    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      @cadfather said:
      sorry Fredo, should have been clearer - the update does remove the separators.. so the toolbar looks great - it just doesn't work! : )
      ..don't worry about it Fredo, i'll leave it as it is.. i will try and find out if there's some clashing etc.. (Thanks)
      Is it the whole set of tools not working?
      Did you try with the version attached in my previous post, just in case?
      I'd better know, because I checked that 44 people have downloaded the file.
      • fredo6F
        @cadfather said:
        yes, the whole toolset stops - with both versions,
        i also tried with an empty plugins folder as below, same result..
        I suggest you then reinstall the standard version 2.0f (and 3.1f for LibFredo6, we never know). I need to investigate.
        By the way, when you say 'Stops' what does that mean. For instance, if you open the Ruby console, do you see any message when launching the tools?
        PS: Nice icon for the folders!
        • CadFatherC
          CadFather
          forgot to mention:
          xp pro sp3
          sketchup 7 pro
          • CadFatherC
            CadFather
            with the clean latest install (i had it but retried it again now) the toolset works - if i change the 'common' file, it stops..
            here's the folder icons - i do need some visual clues as to what swims in this folder!
            Folders.rar
            • fredo6F
              I think I found the issue. I have inadvertedly included a statement that only works with another version of LibFredo6.
              Here is a version that should work hopefully
              to drop into FREESCALE_Dir_20 folder
              • fredo6F
                @cadfather said:
                Hi Fredo
                what are the chances i can remove the separators from the icons toolbar?
                Drop the attached file into the FREESCALE_Dir_20 folder.
                Then restart Sketchup, set the option in the Default Parameters dialog box, and then restart sketchup again.
                to drop into FREESCALE_Dir_20 subfolder
                • fredo6F
                  @cadfather said:
                  Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
                  it's not a big deal though - whenever you stumble upon it..
                  It works for me. Could you redownload it and try again.
                  Just in case, here is the version I use:
                  By the way, does it do what it is suppose to do, that is remove the separators in the toolbar?
                  [Edit] See this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&p=158953#p158953
                  • CadFatherC
                    CadFather
                    fantastico Fredo - it works! β˜€
                    • H
                      hansschatz
                      Thank you! It's very useful!
                      • fredo6F
                        NEW VERSION 2.0g NOW RELEASED
                        IMPORTANT: I decided to change the name of this plugin, as the previous name could create confusion with an existing company and infringe their trademark. Please use now the new name FredoScale when referring to this plugin.
                        This version is identical to the previous one 2.0f, except the possibility to configure the toolbar without separators (a request from CadFather). The option can be selected in the Default Parameter dialog box.
                        See main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                        It works with the current LibFredo6 3.1f
                        • COSEDIMARCOC
                          COSEDIMARCO
                          Updated the Italian Translation File
                          Italian Translation of FredoScale 2.0g
                          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                            Can the old Freescale folders be deleted?
                            • Jean-FrancoJ
                              Jean-Franco
                              Yes, I did it and it works, no problem.
                              Jean-Franco
                              • utilerU
                                utiler
                                The reason for my latest posts, Thom.
                                404 Not Found
                                (www.sketchucation.com)
                                Just Curious...
                                • fredo6F
                                  Yes, in general you can safely erase the subfolder (here FREESCALE_Dir_20) once you have installed a more recent version.
                                  • david_hD
                                    david_h
                                    Anybody else having a problem getting the install to work? Mine deosn't show up. The old one worked fine. .. but the new one. . .nuthin'.
                                    EDITGot it figgered out. Crisis averted. πŸ˜„
                                    • marleusM
                                      marleus
                                      THANK YOU Fredo!!!!!!
                                      You're brilliant.
                                      Finally I get my chair seats right πŸ‘
                                      Markus Sillander
                                      Vantaa, Finland
                                      I'm on FormFonts now
                                      http://www.formfonts.com
                                        Marinho
                                        Hi Fredo, morning, meu name is Marinho, and I live in Luciara, Mato Grosso state, Brasil (nearly 11Β°30'00"S - 50Β°30'00"W at side of Araguaia River). I want you if you can send me please the your famous plugin, now with changed name, FREDOSCALE 2.0f. I use the Sketchup 6.0 and lake very match can use this plugin.I dont find it to download in anyplace in internet.
                                        Tanks a lot,
                                        Best regards
                                        Marinho.
                                          Tanks a lot,
                                          Best regards
                                          Marinho.
                                          Check the first post of this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180
                                            Marinho
                                            Hi Thomthom, I checked the link viewtopic.php?f=180&t=17948#p144180 but I dont find nothing about download FredScale 2.0g. Am I wrong? 😠
                                            Tanks,...
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 58
                                            • 59
                                            • 15 / 59
