            for the two... forun and site Sketchucation, but when I see "FredoScale
                                            2.gf to download to unzip (via SELECT ALU in Sketchup Plugins folder
                                            (731.49 KB) and I click it, I receive the notice "you are not....." and
                                            in this page, there are not place to login. TIG, tanks you for the
                                            direct link to download, but the same things, I am going to a place
                                            where I dont can log me. I am completly lost. The same with the links of
                                            tutorials in home page of Sketchucation. Links where I dont have
                                            acess to login,even though, I have the passwords. Sorry, but I need nost help.
                                            Tanks
                                            Marinho.
                                            • 56
                                            • 57
                                            • 2 / 57
